Old 04-12-2020, 02:40 PM #1
pointman pointman is offline
Banned
pointman will become famous soon enough pointman will become famous soon enough
Banned
Hefty Fab Steel tube bumper on stock suspension..
Bad idea? I am about to pull the trigger and wanted to get some feedback if possible. All the research I've done points to there being a tiny bit of almost in-perceivable droop from the heavy weight, but that it will be fine to run it on stock suspension. Would love to hear if I am making a mistake, if Hefty is a solid option (found a thread about delayed build times but it appears they have it in stock), or anything really. Thank you.
pointman is offline   Reply With QuoteReply With Quote
Old 04-12-2020, 02:48 PM #2
JSparky's Avatar
JSparky JSparky is offline
JSparky is a jewel in the rough JSparky is a jewel in the rough JSparky is a jewel in the rough
JSparky's Avatar
Just to throw some numbers up, if we’re looking at their “hybrid tube bumper”, it clocks in at 98lbs. Will you be adding a winch or no?
67' Land Rover 109, 97' FZJ80, 16' 4Runner Limited
http://www.toyota-4runner.org/5th-ge...-jr-build.html
http://www.overlandcookery.com
http://www.schaubphoto.com
JSparky is offline   Reply With QuoteReply With Quote
Old 04-12-2020, 02:50 PM #3
Banned
Banned
Sorry I forgot to add that! Nothing else. Just the bumper. No winch for sure. Stock 19 with kdss.
Old 04-12-2020, 03:31 PM #4
JSparky's Avatar
JSparky's Avatar
Cool, you’ll get a lot of opinions but I say you’re probably fine.
You’ll feel the weight of the bumper when driving, no way around that. If you’re unhappy with the performance you can always swap out the struts for a blistein 5100/Dobinsons/OME setup to firm up the ride without spending too much. I wouldn’t say it’s immediately necessary for 100lbs in added weight. A winch would be another story.
Nosedive when braking would be my only real concern, especially on mountain roads, but take it one step at a time.
Old 04-12-2020, 03:49 PM #5
Banned
Banned
Thanks for the details. I appreciate that. I'm not sure how I feel about nosedive or feeling it in a daily capacity. I've run bars up front in other vehicles, but they seemed much more cosmetic than this one would be. Now I feel a bit unsure about whether to get it or not haha But I do appreciate the information as this is precisely what I was looking to hear.
Old 04-12-2020, 04:24 PM #6
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
As @JSparky said I'd drive it first then see how you feel. That being said, you didn't give many details about your rig. Do you have anything else on you're rig? Even sliders might be enough to tip the scale into wanting a heavier coil.
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 04-12-2020, 05:06 PM #7
Banned
Banned
Hey, sorry. Stock. I'm surprised sub 100 lbs up front would make it feel.. different.
Old 04-12-2020, 05:58 PM #8
comtn4x4's Avatar
comtn4x4's Avatar
It's more that the 100# is hanging off the front and the front suspension carries all of it. When I added my aluminum front bumper and winch which is about 140# it made a huge difference and I had to go from my already up-sized 650# coils to 700# coils. However, I did have sliders and a very heavy roof rack and skid plates already
Old 04-12-2020, 06:38 PM #9
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Not running stock suspension but when I added my lopro bumper + winch, i definitely noticed the added weight. Swapped out the coils and the ride quality was much much better
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 04-12-2020, 07:47 PM #10
Banned
Banned
Thanks for the feedback. So curious if I will run into disliking it without modding the suspension. You are running a bunch of mods though so maybe I would get lucky. I guess I have to research suspension now. Is it just a matter of getting new coils? If so, what would you recommend?
Sounds like I might regret this without changing something else in the suspension. What coils did you go with? Any other suspension work needed?
Old 04-12-2020, 07:51 PM #11
87pony 87pony is offline
87pony will become famous soon enough
if they didnt already have nose dive id say you would be fine. buuuut since they do from factory, it will definitely make it a little worse.
87pony is offline   Reply With QuoteReply With Quote
Old 04-12-2020, 08:04 PM #12
It's generally recommended to install the new shocks/coils after adding all your weight so you can still get the bumper and then see if you like the ride. I'm also running a full set of skids (aluminum front and steel everything else) but added the bumper/winch much later. I went with a simple Dobinsons Twintube set up. For fronts and rears, it costed about 800ish. They have a bunch of coil options for specific ride height/weight.
Just see though if you like the ride on stock and go from there.
Old 04-12-2020, 08:47 PM #13
comtn4x4's Avatar
comtn4x4's Avatar
You'll definitely benefit from driving it with the bumper on and seeing how it is. The only thing I could say for sure is that it will change some. You'll have to see how you feel about that. It's definitely possible that you get lucky.
You could get new coils only, although I would imagine that you would end up doing the shocks too after looking into it. As far as recommendations go, it depends on your budget. The new Eibach stuff looks nice and gets good reviews. Bilstein and Dobinson's is a good choice too and well reviewed also. If you can step up slightly you could look at Toytec or others too. I personally prefer a fully adjustable front coil over so your suspension can grow with your build but that's a bit more of an investment and may exceed your needs.
The whole suspension thing of kind of a can of worms honestly. If I do this then I want that etc.
Old 04-12-2020, 08:48 PM #14
Sbenis Sbenis is offline
Sbenis is on a distinguished road
If you do this you will def need to upgrade your front suspension ,id save up for some upgrades before puting it on .
Sbenis is offline   Reply With QuoteReply With Quote
Old 04-12-2020, 10:50 PM #15
Banned
Banned
I actually don't mind the dive! Only time it seems excessive is when I brake suddenly and the brakes lock up and its like I fell over the side of the Titanic.
I think this is the only armor mod I want to do! Thanks for the suggestion and estimate. Gives me something to work off of. Had no idea previously. I really like how the 4Runner is now and don't want to mess with the geometry of it too much. This was supposed to be my "don't touch it and enjoy its reliability" ride.
Thank you! I am only hopeful thinking it might just change a tad and I will be ok with it. The idea of jumping into other mods, isn't where I wanted to be. But the look and functionality of that front bumper is calling to me.
The can of worms is what I am trying to avoid! Appreciate the suggestions. Now I have to search all this stuff up. Thanks again.
"definitely"?? Oh man..
hefty , run , solid , stock , suspension
5th gen Hefty Fabworks front tube bumper PNWT4RP For Sale: T4R Items 4 11-14-2019 04:52 PM
Steel CBI Bumper with stock suspension? geofox784 5th gen T4Rs 1 03-12-2019 10:21 AM
FT 3rd Gen Savage Offroad tube bumper for Stock (99-02) Bumper plus $200 Concord, NC SR597Runner Want to Buy/Trade 0 01-23-2015 09:33 PM
Wishing to buy 3rd gen flat Steel or tube bumper Chodymace94 Want to Buy/Trade 0 09-26-2013 04:18 AM
Aluminum vs Steel tube bumper? AF808fighter 3rd gen T4Rs 1 02-14-2012 03:33 PM
