Old 12-03-2020, 09:52 PM #196
RedRunner_87's Avatar
RedRunner_87 RedRunner_87 is offline
RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light
Originally Posted by Big Daddy K View Post
I started adding up what I had, using just the mfr website weights it was 455# which does not include my leveling platform molle panels and all the stuff so I'd say another 100#. The rear bumper weight may or may not include the spare tire mount and I'm not sure the difference between the stock spare wheel/tire and full size E-rated spare. Suffice it to say at trail ready load I'm probably well into the 600 pound range. The weight adds up crazy fast. I leave my hi-lift and spare fuel off for my daily commutes.
I may have to chat with some of the reps to see what I really need. "Need" lol it's not like what I have doesn't work, it just could be better.
You might need the heavier duty Constant Weight springs in the rear. Their chat is super helpful
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
RedRunner_87 is offline   Reply With QuoteReply With Quote
Old 12-12-2020, 10:54 AM #197
ragin_cajun ragin_cajun is offline
ragin_cajun will become famous soon enough
Originally Posted by RedRunner_87 View Post
Awesome! Anxiously waiting for your verdict!
I got the rear done last Sunday. Heaters are on in the garage, planning on knocking the front out today and getting the new rubber landed on the floor.
ragin_cajun is offline   Reply With QuoteReply With Quote
Old 12-13-2020, 10:21 AM #198
Making good progress!
5th Gen Build
Old 12-21-2020, 04:27 PM #199
Just picked it up from the alignment. So far the ride is good, but I've only put about 25 miles on it. It is sitting MUCH higher than I expected in the front with the 3" 0-110 LB springs. The rear lift is pretty close to what I was expecting.
The caster alignment came out much lower than I expected with the UCA's. I believe the Ironman UCA's are supposed to have 4 degree of caster correction. Handles well and the steering is solid, getting some vibration between 65-70 MPH though.
2.4 Deg Left Front / 2.9 Deg Right Front
Shop said they couldn't get it higher than this while keeping everything else within range.
ETA - Spoke to Ironman this afternoon. They think my front's are too high with a stock bumper etc... I installed them as they were set and from what I can tell I need to pull a solid 1" - 1.5" of lift out of the front.
Old 12-22-2020, 11:48 AM #200
Did yours settle at all? Mine went from 23.5" to 22.5" after a week or so. My rear hardly settled at all. Here are my numbers, the tech said it aligned great!
Untitled by redrunner87, on Flickr
5th Gen Build
Old 12-22-2020, 12:32 PM #201
@RedRunner_87 so far I'm sitting at ~24.5"
How many miles did it take for yours to settle?
Old 12-22-2020, 01:35 PM #202
Oh dang that is sitting pretty high! I thought about cranking mine up to 23", but I am going to wait till I figure out if I am going to do anything bumper/winch wise. I think I put about 200 miles on it between measurements. I think it was about a week or two.
I set my at what Ironman said to set it at, since I didn't get mine assembled. We set the driver side 1/4" higher and it sits level. We measured like 5 times before we assembled the front set up lol
5th Gen Build
Old 12-22-2020, 04:34 PM #203
Crazy thing is I measured mine before I put them on. They were sat a 8.5" as the spring chart said. I'm clueless as to why I'm sitting that high. I'm going to back them down tomorrow and then see where it settles.
ETA: I'm an idiot - After I pulled the coilovers and remeasured I was over 9". Somehow I didn't pay attention when I measured the first time around.
Old 12-22-2020, 05:02 PM #204
That is where I have mine set at. I believe it was supposed to be measured from the center of the eyelet?
5th Gen Build
Old 01-01-2021, 06:19 PM #205
toyzoku toyzoku is offline
toyzoku is on a distinguished road
Not sure. You can try it though. Coupon code:THE-IRONMAN-CALVARY
Dang that code expired yesterday!
2000 4Runner 5spd w/new v6, 1st gen TRD Supercharger, URD 7th, 2.2" pulley, Champion 3Core Aluminum Rad, 170amp CS144 Alt, MeanGreen Starter, Doug Thorley Headers, PLX MultiGauge Pod w/AFR/EGT/Boost+ECU, 3" Toytec Ultimate Lift Kit, 4.56 gears w/e-locker, MC HD Clutch, aFe Pro Dry S Cold Air Intake, Sonoran Steel Braided Stainless Rear Brake Line / Parking Brake Cable Bracket and Adjustable Tracbar, WeatherTech Floor Liner, Surco Safari Rack, Stubbs HD-SKO Sliders, CBI Rear Bumper w/swing out, 5 TRD Pro wheels w/BFG KO2 285/70/17, Tundra 231mm Big Brake Kit, Spidertrax 1.5" Spacers
toyzoku is offline   Reply With QuoteReply With Quote
Old 01-01-2021, 06:53 PM #206
Dang that sucks! It seems like their codes come and go. Might want to try hitting up their chat and see if they have any codes going on.
5th Gen Build
Old 01-01-2021, 07:02 PM #207
I just did about something else, when they respond I’ll work that in but I think I’m gonna wait for a sale as well. That 20%+15% you had was a crazy good deal!
Old 01-02-2021, 12:30 AM #208
That made it a no brainer to jump on. Couldn't pass that up at all.
5th Gen Build
Old 01-02-2021, 09:27 PM #209
Metal Tip's Avatar
Metal Tip Metal Tip is offline
Metal Tip is on a distinguished road
Metal Tip's Avatar
Just read all 208 post. I have 5160 on hand, but waiting for the 6112s to come in since they are on back order. I am considering canceling my order and just get the ironman 4x4 set up. Somebody mentioned that they had vibrations at 65 70 mph, anybody else experiencing vibrations at higher speeds.
Sent from my SM-G973U using Tapatalk
Metal Tip is offline   Reply With QuoteReply With Quote
Old 01-03-2021, 01:37 AM #210
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
No vibe issues on mine. I had a small vibe at 60 +/-5 mph with the stock suspension when I was running 265/70R17 LT C duratracs, but was fixed temporarily by tire rotation. New tires (287/50R17 LT C Toyo AT 3s) and IFC suspension and no more vibe.
Vibration in general isn't primarily a shock/spring problem, but more an input/imbalance issue. The shock/spring are there to control the input/imbalance. A vibration that isn't being damped by the suspension may be a suspension problem, but if it is being damped then it's not necessarily a suspension problem.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
cell , foam , oil , pro , shock
Ironman 4x4 Lift r3apingcha0s 5th gen T4Rs 32 03-26-2021 12:09 AM
FS: 4th Gen from 06 Seat Foam Base $50 Seat Foam Bk $40 Sd Airbag $50 Portland, OR bamma For Sale: T4R Items 4 06-20-2015 03:07 PM
Ironman m(a)ce 5th gen T4Rs 1 01-06-2014 11:11 PM
Ironman 4x4... FatTiresRollin 5th gen T4Rs 6 06-02-2013 09:14 AM
OME vs. IRONMAN 4X4 Fjatheart 3rd gen T4Rs 1 09-05-2012 10:35 AM
