First off, many, many thanks to
nimby
for the time he took to write the review on the Firestone A/T on the other 4Runner forum. The tire and lift combo was exactly what I was looking for so I followed his advice. I am very pleased with the outcome. After a little road time I have found a little rubbing on the fender liner when in reverse at full turn so I'll be doing the fender liner mod in due time. Not even close to a BMC
I have also attached a document I created when researching tires that I was interested in. No heavy mudders will be found here. I was looking for a more conservative tread with good road manners. My heavy off roading days are over.
Hope this helps some of you on the fence. Cheers!
Stats:
Eibach Pro Truck with P285/70r17 Firestone Destination A/T2 tires. Stock TRD/OR wheels
Front
Shocks set to 1.6
36 1/2" ground to bottom edge of fender. +1 7/8" Above stock (Stock was 34 5/8")
Rear
2 OME 10mm spacers, stock coils, stock shocks (Eibach PT delayed in shipping)
38" ground to bottom edge of fender. +1 1/4" Above stock (Stock was 36 3/4")
1 1/2" rake
Caster is set to 2.8L, 2.9R.
