Old 06-12-2020, 02:13 PM #61
FishNerd FishNerd is offline
FishNerd is on a distinguished road
Originally Posted by Mike07SE View Post
These shocks are huuuge. And yes they are close, but have not had any contact issues. It is imperative that the rear FCP's are mounted with the correct orientation otherwise they will hit. As mentioned in my write-up, it's a very good idea to review the FCP install YouTube video that they do where it covers this topic.
Thanks! I appreciate it! I still definitely have still a lot to learn, before i pull the trigger suspension, just want to be sure i have all my bases covered before i make the leap.
Cheers!
FishNerd is offline   Reply With QuoteReply With Quote
Old 06-12-2020, 04:41 PM #62
Gonecamping's Avatar
Gonecamping Gonecamping is offline
Gonecamping will become famous soon enough
For those interested they are a STEAL right now...
Toyota 4Runner 2003+/Lexus GX470/GX460 Nitro Gas Suspension Kit - Stage 2
On sale for 1039, but use coupon code (THE-IRONMAN-CALVARY) and it drops to 883...
Wish I would have waited on buying 5100's cause I think this would be a much better suspension upgrade
Ironman Foam Cell Pro-ironman4x4stage2-jpg
Gonecamping is offline   Reply With QuoteReply With Quote
Old 06-12-2020, 05:11 PM #63
whoops... that's not the pro version
However, coupon code still works and brings the pro version down to ~1350.
Old 06-12-2020, 05:47 PM #64
RedRunner_87's Avatar
RedRunner_87 RedRunner_87 is offline
RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light
Got it back from alignment today. Here are the numbers and the recommended numbers from Ironman.
Untitled by redrunner87, on Flickr
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
RedRunner_87 is offline   Reply With QuoteReply With Quote
Old 06-14-2020, 12:21 PM #65
Here is some comparison pictures of stock vs Ironman
IMG_8699 by redrunner87, on Flickr
IMG_8711 by redrunner87, on Flickr
IMG_8705 by redrunner87, on Flickr
IMG_8702 by redrunner87, on Flickr
IMG_8715 by redrunner87, on Flickr
5th Gen Build
Old 06-15-2020, 12:16 AM #66
ElJefe's Avatar
ElJefe ElJefe is offline
Real Name: Jeff
ElJefe will become famous soon enough
ElJefe's Avatar
Real Name: Jeff
Why does the stage 2 pro come with the sway bar relocation brackets and the nitro stage 2 does not?
I'm leaning towards the nitro's since I will mostly be street and fire road driving.
2018 SR5 Premium | Dobinsons 3"/2" - F300/549 R325/705 | Dirt King Tube UCA | HIKEit Throttle Controller | Prinsu 3/4 Rack | Xenon Depot High Beams | Boslla B4 Series LED Low Beams | Lensun Hood Solar Panel | Rockpals Powerstation & Fridge
4Runner Mod Inspiration: https://trail4runner.com/
ElJefe is offline   Reply With QuoteReply With Quote
Old 06-15-2020, 12:50 AM #67
Run Forrest Run's Avatar
Run Forrest Run Run Forrest Run is offline
Run Forrest Run will become famous soon enough
I'm leaning towards the nitro's since I will most be street and fire road driving.
The Foam Cell Pro shocks are so large, the sway bar is relocated slightly forward to ensure there is no contact with the Shock body. The Nitro Shock is slightly larger than OEM, but does not require the additional clearance. Unless you are hard core off roading or want the adjustability of the Nitro front coil, I recommend Nitro’s.
2023 TRD OR, Lunar Rock
Run Forrest Run is offline   Reply With QuoteReply With Quote
Old 06-15-2020, 05:21 PM #68
I wanted the Foam Cell for when I am camping and have it weighted down in the back. We run a lot of forest roads at high(er) speeds so hopefully the FCP will keep the shocks cooler. But yes, it depends on use and all that. I don't hardcore off-road too much but do carry weight when camping.
5th Gen Build
Old 06-15-2020, 05:24 PM #69
Final numbers after a week: 3" up front and 3" Rear
Stock/Day of/Week Later
DF: 19.5"/23.5"/22.5"
DR: 21”/24 1/8"/24"
PF: 19.5"/23.5"/22.5"
PR: 21"/24 3/8"/24.25"
5th Gen Build
Old 06-24-2020, 01:48 PM #70
For those of you that have been running the Foam Cell Pro's anybody install them on Non-KDSS with aftermarket skid plates? I noticed on their site that a swaybar relocation kit is required, I was messaging with someone on the ironman site (the phone always goes to VM) and they mentioned that for Non-KDSS its a replacement bracket (only moves it forward not down) vs. the KDSS version which is a plate that is sandwiched between the existing bracket and frame. Can someone please confirm that this is the case?
If so, do you know far forward it is moves the swaybar? My concern is that the swaybar will make contact with the skid and I dont think i can add spacer to mine (Artec Belly Pan).
Thanks!
Old 06-24-2020, 05:19 PM #71
Thanks!
Do you want me to take a picture of the sway bar and factory skid plate? You can get an idea of how it sits.
5th Gen Build
Old 06-24-2020, 05:34 PM #72
Thank you so much that would be greatly appreciated!
Old 06-24-2020, 06:25 PM #73
I will take some this afternoon and post up in a bit.
5th Gen Build
Old 06-24-2020, 06:39 PM #74
Passenger side:
Driverside:
Mount:
5th Gen Build
Old 06-25-2020, 01:49 AM #75
THANK YOU!!! This is so helpful and greatly appreciated! It looks like it may just work, fingers crossed. Now hopefully they still have stock left.
Thanks again!
cell , foam , oil , pro , shock
Ironman 4x4 Lift r3apingcha0s 5th gen T4Rs 32 03-26-2021 12:09 AM
FS: 4th Gen from 06 Seat Foam Base $50 Seat Foam Bk $40 Sd Airbag $50 Portland, OR bamma For Sale: T4R Items 4 06-20-2015 03:07 PM
Ironman m(a)ce 5th gen T4Rs 1 01-06-2014 11:11 PM
Ironman 4x4... FatTiresRollin 5th gen T4Rs 6 06-02-2013 09:14 AM
OME vs. IRONMAN 4X4 Fjatheart 3rd gen T4Rs 1 09-05-2012 10:35 AM
