Thread Tools Rating: Thread Rating: 18 votes, 4.78 average. Display Modes
Old 05-16-2021, 02:02 PM #46
DougEFresh2 DougEFresh2 is offline
DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough
Wink ATF Interval Overview
Originally Posted by HEAVY WT View Post
I find the transmission part interesting since it says we have "Sealed" transmissions. I have heard people say they start changes after 100,000m. What have people done with this. I have also see there is a difference between fluid change and fluid flush.
So for starters, this isn't a "this is what you should do" guide, it's a "this is what I do" guide. The 2016 Toyota 4Runner Warranty and Maintenance Guide says to "Replace automatic transmission fluid" every 60,000 miles under "Special Operating Conditions". I have never seen any other official interval of changing the ATF from Toyota for a 5th gen 4Runner. With that said, most vehicle manufacturers are constantly trying to improve their "cost of ownership" number so they can brag that their vehicles are "cheaper to own". One of the biggest methods they use is to increase the intervals of replacing fluids. Toyota even says that you can wait to change your motor oil every 10,000 miles..... LOL. Don't do this. I replace mine every 7,500 and it STILL comes out the color of tar.
Anyway, back to the transmission. Vehicle manufacturers will put a warranty on transmissions, basically based on how long the transmission will reliably operate before the fluid needs to be replaced. The problem with using this number yourself can be answered with two points:
1) The damage to a transmission from old fluid usually happens long before there are symptoms of the transmission failing. Think about smoking cigarettes for 10 years. You might not notice any health problems for the first 10 years of smoking! But does that mean that you can smoke for 10 years and you'll be just as healthy as someone who never smoked? Of course not.
2) After the warranty for a transmission expires, any damage that was not diagnosed and caught during the valid period of the warranty is now YOUR problem. But don't worry, Toyota will gladly charge you $7,500 for a new transmission plus $4,000 in labor! HAHAHAHAHAHAHAHA
Chances are, if you wait 100,000+ miles to touch your ATF, your transmission is already (to some degree) damaged.
I hope this answered all of your questions.
2016 SR5, electronic dial actuated, part-time 4WD
2016-2019 service manual: https://www.toyota-4runner.org/5th-g...l-rm27f0u.html
DougEFresh2 is offline   Reply With QuoteReply With Quote
Old 07-02-2021, 08:38 AM #47
Rpede Rpede is offline
Rpede is on a distinguished road
So why happens if you forgot to do this?:
“CAUTION: After removing old filter, but before installing new filter, re-torque the 19 transmission valve body assembly bolts!”
Rpede is offline   Reply With QuoteReply With Quote
Old 07-03-2021, 01:03 PM #48
Very, very high chance that nothing will happen. I tried torquing mine, but not a single one was loose. This step is more for peace of mind. If these bolts get loose, then the transmission just won't perform quite as well.
If you didn't tighten these, I wouldn't worry about it, personally.
The biggest reason I included this step is for completeness.
Old 07-05-2021, 11:09 PM #49
Thank you so much for responding. Your post has been so valuable to us DIYers! Much appreciated.
Old 07-06-2021, 08:13 PM #50
seatia seatia is offline
seatia will become famous soon enough seatia will become famous soon enough
Originally Posted by DougEFresh2 View Post
What is this thread about:
This thread is for beginners......
Great Post
Great references
Something came up on my oil filter order that everyone should be aware of.
I ordered the correct oil filter from Amazon and upon checking the actual filter inside the box it was not correct, but the filter that is roughly 1/2" shorter.
So that is going to be returned to Trader Joes.
I ended up ordering the correct YZZA5 for pickup from a Toyota dealer for half of that price, pleasant surprise.
So always double check in the box.
seatia is offline   Reply With QuoteReply With Quote
Old 07-07-2021, 12:47 PM #51
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Originally Posted by seatia View Post
Great Post
Great references
There have been numerous reports of counterfeit oil filters, spark plugs, air filters, etc. Maybe you got one.
These items are best acquired directly from a Toyota dealer. Either local or online dealers.
Old 07-08-2021, 06:29 AM #52
Jerry101 Jerry101 is offline
Jerry101 is on a distinguished road
Wow, thanks. I can imagine the work you did. A not in one night job.
You use the word "flush" in, seemingly, - or possibly different ways. The full service station flush, with a dedicated machine, is recommended against by (as he was referenced) Scotty Kilmer. He shows how one can get a 2 -3 quart drain and refill done, with a small handheld pump.
It is possible that flush was used by you as your own flush, rather than the machine flush at a service station.
In any event, what a helpful compendium of data. Thanks, again. Jerry
Jerry101 is offline   Reply With QuoteReply With Quote
Old 07-08-2021, 07:26 PM #53
Ohhh ya, when I get time I will go back and edit it this to either say "D.I.Y. Flush" or "Fluid Exchange". I also agree with you in being against getting a machine flush from a garage or dealership.
Thanks for the catch!
Old 07-09-2021, 12:25 AM #54
And, again, thanks for all your good work. Jerry
Old 07-21-2021, 01:45 AM #55
kymira13 kymira13 is offline
kymira13 is on a distinguished road
Bravo! Great post sir!
17 Cement Grey TRD Pro
kymira13 is offline   Reply With QuoteReply With Quote
Old 07-21-2021, 10:31 AM #56
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
I change the oil every 10,000 miles using synthetic and it comes out clear, only slightly darker than the new oil. 2014 SR5 with 265K miles.
I just flushed the transmission using Valvoline Max Life Synthetic, which is what I used the last time. The old fluid had been in 140K miles and I could not see much difference in clarity versus the new. In contrast, when I did the first flush of the Toyota ATF, that stuff was obviously darker than the new fluid going in.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 08-06-2021, 01:05 PM #57
NRath NRath is offline
NRath is on a distinguished road
[QUOTE=DougEFresh2;3474584]
Drive Shaft:
Fluid Change Interval: 15,000 miles / every year – whichever comes first
* for hard use (towing/loading): 7,500 miles / 6 months – whichever comes first;
*deep mud/water: As soon as you get back from off-roading.
Toyota Fluid: N/A
Preferred Fluid: (listed below)
Spider Grease: Classification: Lithium base chassis grease, NLGI No. 2
(Preferred: Lucas Oil Red 'N' Tacky #2 (10005))
(Good Alternative: Mobil 1 Synthetic Grease (105527))
Mad props, DougE. Your list is an excellent source for everyone, even those with years of experience turning wrenches. Finding all this information in one place is almost as good as having the FSM! Oh wait, you hooked us up with that, too!
Now I'm off to see if I'm missing with the "15k Driveshaft fluid change interval". I'm assuming this means add a little grease as with most other vehicles I've ever touched, but I'm not convinced I know what the latest tech may be.
Thanks again for all this work!
NRath is offline   Reply With QuoteReply With Quote
Old 09-14-2021, 10:15 AM #58
carlodonz's Avatar
carlodonz carlodonz is offline
Real Name: Carlo
carlodonz will become famous soon enough
carlodonz's Avatar
Real Name: Carlo
Thanks a lot for this document @DougEFresh2 !
I have a question on the front differential fluid check. The DIY video you linked is very helpful but I was wondering if it's recommended to change the plug gaskets like that person does? Or you listed the part number just in case? Thanks!!
2014 4Runner Trail Super White
carlodonz is offline   Reply With QuoteReply With Quote
Old 09-14-2021, 10:50 AM #59
That's a good question, I suppose I could have made that more clear. So basically, just because I have listed a part in this guide, does NOT mean that you have to replace it.
This might not be the best practice, but I have listed every part for all of the main components that are detached at any point during maintenance.
I have also listed parts in which the torque can be verified without too much trouble and any part that has a limited lifespan that's associated with one or more of the main maintenance components.
I feel this was a good decision because anything that is removed from the vehicle for maintenance has the chance of being damaged or getting lost.
As far as gaskets go, rubber gaskets, like O-rings can be reused one time as long as they're properly lubricated and changed at the recommended intervals, but the metal, crush washers should really be replaced any time that bolt and washer are removed.
Old 09-23-2021, 06:46 PM #60
spartacus's Avatar
spartacus's Avatar
@DougEFresh2 : I really appreciate your thread . Thanks.
ft-lbs , oil , part , plug , toyota
Front/rear differential fluid, trans fluid and transfer case fluid change 88 Kel Varnsen Classic T4Rs 1 05-20-2012 03:26 AM
HID beginner help jillianj 4th Gen T4Rs 62 06-27-2011 12:26 PM
Maintenance: When do we change brake fluid, power steering, coolant Mabuse 4th Gen T4Rs 2 08-25-2009 05:02 PM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
Brake fluid maintenance Thai Maintenance/Detailing 4 06-02-2006 04:07 AM
