01-17-2021, 04:08 PM
#226
Originally Posted by MAST4R
1Louder,
I am curious about this setup in the SW in the first place.
It obviously relies on the springs to do the work. That should ensure long time between changes/rebuilds but this is the opposite of a desert performance setup.
Very interesting idea and many here say they love it so that's great, but does not tempt me here in AZ.
Well, you can get a smoother ride with an Icon Stage XXXXXXX, OME, King, Fox, I dunno. You can also enjoy pulling them off every 1-2 years to have them rebuilt. NO THANKS!
My basic OME Setup on my old FJ lasted over 130,000 miles. 7 years' worth of fun without having to replace them. Although about 6 months before I sold it I did buy some non-adjustable reservoir shocks with heavy-duty Icon springs.
I agree everything is a trade-off. KDSS is great on the road. I have not found any negatives offroad to date. With that said for me at least, it takes DIY replacements out of the question. That was a conscious choice that I decided to make when I bought the 4Runner
Dispensing advice 24/7. Usually free and sometimes worthwhile! @4xoa on the gram.
01-18-2021, 02:08 PM
#227
Real Name: Steve
Real Name: Steve
Picking lift option
Looking at the foam cell kits. Deciding between stage 2 and 3 for my 4th gen with 33"s. My LCAs are frozen and suspension is worn so was going to cut out the LCAs and do a full suspension upgrade. Going with the performance kit for weight, but any input on the lift size option? Will 3" on both front and rear keep the vehicle with only a slight forward rake? or mostly level? Just wondering how the vehicles are sitting. Was also considering a 2.5" front and 2" rear but worried it might settle weird. Any input helps, the tech just said do a stage 3 with 3" all around, but said they don't know how the vehicle would sit after. I also don't want to go 3" and be stressing out my CVs.
'06 Sport Edition V6 4WD, Titanium Silver | Kenda Klevers | K&N CAI, MagnaFlow | Bilstein 5100 + FJC Coils, ES Bushings |
Ro-Ro Build Thread
01-19-2021, 05:47 PM
#228
I did a 3" all the way around and I still have the factory rake just at 3" higher.
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
01-29-2021, 10:46 AM
#229
Originally Posted by generald
Huge thank you to all that came before me here and shared feedback.
I opted to convert from my spacer lift to a suspension lift and despite at-cost pricing for Kings and lots of Bilstein love, I opted for Ironman 4x4 given the value for my use case.
Use Case: Adventures-only 2016 Limited in/around Colorado with summer wheeling, winter ski trips, and Costco runs
Weight Notes: Constant fixed load of !420lbs for SSO Full Roof Rack, Full RCI skids (all of them) with aluminum options where available, RCI flat sliders with kickout, hidden winch mount + winch...and rarely +150lbs for Tepui RTT or a 16' dual console fishing boat.
Previous Setup: Went with a Daystar spacer lift on XREAS and loved the lift AND the company's service -- one of the best experiences out of any company I have ever reached out to. This setup addressed the nose diving from hard braking, gave some good height, but did limit suspension travel when offroad. I wish I did this on day one, not year three. I opted to do a diff drop as well (by Revtek)...jury is out on this but didn't seem to hurt and improved CV angles.
Ironman 4x4 Setup: Foam Cell Pro, Stage 3 with Front (prebuilt) 2.5" / Performance Springs and Rear 2" Performance Load Springs
Alignment: Just had a solid shop in Denver for an alignment and bumper to bumper check to ensure my DIY install went well...all came back okay. They suggested against Heim joints for the adjustable rear sway links due to noise...but it came with the kit and I don't have a problem with the noise. Here are my specs:
OEM UCA & XREAS (old dealer alignment) - Left-Front: Camber @ 0.5*, Caster @ 1.9*, Toe @ 0.46*
- Left-Rear: Camber @ -0.3*, Toe @ -0.08*
- Right-Front: Camber @ 0.6*, Caster @ 2.2*, Toe @ 0.5*
- Right-Rear: Camber @ -0.3*, Toe @ 0.08*
- Total Toe @ 0.96*, Steer Ahead -0.02*
OEM UCA with Daystar 2.5" Front/Rear Spacers on XREAS - Left-Front: Camber @ 0*, Caster @ 2.8*, Toe @ 0.04*
- Left-Rear: Camber @ -0.3*, Toe @ -0.1*
- Right-Front: Camber @ 0.1*, Caster @ 2.7*, Toe @ 0.05*
- Total Toe @ 0.09*, Steer Ahead 0*
Ironmen UCA with 2.5/2" FCP Stage 3 Lift - Left-Front: Camber @ 0*, Caster @ 3.4*, Toe @ 0.09*
- Left-Rear: Camber @ -0.4*, Toe @ -0.35*
- Right-Front: Camber @ 0*, Caster @ 3.6*, Toe @ 0.08*
- Right-Rear: Camber @ -0.3*, Toe @ 0.32*
- Total Toe @ 0.17*, Steer Ahead 0*
Actual Lift Height- XREAS Stock - Dont have them
- XREAS + Daystar - May have them, will look
- Ironman (+250lbs for mods pre sliders, winch): Left-Front @ 23.5", Right-Front @ 23.4375", Left-Rear @ 24.5", Right-Rear: 24.75"
- Ironman (+440lbs for all mods): Left-Front @ 22.87", Right-Front @ 23", Left-Rear @ 24.38", Right-Rear: 24.6"
Thoughts So Far- I am running FN F(X) Pro 17" wheels with Falken Wildpeak AT3/W LT(E) 265/70-17.
- When I purchased, Ironman had limited stock but I spoke with their customer service team and after going over my specs, seemed to be the right pick. Great team there!
- My RTT and 16' fishing boat use cases are rare and I feel airbags are the better option for me versus a much stiffer spring. It isn't tough or expensive to swap front or rear springs now that XREAS is gone should I change my mind.
- I am glad I waited to see if I needed the usual Toyota lean spacer...my current numbers are close enough but I did buy the adjustment wrench just in case (for the fronts).
- My 4Runner is no longer a daily driver. So if not on a Costco trip, she is off road or making a run to go skiing...so the truck-like ride is good. For what XREAS was, it's a superior on-road experience to any SUV/truck suspension I have driven in IF smaller/medium spacers are added to the wrong. The braking nose dive wasn't great, but cornering was unmatched.
- As with nearly every product I have purchased, instructions are hit or miss. Ironman would be mid-pack. They have a good install video on a GX for the stage 2 lift and there are a handful of install guides like Trail4Runner out there. With a bit of Googling, I found the correct panhard and rear sway link adjustments which were most elusive.
- I think I lost a set screw and will email Ironman...I don't expect any issues but also have no worry...they are extremely responsive and knowledgeable compared to some of the other manufacturers I have come across for Toyota and Chevy.
- I am at day 7 with 120ish miles on the clock...time will tell how things settle.
- I plan to add airbags after a RTT trip and a short boat tow to see if I really need them or can live with some sag.
Happy to answer any questions folks have, especially if you are doing the Stage 3 setup and need some pointers.
question:i have a 2016 4RN 2wd limited, wanted to level out with small lift do weekend adventures beach, mountains, light off road travel on lots of red dirt and gravel i recently purchased ironman's stage 2, 2.5" suspension kit Front Springs:
2.5" Lift Performance Load (0-110LBS Additional Payload)
Rear Springs:
2" Lift Performance Load (0-660LBS Additional Payload)
my question is i believe i have x-reas and will have to remove them to install the other , any advice ??? I have stock 245/60r20 and would like to go a little bigger with better terrain tire part of why I opted for the lift and i just dont like the low front ride, as well soft dirt and mud with what i have now there is no grip and spin... kind of a noobie any info will help and i have read lots as well as asked questions but cannot find exact thread for install on type and any issues with install or maybe a suggestions instead of .. thinking of cancel order since they are backorder anyway...
01-29-2021, 11:12 AM
#230
Rear Springs:
Sounds like you have the right setup. This will reduce rake a bit but also give you some height for larger tires (with a simple push mod to the front wheel lines). The Ironman Youtube channel has install guides or Trail4Runner ( Ironman 4X4 Foam Cell Pro 2/3” Lift Kit Stage 2: 5th Gen 4Runner Install) has a good step by step.
As long as you purchased them pre-assembled, should take you a day with some helping hands and only a few basic tools and an extended socket set.
Check out the guide above and happy to answer any follow ups.
[RIP] '00 Ford Ranger XLT
'16 LE: Metallic Gray; SSO Rack, FN (X) Pro Wheels, Falken AT3W Tires, ALL RCI (Aluminum) Skids, SDHW ABS Sensor Covers, Molle Rear Panels, ArcLight Red Light Mod, Ironman 4x4 FCP Stage 3 (2.5"/2"), RCI Sliders, BudBuilt Hidden Winch + Smittybuilt 10k WInch, AGM
Coming soon...lighting & Platstidip
01-29-2021, 06:09 PM
#231
Hello, I'm considering the Ironman Foamcell kit. Was thinking of doing the 2" so I didn't have to do UCAs and a differential drop. Your truck looks great! What size lift did you buy from ironman and what size tires are on the SR5 wheels. I just put new 275s on my SR5 wheels and I like how they look. Thanks!
2015 SR5 Premium with 3rd Row, N-Fab Nerf Bars, TRD wheels, Weathertech Digifits
01-29-2021, 10:15 PM
#232
I am running 255/80(33x10) on my SR5 wheels. I didnt do the diff drop on my 3" kit.
5th Gen Build
03-14-2021, 03:03 PM
#233
GREEN25 Discount code through 3.17.21
Hi, all. Thanks for the excellent details, install links, etc. I places order and the code GREEN25 (Through 3.17.21) got me $599 off on Pro Performance Stage 2 kit. $1799 delivered is a smoking deal and free TREDs boards included. Was looking at Icon Stage 2 and this seems very comparable kit for less.
03-14-2021, 03:38 PM
#234
I am glad they are continuing with their killer deals. I have their green TREDs too, haven't used them yet lol
5th Gen Build
03-22-2021, 09:20 AM
#235
Real Name: B-Money
Real Name: B-Money
I missed the 25% off code by a few days. Any chance we’ll extend this???
Anger Fuels Motion...Motion Fuels Momentum...Momentum Fuels Action...DO SOMETHING!
2010 4Runner SR5
03-22-2021, 10:18 AM
#236
If you sign-up for email updates on their website, they'll let you know when the next sale will hit. My guess would be somewhere around Memorial Day or 4th of July.
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front (coil seats lowered 1/2"), IMS59-50705 & C59-505 rear; Dobinsons diff drop; Ironman UCAs; Eimkeith PCK, Ironman adjustable panhard rod, and Treaty Oak KDSS spacers; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders; Durobumps front & rear.
03-22-2021, 12:29 PM
#237
Real Name: B-Money
Real Name: B-Money
Thanks! I’ll do that.
2010 4Runner SR5
03-26-2021, 12:14 AM
#238
The coupon code SPRING15 takes 15 percent off an order until April 15.
Think that’ll be as good as it gets or is there a chance another 25 percent off sale is coming up soon?
2021 MGM TRD Off Road - Ironman4x4 Stage 2 2.5”/1” Nitro Gas lift - P265/70/17 Falken Wildpeak AT3W’s - Bronze TRD Pro wheels - TRD front skid plate - TRD rock rails
05-09-2021, 10:53 AM
#239
Spring25
25%
05-10-2021, 05:07 PM
#240
Originally Posted by 4RNEWBIE
Spring25
25%
You're the man
5th Gen Build
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
