05-05-2020, 11:24 AM
Tie Rod Reccomendations
Can anyone make a recommendation on replacement Tie Rods? I found a couple comments that OEM was best for the inners?
Thanks in advance for your help
05-05-2020, 03:43 PM
Ive replaced both inner and outer tie rods so many times I've lost count. IMO its best to go OEM. Use you existing ones as trail spares you will probably need them at some point. It's a critical part so I wouldnt go cheap.
On a side note I really wish Marlin Crawler would build their Toyota IFS HD Steering system quicker. We sorely need it
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
05-05-2020, 03:52 PM
Yeah I agree. This is the second time I've damaged mine, Went OEM replacement the first time, I was just wondering if there was something stronger. Thanks
05-05-2020, 04:02 PM
I think the challenge of a stronger tie rod solution is the potential to frag the steering rack like I did a month ago. We really need a total replacement of all steering components. Again, hoping Marlin Crawler will deliver there eventually.
05-05-2020, 04:04 PM
Sounds interesting to me!
05-05-2020, 04:28 PM
Would totally get their system in a heartbeat if they released it. Their stuff if bombproof! I have their LCA frame braces/cam tabs and damn those plates were heavy. Haven't lost an alignment yet.
Makes me wonder...what steering rack was the Marlin equipped 4runner at KOH using?
EDIT: Looks like it was running the prototype (2nd one made) MarRack. Steel City Racing & Marlin Crawler: KOH 2019 Toyota 4Runner IFS 4600 Build
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
05-06-2020, 08:35 AM
Good eye! Here it is
05-06-2020, 08:42 AM
That sure is pretty! Question is, how and when can I get one lol
