Thread Tools Rating: Thread Rating: 18 votes, 4.78 average. Display Modes
Old 05-12-2020, 09:50 AM #16
HorsepowerJunkie HorsepowerJunkie is offline
HorsepowerJunkie is on a distinguished road
Great post with all info needed about servicing the vehicle!
HorsepowerJunkie is offline   Reply With QuoteReply With Quote
Old 05-13-2020, 04:20 AM #17
6uam671_T4R 6uam671_T4R is offline
6uam671_T4R is on a distinguished road
Thanks for putting in the work. I vote to have mods make this a sticky
6uam671_T4R is offline   Reply With QuoteReply With Quote
Old 08-02-2020, 01:19 PM #18
4RMDNA 4RMDNA is offline
4RMDNA is on a distinguished road
Oil Level Problem
Hi, I have a 2020 4Runner SR5 4WD. I did my oil change at 5500 a few days ago and I'm having issues with reading the oil level. The level keeps showing that it is overfilled (about 2-3 cm above the second dot). I've read online about how others are having issues as well. I used mobil 1 so it is very clear which doesn't help obviously. I put in the full 6.6 Qt after draining everything. Do you have any advice on what I should do to get an accurate reading? Should I drain some of it out? Thank you!
4RMDNA is offline   Reply With QuoteReply With Quote
Old 08-02-2020, 02:50 PM #19
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
I think you're OK. I have the same problem. See this video ... Easy! - How to read your dipstick when it's hard to see!. #13 - YouTube When I use this method, dipstick oil level is 1+ cm high on one side and about 6+ cm high on the other side even when I wipe the stick and remeasure as many as 6 times. See this thread Oil Level Reading . Read Lester Lugnut's post near end of thread. He bought a new Toyota dipstick which is a superseded part number. The new stick measures 1/2 inch shorter than the old stick and oil level has been right on full ever since changing to the new stick.
If your oil level is actually 2-3 cm high, nothing will happen as stated in other threads on this subject. When I do an oil change, I measure, count and set aside 6.6 quarts of oil to be put in to avoid any and all doubt as to how much oil went in. You could also measure how much comes out. I doubt very much if 1-2 quarts can remain pooled in the engine.
DougR is offline   Reply With QuoteReply With Quote
Old 08-02-2020, 10:07 PM #20
PARTRDPRO PARTRDPRO is offline
PARTRDPRO is on a distinguished road
👍 great info
PARTRDPRO is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 02:31 AM #21
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Edit: oops, I didn’t read DougR’s post closely at first. Looks like we’re saying the same thing. Might spring for a new dipstick for $12.50.
For most I think, it’s not that you can’t see the oil, it’s that it creeps up the stick. Usually one side more than the other. I always wait until the oil has been sitting overnight before I try to read it even though it goes against official procedure. Even then it’s usually only readable on one side.
1000MPH is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 12:42 PM #22
pointman pointman is offline
Banned
pointman will become famous soon enough pointman will become famous soon enough
Banned
Drive shaft fluid every 6 months??
pointman is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 01:26 PM #23
DougR's Avatar
DougR's Avatar
It's difficult to get a consistent oil level reading because the dipstick guide tube enters engine block at the back near the firewall. A section of the tube is very close to horizontal. If I rotate the dipstick 90 degrees, it cannot be inserted past the first bend in the guide. I kept probing and rotating the dipstick until I reached a point where it would barely get past the guide bends. Upon removing the stick, one edge had a long trail of oil, however the opposite edge was clean. Wiping the stick on a paper towel as shown in the above YouTube video confirmed oil level is right at full with a -50140 dipstick part number. Two more measurements made without probing and rotating showed oil level almost 1 cm high. Vehicle was cold and had not been driven for 2 days, which is very rare.
Old 08-03-2020, 05:38 PM #24
DougEFresh2 DougEFresh2 is offline
DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough
I have never actually used a grease gun before. So, I'll start there. I looked through so many forums about how often I should grease the drive shaft, and I kept seeing either every oil change or every other oil change. I also kept seeing that if the 4Runner is used around mud, dirt and water off-roading that it's a good thing to just grease it again because grease is more susceptible to the elements than oil is in the sealed system.
If you have a differing opinion and at least some reference for me to read backing up your claim, I would be more than happy to look at it and possibly make corrections. I'm constantly updating this when I find out more or better information. I have one more thing to update that I know about which is the socket size needed to re-torque the 19 transmission valve body
assembly bolts, for example.
Thank you!
2016 SR5, electronic dial actuated, part-time 4WD
2016-2019 service manual: https://www.toyota-4runner.org/5th-g...l-rm27f0u.html
DougEFresh2 is offline   Reply With QuoteReply With Quote
Old 08-27-2020, 08:52 AM #25
Davashcow Davashcow is offline
Davashcow is on a distinguished road
Super helpful thread for this new owner. Having the part numbers in one place is awesome. I swapped 4 new quarts of Toyota WS tranny fluid for some original fill and the difference is amazing!
Regarding the diff fluid: I’m a little torn regarding what to use as an alternative to the Toyota gear oil, which is ridiculously priced. It seems that two of the popular favorites (M1 75w90 and Redline) have LSD additives which I’ve found some recommendations AGAINST if you don’t have an actual LSD. Thoughts?
I did decide to pony up and buy the Toyota LF transfer oil. Pricey, but that’s an expensive component to shirk on.
Davashcow is offline   Reply With QuoteReply With Quote
Old 08-28-2020, 09:39 PM #26
Good question! Have a look at this website:
Red Line Synthetic Oil. 75W85 GL-5 Gear Oil
In the description, it states: "This product is not designed for use in most manual transmissions or transaxles with synchronizers, as extreme slipperiness may cause shifting problems"
On the bottom of the page, under "PRODUCT DETAILS", it states:
"Exceed API GL-5 specifications"
And under "OEM COMPATIBILITY", it states that it's compatible with:
"Toyota/Lexus 08885-02506".
This is referring to:
"Toyota Genuine Differential Gear Oil LT 75W-85 GL-5: Toyota part #: 0888502506"
As far as extra additives for LSD's, it does state:
"Contains additional friction modifiers for suitability with clutch-type limited slip differentials"
The word "additional" in this statement makes me think that it works for LSD's in ADDITION to what it was designed to do.
So, because it lists "Toyota/Lexus 08885-02506" and that it "Exceed API GL-5 specifications", personally, I feel confident using this. However, as stated at the very top of my post, I do mention that I'm not the most mechanically inclined person. I'm just doing the best that I can to do as much of my own maintenance as I can. Taking a 4Runner in to the dealership to JUST do an ATF CHANGE (not flush) I've been reading is between $350-400!!!
Anyway, I'm not guaranteeing anything, but I'm doing everything that I post to my own vehicle, if that gives you any comfort. Taking your 4Runner in for ALL the recommended service intervals..... you would end up spending what the car's worth after a decade! LOL. Screw that!
I hope this answers your question!
Old 09-02-2020, 03:22 PM #27
I changed my transfer case today with Toyota liquid gold 75w LF oil. I have just over .5 qt left (550 mL exactly) if anyone wants to grab it for free in Chapel Hill, NC.
Text 622-6141. Area code is original NC.
Old 12-08-2020, 06:58 PM #28
Ejrobin Ejrobin is offline
Ejrobin is on a distinguished road
Does this also cover the 2020 off-road?
Ejrobin is offline   Reply With QuoteReply With Quote
Old 12-08-2020, 07:12 PM #29
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
All trims are the same (except drive train for Limited)
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 12-12-2020, 10:25 AM #30
SpeedyKevin is mostly correct. Technically, this only covers 2016. However, there are only minor changes between each year of the 5th gen. Some examples that I'm aware of include the addition of the "Emission Control Valve Set" starting in 2013 that needs to be removed to replace the spark plugs (my spark plug guide I made covers this). Also, take a look at one image on the very bottom that lists all engines, transmissions and transfer cases used from 2010 - 2020. You'll notice that in 2020, the 4Runner no longer uses the electronic dial actuated transfer case for the part-time 4WD (VF2BM) anymore that they've used since 2013. Now they use one called the VF2CM.
I can't imagine it's wildly different from the old one, but the owner's manual should show how much fluid it uses, and really, the only thing I would personally like to know is whether or not the torque specs for the fill & drain plugs are the same.
Other than those 2 things, everything else SHOULD be the same as far as "basic maintenance" is concerned.
ft-lbs , oil , part , plug , toyota
Front/rear differential fluid, trans fluid and transfer case fluid change 88 Kel Varnsen Classic T4Rs 1 05-20-2012 03:26 AM
HID beginner help jillianj 4th Gen T4Rs 62 06-27-2011 12:26 PM
Maintenance: When do we change brake fluid, power steering, coolant Mabuse 4th Gen T4Rs 2 08-25-2009 05:02 PM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
Brake fluid maintenance Thai Maintenance/Detailing 4 06-02-2006 04:07 AM
