Thread Tools Rating: Thread Rating: 18 votes, 4.78 average. Display Modes
Old 11-22-2021, 02:20 AM #61
U219742 U219742 is offline
U219742 is on a distinguished road
Thanks
thank you for this amazing thread. very helpful
U219742 is offline   Reply With QuoteReply With Quote
Old 11-29-2021, 05:57 AM #62
ColMntDad ColMntDad is offline
ColMntDad is on a distinguished road
Thanks for the guide. I have been using the dealer for all of my changes, up to now. My dealer is so booked that it’s almost half a month away for an appointment. I do all of my oil changes on my diesel, so not new to changing oil. Well that is what I.said before doing the 4Runner. I was able to get the oil out and everything looked good. That was until I came to the Oil filter housing. Was able to drain out the oil no problem but when it came time to remove the housing, that was a no go. I started using a cheater bar but decided to back off doing that on the plastic housing. I felt I was putting a lot of pressure on the breaker bar but nothing. I didn’t want to break the housing. If anyone has experienced a oversight housing, just how much have you had to crank on the housing to make it give? I truly believe the prior oil change tech over tightened the housing.
ColMntDad is offline   Reply With QuoteReply With Quote
Old 11-29-2021, 02:08 PM #63
DougEFresh2 DougEFresh2 is offline
DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough
Dealerships have almost always overtightened bolts and fittings when I used to take my vehicles in. My housing was very tight when I first did it on my 4Runner, however, I don't think it was as tight as yours is, based on your description.
What tool are you using to remove the oil filter housing?
I recommend using this: Motivx Tools MX2320
( Amazon.com: Motivx Tools MX2320-US 64.3mm 14 Flute Precision CNC Machined Aluminum Oil Filter Wrench Compatible with all Toyota and Lexus Cartridge Style Oil Filter Caps and Select Spin-On Filters : Automotive )
2016 SR5, electronic dial actuated, part-time 4WD
2016-2019 service manual: https://www.toyota-4runner.org/5th-g...l-rm27f0u.html
DougEFresh2 is offline   Reply With QuoteReply With Quote
Old 11-29-2021, 03:31 PM #64
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
I used an 18" cheater pipe on a 18" breaker bar with a 27 mm 1/2 inch drive socket on a Motiv oil filter wrench. I braced one foot against the inside of a front tire, held the breaker bar extension in my left hand, and steadily applied torque with my right hand until it broke free. I had a genuine Toyota metal oil filter housing on hand to replace the plastic one.
DougR is offline   Reply With QuoteReply With Quote
Old 11-29-2021, 09:18 PM #65
Thanks, I do have the Motiv MX2320 and a 64mm x 14 flute type with the slots. It is really tight.
Old 11-29-2021, 09:21 PM #66
Thanks for sharing your experience. I will give it a go again this weekend with a bigger bar. Having a spare on hand may be a good idea though. I will be doing the fluids from now on.
Old 11-30-2021, 11:42 PM #67
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
This is a common problem. When you finally get it off you might want to transition to the metal oil filter housing like so many have. If you break tabs on the plastic housing you can try loosening it with a plumber’s pipe wrench that has wide jaws. Good luck.
Old 05-11-2022, 11:52 PM #68
nimby's Avatar
nimby nimby is offline
nimby is a jewel in the rough nimby is a jewel in the rough nimby is a jewel in the rough
nimby's Avatar
Question about Transfer case oil.
The requirement is 75w and the alternative listed is Royal Purple Synchromax......which doesn't give a specific viscosity but says it's a "light viscosity fluid" best used as a replacement for manual transmissions that call for ATF.
Thoughts?
nimby is offline   Reply With QuoteReply With Quote
Old 05-12-2022, 12:52 AM #69
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
Thoughts?
I just replaced mine with amsoil 75/90 severe synthetic. Dealer didn't even have oe fluid available as they used bulk mobil 1 75/90. Same stuff they put in diffs.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 02-02-2023, 06:12 PM #70
CanmoreJim CanmoreJim is offline
CanmoreJim is on a distinguished road
EXCELLENT! Thanks much, jim
CanmoreJim is offline   Reply With QuoteReply With Quote
Old 08-04-2023, 11:13 PM #71
AFDL17 AFDL17 is offline
AFDL17 is on a distinguished road
Awesome post with tons of helpful information. Thank you!
Just a note: I think the rear diff fill and drain plug gasket part numbers may actually be 1215710010. That seems to be the part commonly sold for those applications, but I don't know where to look for a definitive answer.
AFDL17 is offline   Reply With QuoteReply With Quote
Old 08-05-2023, 11:30 PM #72
Red face
To find current part numbers, go here: Parts | Toyota Auto Parts
I've noticed that there are many parts that have their part number superseded. You might very well be correct. The part you listed, as an example, has a LOT of superseded part numbers, just go to the link below and search for "Supersessions".
Gasket; Plug | Part #1215710010 | Toyota Auto Parts
With all the part numbers I've listed in this guide, it would be a part-time job to update them all regularly.
Old 08-06-2023, 08:31 AM #73
Tcw1184 Tcw1184 is offline
Tcw1184 is on a distinguished road
Great reference. I get these are standard intervals, but 3 years on a cabin air filter is way too long. I change mine every 6-9 months. The high humidity combined with organic matter, pollen, and everything else trashes them quick. I’d recommend no more than a year of you care about your interior air quality.
23' 4R TRD Pro
Tcw1184 is offline   Reply With QuoteReply With Quote
Old 08-06-2023, 01:53 PM #74
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
I may be reading your comment wrong, but the differentials use a different oil than the transfer case.
08885-02506 For Diffs
08885-81080 For transfer case
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 08-09-2023, 01:32 AM #75
Do you have a link or reference for these part numbers?
This is what I have listed:
Transfer Case (Part-Time 4X4 w/ Electronic Dial):
Classification: SAE 75W
Toyota Fluid: Toyota SAE LF 75W: Toyota part #: 0888581080
Preferred Fluid: Royal Purple ROY01512 Synchromax synthetic
Alternative Fluid: Red Line MT-LV 70W/75W GL-4 Gear Oil
Front Differential:
Classification: LT 75W-85 GL-5 or equivalent
Toyota Fluid:
Toyota Genuine Differential Gear Oil LT 75W-85 GL-5: Toyota part #: 0888502506
Preferred Fluid: Red Line 50104 75W85 GL-5 Gear Oil
Rear Differential:
Toyota Fluid:
ft-lbs , oil , part , plug , toyota
Front/rear differential fluid, trans fluid and transfer case fluid change 88 Kel Varnsen Classic T4Rs 1 05-20-2012 03:26 AM
HID beginner help jillianj 4th Gen T4Rs 62 06-27-2011 12:26 PM
Maintenance: When do we change brake fluid, power steering, coolant Mabuse 4th Gen T4Rs 2 08-25-2009 05:02 PM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
Brake fluid maintenance Thai Maintenance/Detailing 4 06-02-2006 04:07 AM
