09-06-2023, 12:12 AM
#301
Originally Posted by GT0neX
I just got a recall letter for the UCAs. Sounds like they will cover the cost for parts and labor. Bummer.
Sent from my SM-N975U1 using Tapatalk
Also if you read the letter it states that they will be sending out new replacement upper control arms, not just ball joints. Hopefully their timeline of October holds true.
09-06-2023, 04:27 PM
#302
For those of you moving away from this junk - what are you going with?
I need to replace everything. Have had shock issues, coil issues, and now the UCA. I'm done and ready to rip it all out. Just unsure of what I'm going to go with and who's UCA.
09-06-2023, 05:22 PM
#303
Why are the UCA’s junk? I’ve had no issues with mine and actually think they are really well made. I also believe, per the recall letter, that they are sending out entire new UCA’s once they get them back in stock.
09-06-2023, 05:33 PM
#304
I'm curious whether or not there is a general consensus on the quality of Ironman FCP suspension. I have NOT read this entire thread but all of my research seems to indicate that they are well made and reliable for the vast majority of users. The recall is concerning but it sounds like they are redesigning the UCA and using a different ball joint to correct the issue AND taking care of all existing customers in the process. My local 4X4 shop highly recommends them as well, which is why I chose to go with them over the Bilsteins (and they seem to better suit my onroad/offroad usage). Are there wide complaints about the longevity or quality of their stuff because everything I have read is that they are robust and easy to rebuild...???
09-06-2023, 09:14 PM
#305
I am at 3 years and 35k miles on mine. I have replaced 3/4 shocks due to leaking. 1 front and 2 rears.
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
09-06-2023, 09:44 PM
#306
Ironman
I’ve had the exact same experience with my prior Eibachs with similar mileage and moved to the Ironman and pleased thus far. It’s early in this relationship but I like the fundamentals and load handling so far that are way beyond what my prior setup could do.
09-06-2023, 10:01 PM
#307
I will say ride handling and customer service has been excellent. I have no complaints there. But disappointed in the leaks. I am hoping that they will last a couple more years and I can move to the Dobinson MRR
5th Gen Build
09-07-2023, 01:25 PM
#308
Similar to what others have posted - I've replaced everything on 3 out of 4 corners in 2 years and now the UCA's are being recalled. I'm done, have torn this suspension apart far too many times.
The next time she goes on jackstands everything gets ripped out and there won't be another Ironman product anywhere near my rig. I do admit they have stood behind warranty replacements, but that's not enough, quality in the first place would be much better. You can't expect clients to tear into their rigs this often. All of my failures have been with less than 20K miles on it.
09-07-2023, 03:36 PM
#309
It sounds like you guys are having issues with the shocks not the UCA’s. I realize that there is a recall on the UCA’s and Ironman is taking care of it by sending us an updated arm, not just a ball joint. I would agree with you on the shocks and coils. It appears that they don’t produce a great product shock setup. I was just trying to see if anyone is actually having issues with the arms but I think most or all of the issues here are from shocks and coils.
09-08-2023, 06:55 PM
#310
Originally Posted by honda250xtitan
meh....a monotube shock has the oil and gas separated by the piston... also the gas provides the pressure for rebound. So the shock is all oil, whats creating the pressure to extend the shock? Seems like a great way to having a bucking bronco. (yes i know springs are pushing down but springs hold the weight, shocks control the movement)
what happens when the foam cell gets cooked from one long stretch of a dirt road? IDK, foam bumpers inside my shocks seems like a step backwards.
lulzzzzz
10-23-2023, 05:54 PM
#311
Fyi. Just got an email stating that my control arms just shipped.
10-27-2023, 08:42 PM
#312
A lot of this is anecdotal, but I've been running full FCP suspension for about 3 years and 30k miles with no issues.
10-30-2023, 11:51 AM
#313
Real Name: Neal
Real Name: Neal
I have been running the Ironman 4x4 Nitro gas kit on my 2012 4runner for a little over a year now. I went with the lightest spring options available wi5h the kit, 2.5 inch medium fronts and 2 inch medium rears. I'm not very happy with the setup, it rides very firm and I can feel every bump in the road. At first I was happy and it felt softer than the OME I had on my 3rd gen. After driving many other 5th gens wi5h different suspension setups I now feel how firm the Ironman is. I am going to be removing I and going with a different setup. I don't know if the springs rates are too heavy for my needs or if they shocks are valved for heavier loads.
2012 SR5P 4x4, 2018 TRD Pro front bumper conversion, Auxito LED head light bulbs, Ironman 4x4 Nitro lift with OME 888X front springs, RSO Suspension upper control arms, RSO Suspension prototype skid plates, DX4 Beast wheels, led ditch lights and brackets from Amazon, blacked out emblems, Victory roof rack, CTH ladder, more to come. Previous Rigs. 1997 SR5 4x4 no lockers, Trail Gear sliders, OME 881 890 lift and shocks, Magnaflow muffler, Airaid Jr intake, CBI ditch light brackets, Ebay led spot lights, 265/75R16 AT tires. 1996 Tacoma TRD Sport 4x4 2.7L MT bone stock on 32's.
12-05-2023, 09:52 PM
#314
What set ups are you considering? What other set ups did you test drive with you liked?
My covers is the high spring rate, especially the front. Couple hundred pounds more than say old man emu. The answer I got from Iron Man was it did not matter of had higher spring rate, cause they are designed to be heavier cause designed to be paired up with their shocks.
I have been considering the 2.5”. Front, 2” rear set up paired up with the foam cell pro shocks. For my 4 runner with no added bumpers, winch, tent, fridges etc. I like a little bit of rake. I don’t plan on ever putting more than 200-300 pounds of camping gear in the back for some trips I am planning, and 90% of time is a daily driver.
01-15-2024, 11:03 AM
#315
Any new updates from those running the Ironman pro foam cell lift kit and/or their UCAS?
Did those of you who installed the 2.5” front/2” rear still maintain some factory rake?
