04-10-2020, 04:26 PM
Disable nannies on 2020 4runner
I'm looking at the 2020 4runner and noticed they added some nannies (PCS and LDA). Given that they are the driving distraction, I want to disable them permanently. Or at least have them off until I turn them on.
I've seen several posts on lifts with issues but nothing on turning it off permanently.
Does anyone know of a way to do that? I'm assuming that Techstream can do it, but I can't find the manual (options) otherwise I would RTFM.
Thanks,
Jerold
04-10-2020, 04:29 PM
Thanks,
Jerold
Hi Jerold,
There are dedicated buttons on the steering wheel for these. Turned them off and hadn't thought of them since this thread.
-Greg
04-10-2020, 04:33 PM
Wow thanks for the quick reply!
The Toyota manual says they come back on when the engine starts.
PCS - "The system is automatically enabled each time the engine switch is turned to the “ON” position (vehicles without a smart key system) or the engine switch is turned to IGNITION ON mode (vehicles with a smartkey system)."
LDA - "When the LDA system is turned onor off, operation of the LDA system continues in the same condition the next time the engine is started."
Is this not the case?
04-10-2020, 04:55 PM
I turned off my LDA with the button on the steering wheel and it did not reactivate each time I restarted the car. I haven't played with the PCS though.
2020 ORP - Dobinson's 302/505, JBA UCAs, 5100s, Cooper AT3 Discoverer XLT 285/70/17
4Runners and Dobermans - https://www.instagram.com/derpydobies
04-10-2020, 07:10 PM
Originally Posted by GRDPro
Hi Jerold,
-Greg
Turned them off as I left the dealership. I paid a lot of money for these things. Only thing I get benefit of is CarPlay and the bigger screen.
04-10-2020, 07:32 PM
There there for a reason. Get a different car.
Jokes aside, I always thought they would return after restarting the engine or whatever.
04-10-2020, 07:50 PM
Real Name: Sparky
Real Name: Sparky
The same truck but older?
Old and (c)rusty.
04-10-2020, 08:21 PM
You can turn off the lane departure, but you can't turn off the front collision warning - only adjust the sensitivity.
04-10-2020, 10:26 PM
Banned
Banned
I can second this. My LDA has been off for over a month, and I haven't touched the button since that long ago.
I do remember there being sensitivity settings for the LDA in the between the speedometer and tachometer display, but there's a dedicated button to turn it on and off in the lower right of the steering wheel.
04-10-2020, 11:54 PM
Real Name: Mark
Real Name: Mark
The Toyota manual says only the PCS is enabled each time. It says the LDA stays at whatever the last setting was. That is the way mine works. I don't mind the PCS but the LDA has been turned off since I bought mine.
Current: 2004 Land Cruiser Thundercloud Metallic
Former: 2020 ORP Silver. BFG AT KO2s, TRD Skid Plate, added Rear Sliding Deck, Pro LED fogs, Infinity REF-3032CFX dash speakers.
In Between: 2020 Jeep Wrangler Unlimited Rubicon with almost all options. Got tired of worrying about it disintegrating and ending up setting at the dealer for weeks and months.
Former: 2010 TE Silver w/ C4 Fab Rock Sliders, TRD skid plate, ECGS bushing upgrade, Bilstein 5100s, and BFG AT KO2 tires.
04-11-2020, 01:05 PM
The LDA is fairly sensitive, especially toward the passenger side though I leave it on anyway. I dont find it that annoying.
The PCS I left at the default and it's only had a false alarm twice in 6 months and neither time did it try to stop on it's own. There is a step even less sensitive which I haven't tried either.
04-11-2020, 01:16 PM
If you want to disable them permanently than maybe look at an older model. Might be able to get a good deal on a 2019. Since they don’t any of that stuff to begin with.
04-11-2020, 05:43 PM
Hi Jerold,
-Greg
Agreed, mine are off at the press of a button and do not come back on until I press the button again. I leave them off.
05-11-2021, 11:31 AM
I started a similar thread a few days ago, because I missed this one…
I've had a couple of rental cars with these "features" and they are certainly very annoying; I especially hate when they try to steer you in a certain direction.
It seems there is a little bit of a disconnect between what the manual says and what actually happens in the vehicle… I guess I should go for a test drive and decide if I'm going to buy new or pre-2020.
Between outfits.
05-11-2021, 11:49 AM
Bought a 2021 can confirm these setting changes have persistence across restarts. Change it once, you’re done.
