Old 04-15-2020, 09:31 AM #1
ClovisMan's Avatar
ClovisMan ClovisMan is offline
ClovisMan is on a distinguished road
ClovisMan's Avatar
Will it fit? Or will it hit?
I have a 2.75/1 lift kit on its way and I was wondering if a 17x9 inch wheel with a 5.5 backspace will fit. I have the old American Outlaw wheels from my Silverado that have the same lug pattern and have 285/70/17 KO2's on them. I would like to run them temporarily until new wheel/tire money comes from Uncle Trump. :P
ClovisMan is offline   Reply With QuoteReply With Quote
Old 04-15-2020, 10:16 AM #2
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Hub bore diameter might be too small. Check that first. Has to be at least 106.something mm, over 4". IIRC the chevy bore is around 80mm.
delloro is offline   Reply With QuoteReply With Quote
Old 04-15-2020, 10:24 AM #3
ClovisMan's Avatar
ClovisMan's Avatar
Here are the specs. Maybe I was wrong about the backspacing being 5.5 inch. That looks to be the lug pattern spacing. Hub bore is 106.
Wheel Specs:
• Diameter: 17
• Wheel Width: 9
• Bolt Pattern: 6-139.7/5.5"-0.0
• Offset: -10
• Hub Bore Size: 106
• Weight: 28
• Finish: Silver
• Wheel Accent: Ball Cut Machined
• Load Capacity: 2400
• Wheel Piece Quantity: 1
• Construction Material Description
• Number Of Bolts: 6
• MPN Part Number: 117-7983S
Old 04-15-2020, 12:20 PM #4
delloro's Avatar
delloro's Avatar
Your backspacing will be 5.0" less 10mm, so about 4 5/8".
Wheel Offset Calculator
4.61"
You will be doing some work. Trimming the front, removing the muflaps, and maybe working on the body mount.
Old 04-15-2020, 01:03 PM #5
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
It will probably rub. Mine rubbed on a -10 backspace with 8.5 inch wide wheels and 285/70R17s.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 04-15-2020, 03:02 PM #6
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
I'd say it would rub pretty good. Mine did with 9" rims 5" backspace +1 mm offset. I did BMC, removed the mud flaps and some trimming. Get your caster out as far as you can and that will help some
comtn4x4 is offline   Reply With QuoteReply With Quote
fit , ko2s , lug , trump , wheel/tire
