Thread Tools Rating: Thread Rating: 18 votes, 4.78 average. Display Modes
Old 12-12-2020, 06:01 PM #31
renau001 renau001 is offline
renau001 will become famous soon enough renau001 will become famous soon enough
thank you sir
2016 Trail Edition Premium w/ KDSS. LT265/70R17 BFG KO2s, Ceramic Pro, TSO pro grille, sliding cargo tray, WeatherTech floor liners, '10-'13 trail running boards.
Nobody cares about your vehicle as much you do. DIY Maintenance Quick Reference
renau001 is offline   Reply With QuoteReply With Quote
Old 12-12-2020, 10:22 PM #32
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Interesting when I google that new transfer case (VF2CM) there’s a discussion on Tacoma World similar to ours about the T/C fluid. Some people on there reported shifting issues using alternative fluids. I’d take that with a grain of salt but thought I’d report it. There’s also pdf about developing a thinner fluid to improve efficiency.
‘16-newer Transfer Cases | Tacoma World
Edits: Transfer Case!
1000MPH is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 06:30 PM #33
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Wink
Originally Posted by 4RMDNA View Post
Hi, I have a 2020 4Runner SR5 4WD. I did my oil change at 5500 a few days ago and I'm having issues with reading the oil level. The level keeps showing that it is overfilled (about 2-3 cm above the second dot). I've read online about how others are having issues as well. I used mobil 1 so it is very clear which doesn't help obviously. I put in the full 6.6 Qt after draining everything. Do you have any advice on what I should do to get an accurate reading? Should I drain some of it out? Thank you!
I did the same thing with my 2005. Had to get underneath and drain off a quart or so.
Important thing is to change every 5000 miles with right stuff. I like conventional. Tried synthetic. Just a waste of money IMO. Conventional is better IMO. 10,000 / 20000 mile oil changes and you get “mud” in your crank case!
Captsolo is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 07:04 PM #34
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
Originally Posted by Captsolo View Post
... Important thing is to change every 5000 miles with right stuff ... 10,000 / 20000 mile oil changes and you get “mud” in your crank case!
Your location, the Bahamas, should qualify as "severe service" or "special operating conditions" so, a shorter OCI is recommended. Perhaps you have had an oil analysis to help determine that 5000 miles is the limit under the conditions in which your vehicle operates? Short frequent trips? Slow stop and go traffic? Towing? Commercial use? Heavy vehicle load? High humidity? Salty air ... it all adds up to require frequent engine, transmission and gear oil changes.
DougR is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 08:58 PM #35
Just for reference, it is not difficult to get an accurate oil reading, even on these smooth dipsticks.
1) warm engine
2) shut off engine
3) remove dipstick promptly
4) wait 5 mins
5) insert dipstick slowly
6) wait 10 seconds
7) remove dipstick slowly
8) read level
I’m sure there are other ways, but I get a perfect, consistent reading this way every time with no splotchiness or creep up the sides that makes it hard to read. All the oil in the dipstick housing drains back down during the 5 minute wait.
Old 02-21-2021, 06:39 PM #36
@DougR have you done a brake fluid flush yet? I like the look of the brake bleeder bottle you linked to.
Old 02-21-2021, 08:48 PM #37
DougEFresh2 DougEFresh2 is offline
DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough
No. I bought the bottle, but it's sitting in the cabinet in my garage, atm. I'm only a couple hundred miles away from 50k, so, I'm going to be experiencing quite a few new procedures here very shortly. After I hit 50k, I'll be doing a transmission flush, brake bleed, steering fluid flush and maybe an A/C refresh, depending on how productive I'm feeling.
2016 SR5, electronic dial actuated, part-time 4WD
2016-2019 service manual: https://www.toyota-4runner.org/5th-g...l-rm27f0u.html
DougEFresh2 is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 09:36 PM #38
DougR's Avatar
DougR's Avatar
I'm DougR ... YES, the brake bleeder bottle worked very well. I easily flushed all the brake fluid.
Old 02-23-2021, 06:40 PM #39
LOL ooops!
Old 02-23-2021, 09:02 PM #40
TravelingTaco TravelingTaco is offline
TravelingTaco is on a distinguished road
Amazing thread! Thank you
TravelingTaco is offline   Reply With QuoteReply With Quote
Old 05-12-2021, 08:13 AM #41
007Tacoma's Avatar
007Tacoma 007Tacoma is offline
Real Name: Mark the Common Sense Wizard
007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice
007Tacoma's Avatar
Talking Excellent Reference all in one post!!!
So, this is my new favorite quick reference guide... I may actually print it, laminate it, and stick it to the side of my tool box in the garage.
Question (If you can fit it)... Could you include a pic of the serpentine belt route in that post? This particular one is courtesy of @1000MPH in this post
Originally Posted by DougEFresh2 View Post
Engine:
Designation: 1GR-FE
Fluid Change Interval (motor oil): 7,500 miles / every year – whichever comes first
* for hard use: 5,000 miles / every 6 months – whichever comes first
Classification (Engine Oil): SAE 0W-20 (U.S.); SAE 0W-20 -or- SAE 5W-20 (Canada)
Toyota Fluid (Engine Oil): Toyota part #: 002790WQTE01
Preferred Fluid (Engine Oil): Mobil 1 0W-20 Advanced Fuel Economy Full Synthetic
Capacity: 6.6 quarts
Fuel Tank Capacity: 23 gallons
Lowest Octane gasoline allowed: 87 (You must only use unleaded gasoline)
Highest Ethanol percentage allowed: 15% (E15)
Oil Filler Cap: Toyota part #: 1218031020 (hand tight)
Oil Filler Cap Gasket: Toyota part #: 9043037004
Oil Pan Drain Plug: Toyota part #: 9034112012 (thread size: M12-1.25) (socket size: 14mm; torque: 30 ft·lbf)
Oil Pan Drain Plug Gasket: Toyota part #: 9043012031
Oil Filter Cap Assembly: Toyota part #: 1565038020 (18 ft·lbf)
* Use the Motivx Tools Oil Filter Wrench for Toyota, Lexus, and Scion 2.0 To 5.7 Liter Engines with 64mm
Cartridge Style Oil Filter System for the Oil Filter Cap Assembly.
Oil Filter Element: Toyota part #: 04152YZZA5
Oil Filter Cap O-Ring (big): Toyota part #: 9030179006
Oil Filter Cap O-Ring (small): Toyota part #: 9672335028
Oil Filter Drain Plug: Toyota part #: 1564331050 (drive size: 3/8"; torque: 10 ft·lbf)
(5) Front Bumper Cover Lower bolts: Toyota part #: 9010906330 (socket size: 10mm; torque: 71 INCH-lbs)
(10) Under Cover Assembly/Sub & Seal bolts: Toyota part #: 9008011373 (socket size: 12mm; torque: 21 ft·lbf)
Drive / Serpentine Belt: Toyota part #: 90916A2015 / Bando 7PK2150
Oil Change Guide
I'm 007Tacoma.
...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
007Tacoma is offline   Reply With QuoteReply With Quote
Old 05-13-2021, 12:11 AM #42
Talking
Thank you! I added that pic you included after I confirmed it was the same orientation as the one from the service manual. It makes me feel really accomplished when I hear feedback like this!
I originally wanted this to be more simple, however, I just couldn't stop adding more and more info to it. Hahahaha and ya, I keep a copy of the info list in my car so if I need to stop at a Toyota dealership, I don't have to have a 20 minute conversation with the parts department! lol
Old 05-15-2021, 10:12 PM #43
HEAVY WT HEAVY WT is offline
HEAVY WT is on a distinguished road
I find the transmission part interesting since it says we have "Sealed" transmissions. I have heard people say they start changes after 100,000m. What have people done with this. I have also see there is a difference between fluid change and fluid flush.
2016 TEP w/KDSS, camelback roof rack, gobi ladder, C4 Fab sliders, KO2s.
2006 S2000
HEAVY WT is offline   Reply With QuoteReply With Quote
Old 05-15-2021, 10:32 PM #44
1000MPH's Avatar
1000MPH's Avatar
There are a lot of opinions out there. You can spend a lot of time reading threads here, tundra and taco sites, BITOG, youtube, etc.
I would say most people start to do drain and fills between 60k-120k.
The range of maintenance goes from a simple single drain n fill to a complete “flush” with pan drop and filter screen replacement.
Use your judgment based on whatever you choose is valid info.
My truck has had a pretty easy life but quite a bit of light off-road. I changed mine for the first time at 100k+.
I think after seeing the fluid and additional research I would start at 60k and do one or two drain n fills every 30k-45k.
Old 05-15-2021, 10:46 PM #45
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
It is sealed in the sense that there is no dipstick so no "easy" way to change the fluid like older non-sealed transmissions. But in reality isn't actually sealed as it has a drain plug and a fill plug.
I did a transmission fluid change on my previous FJ Cruiser (same engine & transmission). I used the method of disconnecting the return line from the radiator to pump out 2 quarts at a time. There is a procedure for filling it to the correct level at the proper operating temperature. Overall I thought the job was surprisingly easy. More steps than an engine oil change but about the same level of difficulty.
As for change versus flush, I think by flush they mean using a machine that flushes out the old fluid under pressure. I have always heard that is a bad way to do it. A change I think means replacing the fluid using at most the transmission's own pumping action, or just draining and replacing the fluid in the pan. The method I used with my FJC just uses the transmission pump. Some shops will have fluid swap machines that operate by the same method.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
ft-lbs , oil , part , plug , toyota
Front/rear differential fluid, trans fluid and transfer case fluid change 88 Kel Varnsen Classic T4Rs 1 05-20-2012 03:26 AM
HID beginner help jillianj 4th Gen T4Rs 62 06-27-2011 12:26 PM
Maintenance: When do we change brake fluid, power steering, coolant Mabuse 4th Gen T4Rs 2 08-25-2009 05:02 PM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
Brake fluid maintenance Thai Maintenance/Detailing 4 06-02-2006 04:07 AM
