03-22-2019, 04:22 PM
Rear spring question
Is there a spring that I could replace my stock rear springs with to get 1" of lift?
I know I could just use a spacer but thought maybe new rear springs would be better. My Runner has 64K on it now.
'14 4Runner SR5 Premium Bilstien 1500's, Airlift bags, 275 70R 17 Cooper AT3's,Power Stop rotors & brakes, Xenon Depot 9005 Extreme Pro LED, Morimoto H11 2Stroke 2.0, AEM dry flow filter, Magnaflow exhaust, Sprint Booster
'19 Tundra Limited CM, 2.5/1 Bilsteins 5600's, Cooper AT3 275 70 18 on Method NV305's
'12 Subaru Legacy Limited
03-22-2019, 04:24 PM
official vendor
official vendor
The Eibach rear spring lifts 1" and rides great.
Part number E30-82-071-01-02 for the pair.
2019 TRD Off Road
2007 GT3
1982 911 SC
03-22-2019, 04:32 PM
For a 1" rear lift, if you don't do a lot of off roading, I'd go with a 1" spacer.
$0.02.
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Procharged (D1SC), Bilstein 5100s w/ 2" Toytech Superflex, 285/70/18 duratracs (E), 18x9 Volk TE37, OEM Audio+ Ref500, RA Motorsports rack, TRD hood + skid // 2003 Black Limited (2UZFE) aka Blacky Chan: Bilstein 5100 w/ Icon 2.5" springs, BMC, air bag delete, 17x9 SCS Ray10, 285/70/18 Yokos
03-22-2019, 09:09 PM
Just hop on Amazon and look. Icon and Dobinsons are two solid brands. They make springs with different promised ride height increases. Installation is pretty easy, especially if you don’t have KDSS. Plenty of videos on that.
Current - 17’ TRD ORP KDSS/Bilstein/Chaos UCA’s/TRD PRO/KO2 285s/Rigid Fogs
Former - 14’ TEP - too much to list
Former - 11’ SR5
03-23-2019, 08:17 AM
Check out wheelers off road springs, I believe they are made by eibach. If I were to go that route, I would also check if you should the shocks with bilstein or something with more travel. I believe wheelers T1 (front) and T13 (rear) springs matched with bilsteins was used by someone on this forum in one of the 5100 threads. hope this helps.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
03-23-2019, 08:46 AM
I second the eibach spring. Gives the advertised lift height and isn’t too stiff. If your going through the trouble to put a spacer in might as well put an upgraded spring in. Same amount of work.
2022 Limited 4x4 Silver
2017 TRD Offroad. Barcelona Red, 265 BFG KO2, Eibach Pro-truck 1.6/1, Shrockworks sliders-TRADED
03-23-2019, 08:49 PM
I used this spring as well, 2015 Trail, no 3rd row. Gave advertised amount of lift and rides great paired with some 5160’s
03-23-2019, 08:52 PM
I think this is the only one I have found that says 1".
Ryan, is it 1" sharp, once settled? I assume that 1" applies to a newer vehicle and that an older rig would see a bit more vs the sagging suspension being replaced?
03-23-2019, 11:49 PM
official vendor
official vendor
Plus or minus a millimeter or two.
You could see a little more if the OE springs have settled a bit.
We also make a rear spring for Wheeler’s that gets 1.5.
Ryan
2019 TRD Off Road
2007 GT3
1982 911 SC
03-24-2019, 12:07 AM
Ryan
Thanks for the clarification.
03-24-2019, 12:22 AM
FJ Cruiser rear springs would probably get you close to 1" if you were looking to stay with something with less spring rate, closer to stock.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
03-24-2019, 12:36 AM
Isn't that only true of IV gen?
03-24-2019, 08:20 AM
Already running Bilsteins on all 4 corners. Just looking for the minimum rear lift. I dont want an excessive rear rake again.
03-24-2019, 11:16 AM
Hmmm, it's definitely true of 4th gens, I assumed the same would hold true for 5th gens. Is there some reason it wouldn't apply? The suspensions are mostly the same.
03-24-2019, 11:29 AM
From what I have read here, the FJ coils as lift coils only work for 4th gen due to the 5th being heavier.
Per Google, there is a 450lb weight difference between a 2007 and a 2017 4x4 4Runner for V6 models. The FJ and the 4th gen, otoh, are both listed at 4,300lb.
