Old 07-01-2020, 05:16 PM #91
RedRunner_87's Avatar
RedRunner_87 RedRunner_87 is offline
RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light
Originally Posted by bmy1287 View Post
That one isn't working for me
Originally Posted by Jetboy View Post
Looks like it works on non-sale items now, but not suspension.
Dang that is a bummer! I used it on my suspension when it was 20% off.
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
RedRunner_87 is offline   Reply With QuoteReply With Quote
Old 07-02-2020, 07:59 AM #92
Dinosaur Overland's Avatar
Dinosaur Overland Dinosaur Overland is offline
Dinosaur Overland is on a distinguished road
I used it also to get my lift, I would call ask for Chris tell him you have CC in hand ready to buy if he will give you that discount.
Dinosaur Overland is offline   Reply With QuoteReply With Quote
Old 07-09-2020, 11:09 PM #93
Aboh329 Aboh329 is offline
Aboh329 is on a distinguished road
Anyone run different springs with the Ironman shocks? Like eibachs or dobinsons?
Aboh329 is offline   Reply With QuoteReply With Quote
Old 07-09-2020, 11:26 PM #94
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Why? Then you'd have to find a place to paint them lime green.
delloro is offline   Reply With QuoteReply With Quote
Old 07-10-2020, 12:33 PM #95
That’s one reason why I want to use different springs. But the main is because I only want a 1” rear lift. I’ve been seeing people are getting 2-3” rear lift with their kits.
Old 07-10-2020, 05:09 PM #96
Forgot to post this. Tested the flex out
5th Gen Build
Old 07-12-2020, 03:51 PM #97
TodiN's Avatar
TodiN TodiN is offline
Real Name: Todi
TodiN will become famous soon enough
TodiN's Avatar
Real Name: Todi
Powder coat issue on green TOYO65C KO220 springs
Has anyone installed the green front TOYO65C constant load (100-200 lb) springs?
Both of my springs came with a slight powder coat defect. Both small defects are almost in the same spot.
Ironman Foam Cell Pro-20200712_154207-jpg
2018 TRD OR
- SSO Full Rack; Ironman 4x4 Stage 3 Foam Cell Pro: Constant Load – front, Performance Load – rear; M.O.R.E. aluminum full set skid plates; Artec aluminum gas tank skid; RCI front filler skid plate; HetfyFab Low-Profile Banshee Bumper; ReszFab flat sliders; Smittybilt 98695 XRC 9.5K GEN3 Winch; Pedal Commander; ARB diff breather; Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Wildpeak AT3W LT285/70-17 E;
TodiN is offline   Reply With QuoteReply With Quote
Old 07-13-2020, 05:33 PM #98
I will check mine, but I don't think mine look like that.
5th Gen Build
Old 08-06-2020, 08:24 AM #99
TodiN's Avatar
Real Name: Todi
TodiN's Avatar
Real Name: Todi
I received the following response from Ironman, confirming my suspicion:
"Thank you for sending in the images of your coils. Not to worry, those are not defects. Coils are hung on large racks during the powder coating process. Once they are powder coated there are slight shadow marks left from the hangers. These marks are touched up with the same paint to complete the seal on the coils ensuring a long-lasting finish. Hope this helps!"
2018 TRD OR
Old 08-06-2020, 12:36 PM #100
datq1doe datq1doe is offline
datq1doe is on a distinguished road
Been following this thread for a while. Just took advantage of their summer sale and bought the stage 2 FCP. Should I consider an front diff drop kit with this lift as well? Also have you had any issues with the sway bar coming into contact with the front crossmembers after the relocation?
Insta: @appa_rnr
datq1doe is offline   Reply With QuoteReply With Quote
Old 08-06-2020, 12:44 PM #101
TodiN's Avatar
Real Name: Todi
TodiN's Avatar
Real Name: Todi
You should get a diff drop. I installed my FCP without installing the diff drop (I was too tired by the end of the day) and now I regret it, I have to get back under the truck.
With moving forward the sway bar, I have no issues (OEM setting will touch the front springs).
2018 TRD OR
Old 08-06-2020, 12:55 PM #102
Mike07SE's Avatar
Mike07SE Mike07SE is offline
Mike07SE will become famous soon enough
Mike07SE's Avatar
Never found the diff drop to be necessary in any of my lifts. Everyone has their 2 cents on this. If your axles simply do not bind after lift it's not worth the effort. For me save the money / headache of installing.
As for as the sway bar goes, my stage 2 came with the relocation brackets and caused interference with the front crossmembers. I took it off and again I personally have not had any issues.
SOLD2007 4Runner Sport Edition V6 4X4 - Natural White - Perf: Doug Thorley Long Tube Headers | 4.56 Gears ARB Front / TrueTrac Rear Off Road: Fr: Bilstein 6112 w/1/2" Toytec Spacer / Rr: MT ICON Long Travel | JBA UCAs | VTX Rogue 17x8.5 -10 | GY Duratrac 285/70R17 | Rear Diff Breather Mod | 1" Toytec Body Lift | Custom Cut Axle Joints ICE: Auto Pumpkin 10.1" Android | 3.5" Tweeter Mod Exterior: Quad Bi-Xenon HID Retrofit
2019 4Runner Limited 4x4 - MGM - Hers | Ironman4x4 FCP's & UCA | Fuel Rebel 20x9+1 | GY Duratrac 275/60R20 | Victory 4x4 FLRR
Mike07SE is offline   Reply With QuoteReply With Quote
Old 08-13-2020, 10:25 AM #103
BLUESTEEL91's Avatar
BLUESTEEL91 BLUESTEEL91 is offline
BLUESTEEL91 is on a distinguished road
New member/owner here. Have just received my stage 3 Ironman 4x4 foam cell kit. Waiting on a diff drop kit, wheels and tires so I can get it all aligned together.
Anyone have install videos or tips/issues that aren’t addressed in the paper instructions?
Thanks
BLUESTEEL91 is offline   Reply With QuoteReply With Quote
Old 08-13-2020, 01:33 PM #104
Dreaddy72 Dreaddy72 is offline
Dreaddy72 is on a distinguished road
Thanks
They have some really good youtube step by step instructions. Good luck. I got the nitro set up and absolutely love it.
Dreaddy72 is offline   Reply With QuoteReply With Quote
Old 08-13-2020, 01:57 PM #105
Bill Z's Avatar
Bill Z Bill Z is offline
Bill Z will become famous soon enough
Bill Z's Avatar
Thanks
Amazing OVERLAND Suspension Install Ironman 4x4 Stage 2 - Toyota 4Runner - YouTube
Good luck and reply back with your results. My Stage 2 kit should be arriving in a couple of weeks.
Bill Z is offline   Reply With QuoteReply With Quote
cell , foam , oil , pro , shock
Ironman 4x4 Lift r3apingcha0s 5th gen T4Rs 32 03-26-2021 12:09 AM
FS: 4th Gen from 06 Seat Foam Base $50 Seat Foam Bk $40 Sd Airbag $50 Portland, OR bamma For Sale: T4R Items 4 06-20-2015 03:07 PM
Ironman m(a)ce 5th gen T4Rs 1 01-06-2014 11:11 PM
Ironman 4x4... FatTiresRollin 5th gen T4Rs 6 06-02-2013 09:14 AM
OME vs. IRONMAN 4X4 Fjatheart 3rd gen T4Rs 1 09-05-2012 10:35 AM
