Old 10-22-2020, 11:06 AM #166
dezertbomber dezertbomber is offline
dezertbomber is on a distinguished road
Looking to buy their 2" heavy springs, anyone have an updated code for just the single item? Thanks in advance.
dezertbomber is offline   Reply With QuoteReply With Quote
Old 10-22-2020, 12:37 PM #167
FYI was given a code from a chat sessions with them that works as of now: GOODBUDDY10
Old 10-22-2020, 06:37 PM #168
RedRunner_87's Avatar
RedRunner_87 RedRunner_87 is offline
RedRunner_87 is a jewel in the rough RedRunner_87 is a jewel in the rough RedRunner_87 is a jewel in the rough RedRunner_87 is a jewel in the rough
Thanks!
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
RedRunner_87 is offline   Reply With QuoteReply With Quote
Old 10-28-2020, 01:55 PM #169
1Louder 1Louder is offline
1Louder is on a distinguished road
Two Questions:
Question 1:
Does anyone have this setup with 32" in tires? If so a couple of photos would be helpful. I am trying to decide if I am going to go with 32" tires to maintain as much factory power or go for broke and go with 33" tires. My FJ had 33", I never re-geared and towing was problematic.
I just don't want to do the lift and have the tires look way undersized. I sure 31" will look small.
Question 2:
Has anyone adjusted the front coil overs to 1.75" height vs 2.5. I am fine with a bit of rake. 2.5 will level the truck.
Thanks!
Dispensing advice 24/7. Usually free and sometimes worthwhile!
1Louder is offline   Reply With QuoteReply With Quote
Old 10-28-2020, 03:12 PM #170
TodiN's Avatar
TodiN TodiN is offline
Real Name: Todi
TodiN is on a distinguished road
TodiN's Avatar
Real Name: Todi
Originally Posted by 1Louder View Post
Two Questions:
Question 1:
Question 2:
Thanks!
A1: I 285/70/17 which is about 33". Pic of my truck attached.
A2: I adjusted my Pro coils up and down. A lot of pictures here. Bottom line is you need to use the Ironman's wrench with some sort of leverage. I started with a pipe wrench but is way to heavy.. My 19" braking bar was not sufficient so I got a 25" long one. The Allen hex size is between 16mm and 17mm so I used a 16mm with some aluminum to make it fit properly.
Sent from my SM-N975U using Tapatalk
2018 TRD OR
- SSO Full Rack; REPLACED: FJ TRD Pro Kit with: Front - 1.25" Lift Poly Front Coil Preload Spacer Kit (DAY TA3273), Rear - Eibach E30-82-071-01-02 WITH Ironman 4x4 Stage 3 Foam Cell Pro: Constant Load front, Performance Load rear; M.O.R.E. aluminum full set skid plates; RCI front filler skid plate; HetfyFab Low-Profile Banshee Bumper; Smittybilt 98695 XRC 9.5K GEN3 Winch; Pedal Commander; ARB diff breather; on-board Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Wildpeak AT3W LT285/70-17 E; Removed Spidertrax wheel spacers
TodiN is offline   Reply With QuoteReply With Quote
Old 10-28-2020, 05:10 PM #171
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future
Jetboy's Avatar
Extra leverage is pretty common. I actually welded a 12" or so piece of steel tube to my spanner wrench for my Fox shocks. One thing that can help is a little bit of oil between the adjustment ring and the spring to help it slide. I also like to lube up the threads as much as I can with penetrating oils before I move them just to free everything up. Once they've been through a few years of wear, it'll only get harder to turn. The Ironman spanner looks pretty nice. The one Fox sends is a flimsy piece of shit.
Old 10-28-2020, 05:20 PM #172
Awesome reply. THANK YOU! My stage 1 kit has shipped.
Old 10-29-2020, 09:09 AM #173
Bundutrailer Bundutrailer is offline
Bundutrailer is on a distinguished road
Great hearing all the glowing reviews, very underrated
Bundutrailer is offline   Reply With QuoteReply With Quote
Old 10-30-2020, 08:04 AM #174
Dinosaur Overland's Avatar
Dinosaur Overland Dinosaur Overland is offline
Dinosaur Overland is on a distinguished road
Just got back from Rendezvous in the Ozark's about a 1600 mile trip and really like the way the Stage 3 suspension handles towing the trailer.
Ironman Foam Cell Pro-ffbdbec1-0711-4baf-bcb5-fd7ad7892d94_4_5005_c-jpeg
Dinosaur Overland is offline   Reply With QuoteReply With Quote
Old 10-30-2020, 02:18 PM #175
redshift83's Avatar
redshift83 redshift83 is offline
redshift83 is on a distinguished road
redshift83's Avatar
So, i'm basically ready to buy a suspension setup, was originally going to go with 6112s and 5100/5160s out back with a mild lift out back and maybe 2" up front. The FC stage 2 kit really seems like a good deal though with the UCAs and everything included. I have KDSS, stock tires, and small children though so i'm not looking for a huge lift right now. Is anyone running the rear shocks with springs that don't give a 2"+ lift? I'd still buy the kit and keep the taller ones for later on when i get the other things sorted, but i'd like the option to stay low for now.
I know i should probably just get some 5100s like my 3rd gen had and be happy, but where's the fun in that?
10 4Runner TE - stock for now
97 SR5 -Sold
91 Celica All-Trac - tons of mods
99 Miata #becauseracecar
redshift83 is offline   Reply With QuoteReply With Quote
Old 11-02-2020, 10:28 PM #176
No more "free traction boards" but the price of at least the Stage I kit dropped. Now $1199.
Old 11-04-2020, 10:44 AM #177
grizzlypath's Avatar
grizzlypath grizzlypath is offline
grizzlypath is on a distinguished road
I just installed the Ironman 4x4 Foam Cell Pro Stage 2 kit on my 2020 ORP with KDSS, works great! There's lots of good info on this forum so I probably won't post a DIY or anything, but if anyone searching through here has any questions feel free to PM me or something. Happy to help. Although tbh, it was quite straight forward.
grizzlypath is offline   Reply With QuoteReply With Quote
Old 11-04-2020, 10:50 AM #178
The install was pretty easy! 8K later I am still happy
5th Gen Build
Old 11-04-2020, 03:25 PM #179
Anyone used stock springs with the foamcells?
Old 11-04-2020, 03:50 PM #180
TodiN's Avatar
Real Name: Todi
TodiN's Avatar
Real Name: Todi
Looks you have quite a rear sag... What rear springs do you have?
2018 TRD OR
cell , foam , oil , pro , shock
Ironman 4x4 Lift r3apingcha0s 5th gen T4Rs 28 09-04-2020 09:34 PM
FS: 4th Gen from 06 Seat Foam Base $50 Seat Foam Bk $40 Sd Airbag $50 Portland, OR bamma For Sale: T4R Items 4 06-20-2015 03:07 PM
Ironman m(a)ce 5th gen T4Rs 1 01-06-2014 11:11 PM
Ironman 4x4... FatTiresRollin 5th gen T4Rs 6 06-02-2013 09:14 AM
OME vs. IRONMAN 4X4 Fjatheart 3rd gen T4Rs 1 09-05-2012 10:35 AM
