Old 04-17-2020, 01:27 PM #1
emmantik emmantik is offline
emmantik is just really nice emmantik is just really nice emmantik is just really nice emmantik is just really nice
Can I use these fuse slot blanks for rear cargo lights?
I have tested the following marked slots with a lamp tester and discovered that they provide power even though the key is not in ignition/not in ACC position. I have the following questions;
1. Can I use any of these marked slots to power 2 LED festoon lights (VLED 6418) in the cargo area? It will be controlled with a on/off button or switch.
2. If yes, are there any negative implications? Battery drain, eventual dead battery etc.?
Yes I can wire them like others have done here, which is to run with existing rear cargo lights but would like to try this option first as it would be less tedious. My plan B was to wire them like others have done which is well documented here.
Thanks!
Can I use these fuse slot blanks for rear cargo lights?-20200415_185629_resized-jpg
2015 Magnetic Gray SR5P
emmantik is offline   Reply With QuoteReply With Quote
battery , cargo , lights , power , wire
LED grille lights - Add a fuse using the tail light / side marker fuse DigitalRJH 5th gen T4Rs 8 03-19-2019 04:44 PM
Fuse slot with power all the time whitetiger 5th gen T4Rs 1 10-22-2017 02:07 PM
Is there an available switched 12v slot open in the fuse box? judogti 4th Gen T4Rs 5 06-17-2014 07:36 PM
What are all the blanks for to the left of my rear diff lock switch? NJB 3rd gen T4Rs 10 01-28-2009 10:39 AM
parking & rear lights fuse el_do33 4th Gen T4Rs 3 09-13-2008 01:11 AM
