04-15-2020, 01:46 PM
No Drill KDSS Sliders
Does such a thing exist? I'm not too familiar with slider options but I have a 19 ORP with KDSS. Prefer no drill options. What is out there?
FTR, I researched but it's like wading through a sea of of partial info.
04-15-2020, 01:50 PM
2013 Trail w/kdss - 4.56 gears - King shocks - Dobinsons C59-749v springs - Total Chaos UCA's, LCA'S + track bar - Metal Tech lower links - RR7-H - 305/70/17 Nitto Ridge Grapplers - Sherpa Crestone Rack - ARB drawers - OPOR sliders - RCI Skids - CBI Bumpers - Warn VR10S.
04-15-2020, 02:09 PM
I got the RCI 5 degree sliders with step plate for my KDSS 2017 4Runner. Love them. On one side of the 4Runner the slider is identical to non-KDSS and on the other side is modified to go around a KDSS component. 60 lbs weight on one side and 50lbs for the other side. Lighter if you don't get the step plate.
5 degrees allows you to use it as a step to get into the 4Runner. My 7 year old daughter uses it to get into the back seat. That's why I also like the kickout on the RCI sliders. The step plate and 5 degress I also use to get access to the roof easier.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
04-15-2020, 03:29 PM
The Slee Sliders required me to make one (I think) existing bottom frame hole on the passenger side a little bigger, but I think that was about it.
2018 TRD Off-Road - KDSS
Slee Sliders
CBI Skids
04-15-2020, 04:07 PM
04-15-2020, 07:36 PM
RSG uses the factory holes.
04-15-2020, 07:52 PM
RCI one didn't require any cutting. Just bolted on.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
04-15-2020, 07:58 PM
I have a 2019 TRD Off Road with KDSS and a 2inch Dobinsons lift. I started with RSG angled sliders with bump outs and no top plates. Loved the look, but they weren’t family friendly as far as climbing in like with the flimsy factory running boards. My wife and daughter hated the RSG sliders. Almost had a family friend break her ankle using them as a step.
I sold the RSG sliders and went with Victory 4x4 Strike sliders and those ended up p being exactly what we needed. They worked with KDSS, bolted on and did their job as rock sliders when we visited Arizona and did over 300 miles off road.
Photos are the factory running boards, then RSG sliders and finally the Victory 4x4. All the sliders bolt on and work with KDSS. Both of the sliders required very minor trimming of the KDSS skid plate. I’m talking a tiny thumbnail size notch. The Victory sliders require drilling two holes in the frame if you want to use them as serious rock sliders. No big deal for installing either set of sliders. The RSG were slightly easier to line up but they were both average installations.
04-15-2020, 08:02 PM
Real Name: Mark P
Real Name: Mark P
I have RSG with kick outs and plates. Super happy.
Silver 2018 4Runner ORP w/ KDSS|Bilstein TRD FJC TTU & HD suspension|275 BFG KO2s|RSG sliders|RCI steel full skid set|Warn hybrid bumper|X20 winch w/ Southeast Overland Rope|DD Sport fogs & rear floods|22” X6 LED bar|Orange Boxx panels|Rhino-Rack Pioneer|Proline elite rear w/ dual swingouts & FrontRunner Table.
04-15-2020, 11:25 PM
+1 for RCI
Mods are loading.......
04-16-2020, 12:27 AM
Shrockworks makes sliders. KDSS shouldn't matter for sliders.
5th Gen Toyota 4Runner Rock Sliders, 2010-2020
These are bolt on, super easy, did them in less than 2 hours with a buddy and some beer.
04-16-2020, 12:31 AM
I just installed a set of Shrockworks sliders on my 16 Trail. Simple, only one hole to drill. If you can’t put these on, you have no business near a wrench.
04-16-2020, 09:39 AM
Originally Posted by 2112 R
A lot of them are made for KDSS now. The difference is you have a pump on the side, so bolt on sliders need a break in the plate against the frame to fit around it.
