Old 04-08-2020, 03:20 PM #1
Bat4runner Bat4runner is offline
Bat4runner is on a distinguished road
2020 SR5P Steering Wheel vibrations
Have a 2020 SR5P that i have some RRW wheels and got a set of 275/70/17 BFG KO2s with a 3/2 lift. I've had the KO2s on since December. I took my car in for 5k maintenance in January and from there i've noticed a steering wheel vibration at 55mph-60mph, then it smoothes out after that. Dealer said for the 5K maintenance, all they did was rotate the tires and check fluids. So i took the car to discount tires and they rebalanced all the tires. I've had the tires rebalanced 3 times already over the last 2 months, and i'm still feeling the vibrations at around 55mph, but its not as bad as it initially was.
Before I go and rotate my tires back to see if thats a fix, anyone have any ideas on what else could be causing this?
I had someone tell me sometimes 1 tire can be "defective" in the sense that it won't ever be able to provide a smooth ride and the only "fix" is to rotate my tires back and have the defective tire always sit in the rear.
What are everyone's thoughts on this.
Bat4runner is offline   Reply With QuoteReply With Quote
Old 04-08-2020, 03:22 PM #2
ryguytheman's Avatar
ryguytheman ryguytheman is offline
ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice
Search "steering wheel vibrations" on this site. This is a problem that many people experience. As far as I know, there is no straightforward solution.
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
ryguytheman is offline   Reply With QuoteReply With Quote
Old 04-08-2020, 03:33 PM #3
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
Yep, mine does it with KO2's. When I first got them I had them balanced twice and that solved it. The next tire rotation back, balanced again, better but not perfect. Very annoying.
I think the balancing has to be absolutely perfect on a 4Runner. Make sure you get a road force balance if they didn't do that.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 04-11-2020, 01:10 AM #4
So you're still experiencing issues with it after your most recent rotation? Are ko2 that hard to get balanced?
Thanks
Old 04-11-2020, 11:36 AM #5
steelevo steelevo is offline
steelevo is on a distinguished road
I agree that road force balancing is a must with a lot of tires.
Also, since you have a different set of wheels, I would double check the hub bore. If it’s not to exact OEM spec, you’ll need a hub centric ring to fill the gap. You’d be surprised at this not centering the wheel perfectly.
steelevo is offline   Reply With QuoteReply With Quote
Old 04-11-2020, 07:56 PM #6
The wheels were designed specifically for the 4runner and tacoma. Everything was fine prior to the first rotation.
My discount tire has a machine that says road force balancing, and that's what they used to balance my tires. Not sure if there's anything additional on top of that thats needed.
Old 04-11-2020, 08:44 PM #7
Sorry, I missed the wheels that you had in your first post.
The best way to isolate the problem, is to rotate the rear wheels back to the front, first. Move only one wheel up front at a time. If you’re issue goes away, then you have eliminated some of the wheels and tires. It could either be a bad tire or a bad wheel. Process of elimination is the only way to figure out what the issue is.
maintenance , rotate , sr5p , tire , tires
Audissey's 2020 SR5P Build - "Midnite" Audissey 5th gen T4Rs 14 10-29-2020 04:06 AM
XUJI leather steering wheel cover install. Goodbye plastic steering wheel. OEM? Kelbad 5th gen T4Rs 24 05-19-2019 03:51 AM
wheel vibrations bbf 4th Gen T4Rs 1 05-08-2018 12:07 PM
4th gen vibrations steering 03pontiacgtp 4th Gen T4Rs 5 04-23-2015 02:46 PM
steering wheel vibrations BRONXRUNNER General Discussions 2 01-18-2011 01:03 PM
