Old 04-13-2020, 01:16 PM #1
Agent_Outside's Avatar
Agent_Outside Agent_Outside is offline
Agent_Outside is just really nice Agent_Outside is just really nice Agent_Outside is just really nice Agent_Outside is just really nice
Which rear springs and why?
I’m looking for some input. I have a 5th gen 4Runner, family hauler, road trip, camping, overland type build. It gets used and abused pretty hard but it’s not definitely not a rock crawler.
Current suspension is extended travel remote res Kings with custom length rears, Ikon 2” rear springs, OME trim pack spacer for the rear to correct the lean, durabumps, JBA control arms. About a 2” lift all the way around maintaining rake when not loaded.
I have a steel rear bumper on order.
The bumper alone is 225 lbs, and the full size 33” spare will go from under the truck to out back, no extra weight there but it’s leveraged further out. it has RCI sliders and Their aluminum plate armor so I’d gray see probably guess 50-75 pounds to the rear axle. I also have a small Dometic fridge. So I figure with the new rear bumper I figure 300-350 pounds static year round weight added. When it’s not ski season I have a 160-170 pounds distributed across a full length roof rack for the rear of the year from an iKamper Skycamp that’s bed lined.
What rear springs would you go with for my application and why?
Agent_Outside is offline   Reply With QuoteReply With Quote
Old 04-13-2020, 01:24 PM #2
engeeoh01 engeeoh01 is offline
engeeoh01 is on a distinguished road
How about air bags? Considering the varying weight throughout the year, it may be ideal to have air bags since it’s adjustable.
engeeoh01 is offline   Reply With QuoteReply With Quote
Old 04-13-2020, 01:39 PM #3
That might something to consider if need be but honestly I didn’t think airbags will be necessary when the only real variance in weight is the tent and when it’s mounted the weight is distributed relatively evenly.
Old 04-13-2020, 02:02 PM #4
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
If you like the 2" lift now, I would recommend looking at the Dobinsons C59-327 - 200-400LB heavy rear load weight, 2" lift.
Dobinsons 5th Gen T4R Suspension options - lots of choices
Dobinsons C59-327 Rear Coil Springs for Toyota 4Runner and FJ Cruiser
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 04-13-2020, 02:07 PM #5
MaddoxPics's Avatar
MaddoxPics MaddoxPics is offline
MaddoxPics is a jewel in the rough MaddoxPics is a jewel in the rough MaddoxPics is a jewel in the rough
MaddoxPics's Avatar
Been running OME medium rates for awhile. Going to switch up to the Dobinson 749V. I think it's good for constant weight of 700+. With the hauler I'm not sure if you'll want more of if that'll work.
MaddoxPics is offline   Reply With QuoteReply With Quote
Old 04-13-2020, 02:52 PM #6
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
I'm thinking the Dobinsons rear progessive rate coils seem appropriate in your situation. The 701V or 749V seem like good choices. Chat with @Crikeymike and I'm sure he can give you his best recommendation.
Dobinsons rear long travel variable rate flexi coils
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 04-13-2020, 02:54 PM #7
JSparky's Avatar
JSparky JSparky is offline
JSparky is a jewel in the rough JSparky is a jewel in the rough JSparky is a jewel in the rough
JSparky's Avatar
I’ve run a lot of rear coils. With that weight I’d go with Dobinsons “heavy” progressive or OME 899.
I prefer a linear coil, so OME 899 is my first suggestion. I’m on Dob’s super heavy coils now, mainly for height and downtravel, but if keeping at 2-3” of lift for your custom shocks I’d go OME.
Don’t be afraid of the 880lb constant load, they ride good on a 4Runner with armor, bumper, tent, fridge, and other gear (I know cause I ran them). I believe the last page of my build thread shows them if you wanna check them out. Dobinsons may have a linear option too, haven’t checked their page out in awhile!
67' Land Rover 109, 97' FZJ80, 16' 4Runner Limited
http://www.toyota-4runner.org/5th-ge...-jr-build.html
http://www.overlandcookery.com
http://www.schaubphoto.com
JSparky is offline   Reply With QuoteReply With Quote
Old 04-13-2020, 03:17 PM #8
offroadarcade offroadarcade is offline
offroadarcade is on a distinguished road
JSparky - curious what specifically you like more about a linear coil vs progressive.
offroadarcade is offline   Reply With QuoteReply With Quote
Old 04-14-2020, 12:32 AM #9
JSparky's Avatar
JSparky's Avatar
They both have their benefits, but from a road handling perspective I feel that linear coils behave more predictably, especially in turns on windy roads. It’s not a huge deal (I am happily running progressives) but it is a consideration.
Old 04-14-2020, 12:40 AM #10
SHagood's Avatar
SHagood SHagood is offline
SHagood is just really nice SHagood is just really nice SHagood is just really nice SHagood is just really nice
SHagood's Avatar
Dobinsonssssssss.
Buy them through Apex Overland, shoot them an email, DM on instagram, or call Jill and tell them your setup and what you want. They will pair you with springs loaded for additional weight based on your needs.
2008 Urban Runner
MY BUILD THREAD
SHagood is offline   Reply With QuoteReply With Quote
Old 04-14-2020, 09:09 AM #11
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
After monkeying around with different rear springs over the years I’m super happy with my OME 899s. I’m a similar weight to where you will be at and I wish they were a little stiffer to be honest. When I’m fully loaded I even turn up my rear compression dampening pretty high to stay off of my bump stops when moving briskly off road.
Here’s how I sit fully loaded with about two weeks of food and water loaded up. The front end is a bit low because I adjusted them down before this trip.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 04-14-2020, 08:38 PM #12
War Eagle's Avatar
War Eagle War Eagle is offline
Real Name: Mark P
War Eagle will become famous soon enough
War Eagle's Avatar
Real Name: Mark P
I run Bilstein heavies and happy.
Proline bumper, dual swingouts, dual cans, Dometic fridge, RSG plate sliders, RCI Steel skids including tank, Rhino Rack Pioneer platform and full sized batwing, Thule XT Pro bike rack and A Cannondale mountain bike. I also have an APOC steel expo trailer - zero squat
Silver 2018 4Runner ORP w/ KDSS|Bilstein TRD FJC TTU & HD suspension|275 BFG KO2s|RSG sliders|RCI steel full skid set|Warn hybrid bumper|X20 winch w/ Southeast Overland Rope|DD Sport fogs & rear floods|22” X6 LED bar|Orange Boxx panels|Rhino-Rack Pioneer|Proline elite rear w/ dual swingouts & FrontRunner Table.
War Eagle is offline   Reply With QuoteReply With Quote
Old 04-14-2020, 09:00 PM #13
Frodaddy Frodaddy is offline
Frodaddy is on a distinguished road
Bilstein Heavy Load (400lb) #36-281831 would work great on your type of setup, but they provide only 1.5" lift. You could run a small spacer with these to get to 2" if that is the height you really want to achieve.
OME Options:
889 - 2.5 - 3" lift - Medium Rear Coils
898 - 2.5 - 3" lift - Heavy Load - 440 lbs constant load
899 - 2.5-3" lift - Heavy Load - 880 lbs constant load
All OME's are 2.5-3" Lift which may be a little tall for what your wanting to do. Either way, I would stick around the 400lb added load rating.
Both the Bilstein's and the OME's are linear, which I prefer.
Frodaddy is offline   Reply With QuoteReply With Quote
Old 04-14-2020, 09:37 PM #14
War Eagle's Avatar
Real Name: Mark P
War Eagle's Avatar
Real Name: Mark P
OME Options:
He might get more lift. I have same springs and had 2.5” of lift over weighted OEMs. Above load minus bike and rack
Before Hub center to fender
-driver 20”
-passenger 19.5
Afterward hub center to fender
Driver 22.5
Passenger 22.5
Old 04-14-2020, 10:30 PM #15
Rico696 Rico696 is offline
Rico696 is on a distinguished road
I got a similar set-up as you, steel rear with sliders, skids, and Gobi rack and I ended up going with OME 898's and they are perfect. Mine is my daily and only loaded when we traveling, so I did not want to go with a high constant load spring (ei. OME 899's) since from what I've read, they give an extremely harsh ride. But...since I've never tried those...I can't say the do from experience, just from what I've read. I have OME BP-51's and had a medium spring before and I could feel the "bounce" on the back way too much even when I adjusted the settings on the shocks, which is why I went with the 898's. Just my experience, hope this helps. Cheers!
Rico696 is offline   Reply With QuoteReply With Quote
bumper , it’s , pounds , rear , springs
OME 906 Rear 2" lift springs $140 (Colorado Springs) 99 sr5 highlander For Sale: Suspension/Wheels/Tires 2 06-28-2015 11:13 PM
Need new rear springs that work with Bilstein HD's. Stock springs isn't doing it sugjavier 3rd gen T4Rs 5 08-16-2014 06:15 PM
Rear Coil springs for 3rd gen (replacement recall springs) stevesnj For Sale: Suspension/Wheels/Tires 0 07-20-2013 10:57 AM
'99 front springs/shocks w/spacer & rear springs Full_Throttle For Sale: Suspension/Wheels/Tires 10 09-18-2012 11:57 PM
FJ 4x4 Front shocks and Springs and Rear Springs The_B.O.W. Classifieds - buy & sell (no commercial ads please) 0 09-26-2010 11:26 PM
