Hey folks looking for some advice. Over the last month I've noticed that shifting out of Park was a little stiffer than it ought to be. I took my center console apart but did not find any obstructions. Today on the highway I noticed that the gear light indicator on the dashboard was blank (yet it will show P, R, N just not D or the number if you're on S mode). About 20 minutes into my drive the check engine light and Trac Off lit up my dashboard (both solid).
It's a 2015 Limited with 75k miles. As luck would have it my powertrain warranty just ended 6 months ago too.
I've searched high and low but haven't found anyone with same problem on the forum (at least not for the Gen 5). Any clues on what the problem may be? Should I take it to a specialized transmission shop or my neighborhood mechanic? A little anxious about how costly this repair may be.
Thanks in advance!
Sent from my SM-T380 using Tapatalk
