04-09-2020, 03:04 PM
Real Name: Patrick
Real Name: Patrick
Odd electrical issue
I'm having a strange electrical experience with my truck. I go to turn it on, the truck goes completely dead...no warning lights, exterior or interior lights...nothing.
I take out my booster battery charger...it sits on there for 3 to 5 minutes, and boom, starts right up. It started about 2 weeks ago, it went a few days before it did it again, and now it seems to be increasing. This morning when it did the charge thing...the head unit went crazy trying to reset, reset, reset.
A little background. I have a group 31 Northstar, 4 years old, but just had it tested at the dealer a few weeks ago and they say it's fine. I do run a 100w panel on the roof, and a small fridge inside....it's been shut off for a few days now. I have a bunch of things wired into the truck...but everything goes to a separate fused panel, and nothing appears to be blown. The only thing cut into the original wiring harness is the remote start that was installed by the dealer.
Thoughts?
Thanks in advance
White 2016 TEP .....My ROAM Truck Build....... My ROAM trailer Build
04-09-2020, 03:43 PM
Real Name: Jeff
Real Name: Jeff
Hi, I would double check all of your wires going to your Northstar. Look for a loose connection. Maybe making contact most of time and then not. You charging it and hooking up the cables may be just enough for contact to be made again. If you dont find anything just for confirmation. I would have someone else check your battery. I think loose wire or battery post connector.
You could also put in the run position next time it does it and go under the hood and see if you can move the wires around and see if you can get vehicle to energize that way without the charger first.
2015 Trail Edition Premium Super White, Shrockworks RS , Gobi Stealth Rack, Bilstein 6112 coil overs set at 3rd notch with Toytec 1/2 in spacers, SPC UCA, Rear Bilstein 5160, Cornfed 3/4 rear spacer, Airlift 1000 airbags, Fuel D700 wheels 17x9 -12, 285/75/17 Nitto Ridge Grapplers- TRD skidplate, RCI TRD Integration Skid Plate. Toytec 1in body lift, BMC
04-09-2020, 05:48 PM
Real Name: BobH
Real Name: BobH
Appears to me to be a battery that will not hold a charge very long. I would disconnect all your extras on the added fuse panel to see if it still happens.
Another item would be to disconnect the + lead from the battery and insert an ammeter to see if there is very much current being drawn when all is off. Close the drivers door to make the overhead lights turn off too. Mine runs 125 ma with everything off after s short time.
Check the battery voltage when its running to see if it's charging the battery enough. 13.6 or higher should show, then drop to 12 when turned off.
Then I would get a new battery if all looks OK.
Mine did not give me any warning, one slow crank and start, then it died.
04-09-2020, 06:43 PM
I would take it and have the battery, charging and electrical system tested. A good tester will check the battery status, battery under load, alternator output and charging system. You could have a bad diode in the alternator and not charging the battery properly.
Checking all connections (as mentioned) is a good idea too. Battery terminals and cable ends for tightness and corrosion. Also ground connection to frame and alternator connections for same.
04-09-2020, 10:46 PM
Pat,
You took it to a Dealer?
Your better than that. ask Antman, LOL
all kidding aside it Sounds like a battery went south.
signature not available
04-10-2020, 09:18 AM
x2 battery
04-10-2020, 01:25 PM
Northstar went southstar.
I'll show myself out.
04-11-2020, 03:43 PM
Real Name: Patrick
Real Name: Patrick
Ok folks...nice sunny day here in NY...amp meter at the rear says 14.2.where the solar panel comes in ...take a reading at the battery, it says 14.2.
Go to start the truck"click" everything is dead...almost like its grounding out or something. I guess tomorrow I'll disconnect all the ancillary accessories wired in, and start from ground zero. If I still have a good reading at the battery, all accessories are disconnected, and she still wont start, I guess I'm headed back to dealer on Monday.
I started it with the jump pack today...I'm lost.
04-11-2020, 04:29 PM
You can try this to get a better idea of your batteries condition. Completely disconnect the battery, use some 12v accessory to knock the surface charge off it and let the battery sit for a day then take reading at the posts.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
04-11-2020, 08:26 PM
Real Name: BobH
Real Name: BobH
You are working too much, and do not go to a dealer, even if you like them. Go buy a new battery, Optima, AGM or whatever you like. You may have lots of time with the restrictions, but do something more fun.
This was not fun either -- I just finished an oil change and had more trouble than usual with the skid plate. The front tabs are now gone.
04-15-2020, 10:54 AM
Real Name: Jeff
Real Name: Jeff
Whats the word from the shop ?
04-15-2020, 12:23 PM
Has anyone mentioned the alternator??
__________________________
2014 4Runner LE - XD Grenade OR 17" Gunmetal Wheels - 285/70/17 Ridge Grapplers - XREAS Delete - ToyTec BOSS Suspension Lift w/SPC UCA's - Borla Catback Exhaust - AFE Momentum GT Pro CAI - Sprint Booster (wow!) - Tint Match - AVS Aeroskin - K&N Washable Cabin Air Filter - Black Emblem Kit - Stock Running Board & LE Rocker Trim Delete - Added RSG Flat Sliders w/bump-out & TE Rocker Trim - Full LED Swap - Rola Rack & Fox Wing Awning: Skids, lights and new front end w/Slimline bumper & winch still awaiting clearance from the tower...
04-15-2020, 12:38 PM
Originally Posted by honda250xtitan
x2 battery
nice
04-15-2020, 09:42 PM
Sounds like a dead battery to me. How are you measuring battery condition? You cannot use a volt meter... must use a battery tester that loads the battery.
Cause of low battery could be a short somewhere... or slow draw on battery. But first step is check battery condition properly. Good luck
04-15-2020, 10:44 PM
Real Name: Bob
Real Name: Bob
Thanks in advance
I am having the same issue.....when it sits idle for more than a couple days, it won't start....think its a battery problem.....going to take it Advance Auto Parts for a test
2018 TRD ORP, MGM, Xpel 35% Tint, Xpel Clear Bra, In-Dash 2m/70cm Icom Radio, Dual-band 1/4 wave antenna with Rago Mount, sPod Bantam, 2 x 32" behind the grille LED lightbars, Cali Raised 3-way Fog Lights.
Sold: 2011 SR5
