Old 08-13-2020, 04:35 PM #106
BLUESTEEL91's Avatar
BLUESTEEL91 BLUESTEEL91 is offline
BLUESTEEL91 is on a distinguished road
Originally Posted by Dreaddy72 View Post
They have some really good youtube step by step instructions. Good luck. I got the nitro set up and absolutely love it.
After doing more research and forum reading, I might actually hold off on the diff drop kit. Looks like the CVs might be in a good position without the drop kit.
BLUESTEEL91 is offline   Reply With QuoteReply With Quote
Old 08-13-2020, 04:39 PM #107
Dinosaur Overland's Avatar
Dinosaur Overland Dinosaur Overland is offline
Dinosaur Overland is on a distinguished road
I installed the stage 3 without a diff drop and don't see a need for one, but to each their own. Extremely happy with this kit
Dinosaur Overland is offline   Reply With QuoteReply With Quote
Old 08-13-2020, 04:51 PM #108
Originally Posted by Bill Z View Post
Amazing OVERLAND Suspension Install Ironman 4x4 Stage 2 - Toyota 4Runner - YouTube
Good luck and reply back with your results. My Stage 2 kit should be arriving in a couple of weeks.
Thanks and will do!
Old 08-13-2020, 06:48 PM #109
RedRunner_87's Avatar
RedRunner_87 RedRunner_87 is offline
RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light
I didn't install the drop either on mine.
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
RedRunner_87 is offline   Reply With QuoteReply With Quote
Old 08-16-2020, 09:52 PM #110
So just finished the install of the stage 3 foam cell kit on my 2019 TRD Off Road. Initial impressions are that I am very pleased and boy did this kit stand my 4runner up.
The measurements are below but essentially I got a ~3.5” lift in the front and a ~2.25” lift in the rear. This will settle after a little more driving as well as the additions of steel bumpers, skids and sliders.
The install was relatively easy but still took 7.5 hours for me and my buddy. The main hang up for us is that neither of us had 19mm wrenches, we had sockets but largely the combo wrenches (ratchet wrench preferably) were what we needed. Not a deal breaker but would’ve made things easier.
Test drive: Steering was a bit stiffer. My buddy has a bilstein lift and mentioned his felt the same. Can’t explain why but I believe this is normal. Less body sway around corners. This suspension is hefty and will take care of you on the road just as much off road.
I plan to take this on some actual trails and really get a good review and full impression of this set up. Next on the agenda are Method 701s and General Grabber X3s next week.
The below measurements are from the listed point to the fender. I took the measurements in the same spot both times and test drove it before measuring after the install.
Stock:
DF - from ground 34 3/8” PF - ground 34 3/4”
Hub 20” Hub 20.5”
DR - ground 36 7/8” PR - ground 37”
Hub 22 3/8” Hub 22.5”
Ironman 4x4:
DF - from ground 37 3/4” PF - ground 38”
Hub 23 3/4” Hub 24”
DR - ground 40” PR - ground 40”
Hub 25.5” Hub 25.5”
It appeared the suspension install leveled things out for me being off by only a 1/4” on the DF which will be fine tuned after I get my wheels, tires and alignment done.
Old 08-16-2020, 10:16 PM #111
Stock:
Hub 20” Hub 20.5”
Ironman 4x4:
Hub 23 3/4” Hub 24”
Hub 25.5” Hub 25.5”
Glad you are happy with it! Yours will definitely settle a bit after a week or so. Mine did and I started about where you were.
5th Gen Build
Old 08-18-2020, 09:33 AM #112
Where did yours end up settling?
Also, did you buy their adjustment tool or buy a spanner wrench? I chose the latter.
Old 08-18-2020, 11:08 AM #113
Bill Z's Avatar
Bill Z Bill Z is offline
Bill Z will become famous soon enough
Bill Z's Avatar
What size spanner wrench does it take?
Bill Z is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 11:21 AM #114
TodiN's Avatar
TodiN TodiN is offline
Real Name: Todi
TodiN will become famous soon enough
TodiN's Avatar
Real Name: Todi
The pin for the Ironman 4x4 tool is 7mm, what spanner wrench did you get?
2018 TRD OR
- SSO Full Rack; Ironman 4x4 Stage 3 Foam Cell Pro: Constant Load – front, Performance Load – rear; M.O.R.E. aluminum full set skid plates; Artec aluminum gas tank skid; RCI front filler skid plate; HetfyFab Low-Profile Banshee Bumper; ReszFab flat sliders; Smittybilt 98695 XRC 9.5K GEN3 Winch; Pedal Commander; ARB diff breather; Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Wildpeak AT3W LT285/70-17 E;
TodiN is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 12:33 PM #115
Well, I didn’t know the pin on the Ironman tool was 7mm. The spanner wrench I went with is 8mm. I ordered it from Amazon and I am currently waiting for delivery. I’ll let you know if the 8mm works.
Old 08-18-2020, 12:35 PM #116
Not 100% sure but I ordered an 8mm spanner wrench from Amazon so I’ll let you know if that works once I get it.
Old 08-18-2020, 01:10 PM #117
TodiN's Avatar
Real Name: Todi
TodiN's Avatar
Real Name: Todi
What item did you order, can you post the link?
2018 TRD OR
Old 08-18-2020, 01:20 PM #118
This is what I ordered.
Vmotor Chrome Vanadium Adjustable C Spanner Hook Wrench Tool - 2-4 3/4"(51-121mm) Vmotor Chrome Vanadium Adjustable C Spanner Hook Wrench Tool - 2-4 3/4"(51-121mm) - - Amazon.com
Old 08-18-2020, 01:28 PM #119
Bill Z's Avatar
Bill Z's Avatar
Thanks! Keep us posted on how it goes.
$79 for the Ironman tool (marked down from $129) seems a bit excessive....
Old 08-18-2020, 02:02 PM #120
TodiN's Avatar
Real Name: Todi
TodiN's Avatar
Real Name: Todi
Let me know if it fits. To lower my 4Runner I adjusted my springs over the weekend with the Ironman tool. I did have to use a pipe wrench for leverage as the tool is too short.
I wish the tool would have a square 1/2" hole for a breaker bar instead of 10mm and 11mm hex holes...
2018 TRD OR
cell , foam , oil , pro , shock
Ironman 4x4 Lift r3apingcha0s 5th gen T4Rs 32 03-26-2021 12:09 AM
FS: 4th Gen from 06 Seat Foam Base $50 Seat Foam Bk $40 Sd Airbag $50 Portland, OR bamma For Sale: T4R Items 4 06-20-2015 03:07 PM
Ironman m(a)ce 5th gen T4Rs 1 01-06-2014 11:11 PM
Ironman 4x4... FatTiresRollin 5th gen T4Rs 6 06-02-2013 09:14 AM
OME vs. IRONMAN 4X4 Fjatheart 3rd gen T4Rs 1 09-05-2012 10:35 AM
