Old 04-18-2020, 05:15 PM #1
WISluggo WISluggo is offline
WISluggo is on a distinguished road
Help Wiring the DRL on Alpharex Nova on a 2020
The Novas are installed and are working really well, but I need help with the DRL. The 2020 has a different fuse box than previous years, and the fuse tap provided will not fit into the INJ fuse without distorting/cracking the lid on the fuse box.
One option was to use the EFI fuse, suggest by my mechanics, but interestingly that fuse is apparently powered, occasionally, when the truck is off. I know this because I will walk out to the garage and see the drls on a minute and then switch back off.
So, I am wondering what options I have, if any, aside from jamming the signal wire into the INJ fuse (i.e. not using a tap), or breaking the fuse box lid. What have other 2020 owners done?
WISluggo is offline   Reply With QuoteReply With Quote
Old 06-24-2020, 10:26 PM #2
welmr's Avatar
welmr welmr is offline
welmr is on a distinguished road
welmr's Avatar
I just installed mine and I’m having the same issue. The LED DRL’s only come on with the parking lights for me.. setting my headlights to DRL only turns on the regular DRLs.
welmr is offline   Reply With QuoteReply With Quote
Old 06-24-2020, 11:12 PM #3
mystiqueskillz mystiqueskillz is offline
mystiqueskillz is on a distinguished road
Comments on TRD Jon's Youtube, someone commented they used these for the DRL on their 2020.
Amazon.com: Gebildet 12V 24V Low Profile Add-a-Circuit Fuse Tap, ACS Miniature Piggy Back Blade Fuse Holder with Wire Harness, 6 pcs Fuse (3A 5A 7.5A 10A 15A 20A) and Fuse Puller (Pack of 4): Automotive
mystiqueskillz is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 12:23 AM #4
NB17Limited's Avatar
NB17Limited NB17Limited is offline
NB17Limited will become famous soon enough NB17Limited will become famous soon enough
Did you use the fuse tap or send any power from anywhere to the single wire on the bottom of the headlight assembly? You can't just plug all the headlight harnesses in and call it a day. These are not truly plug and play which kinda sucks.
NB17Limited is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 06:58 AM #5
Horizon Horizon is offline
Horizon is on a distinguished road
I used the inj fuse and warped the fuse box cover slightly to get it to fit on my 20 pro. A new cover is around 50 bucks so I was okay with this decision knowing I could replace it easily. The only other fuse I can think of is the one in the cabin for kdss (if you don’t have it) that would turn on with the ignition but you would have to go through the firewall. It’s worth it IMO for the DRLs and the tap. Hope that helps
Horizon is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 10:45 AM #6
welmr's Avatar
welmr's Avatar
Yeah I used the fuse tap and did connect the bottom wires.
Old 06-25-2020, 08:34 PM #7
TBTally TBTally is offline
TBTally is on a distinguished road
I just ordered a set of Luxx from Alpharex luxx series led projectors. I guess I will have the same issue. Sub'd for a solution.
TBTally is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 09:03 PM #8
Your post history suggests you have a 2019. I have the Luxx on our 2017 and do not have the issue that OP or the other guy have. Don't fret yet!
Old 06-25-2020, 09:04 PM #9
Is it a 2020? If not, can you post a pic or your fuse box with the tap?
Old 06-25-2020, 09:19 PM #10
Wink
Ahhhhhh thanks for letting me know that.
Old 06-26-2020, 04:27 PM #11
david05111 david05111 is offline
david05111 will become famous soon enough
I used a tap on the INJ fuse on my 2020 for my raptor lights. It doesn't allow the fuse box to completely seal, but if you can't live with it that way, just add some tape or something. It'll be fine.
The problem is really crying out for someone to come up with a new lid for that fuse box and put it on sale. If I knew anyone locally with the capability of getting that done, I'd be putting that together right now and getting ready to market them.
david05111 is offline   Reply With QuoteReply With Quote
Old 08-27-2020, 04:49 PM #12
Wolff_4Runner Wolff_4Runner is offline
Wolff_4Runner is on a distinguished road
I am running into a similar issue... it seems that all of the wiring accessories really like to tap in to the INJ ignition fuse which creates some issues when running multiple accessories...
Has anyone tried to splice into the DRL power cable harness running to one of the headlights?
I will be attempting to splice into the existing wiring that is running to the stock DRL on the drivers side. I believe there are two sets of colored wires (once for the turn signal and another from the DRL relay) - and if you can find the power wire I think you should be able to T splice in and have it working... but I have not confirmed.
Wolff_4Runner is offline   Reply With QuoteReply With Quote
Old 08-27-2020, 04:58 PM #13
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
Any circuit that goes hot when the ignition is switched on would work the same way.
Advantages to using the factory DRL circuit would be that they'd behave the same way as factory DRLs in any condition that cause the factory DRL to turn off.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 08-27-2020, 07:02 PM #14
I believe you will get flickering DRLs on the Alpharex. I have the wiring diagram printed out and in my stack of to dos but haven't gotten around to it yet. Our other car needed a transmission rebuild and has been taking my free time. Anyway, I think you'll need a capacitor to keep them from flickering.
Old 08-28-2020, 11:54 PM #15
volfan615 volfan615 is offline
volfan615 is on a distinguished road
Not sure why the aftermarket manufacturers haven't figured this out. This is much preferable than the DRLs just being on all the time.
volfan615 is offline   Reply With QuoteReply With Quote
box , fuse , inj , lid , tap
*Review* Alpharex Pro headlights CharlesNellis 5th gen T4Rs 99 05-13-2021 11:00 AM
AlphaRex Nova series headlights MillerPKA 5th gen T4Rs 53 02-11-2021 05:50 PM
Wiring harness for 2020 TRD ORP to Kicker Key DSP Amp 4xColt 5th gen T4Rs 4 04-07-2020 07:02 PM
Alpharex Nova Price? WISluggo 5th gen T4Rs 0 03-30-2020 08:32 PM
WTB Alpharex Pro with HID WISluggo Want to Buy/Trade 0 02-28-2020 11:30 PM
