Old 04-20-2020, 05:22 PM #16
jdm-v35 jdm-v35 is online now
jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough
poly bushings ordered!
jdm-v35 is online now   Reply With QuoteReply With Quote
Old 04-20-2020, 05:29 PM #17
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Originally Posted by jdm-v35 View Post
I test drove with and without KDSS and at the time it seemed like a better idea to go with non-kdss because of more suspension options, and no issues with it down the road as I plan to keep the 4runner for 20+ yrs. The 5100's and OME springs did help and there is pretty much no nose dive on braking. Sway is less than stock, but still very very present.
I may try the poly sway bushings to see if that helps as well as continue looking into sway bar fitment.
As for comparison between my G35 and a stock G37, and the 4runner by spring rate F/R:
my 4runner: 590lb / 260lb
G37: ~ 420lb / 400lb
My G35: ~ 560lb /560lb plus every single bushing changed to poly and sways are 70% stiffer than stock.
I think all the sway and weakness are in the rear springs of the 4runner, and stiffer springs or a rear sway upgrade would help.
There's nothing on this planet that will make your 4Runner behave like a G37.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 04-20-2020, 05:32 PM #18
Agreed! not trying to even get close to that. was more a comparison for the person who was asking about comparison between the g37/g35
Will give the bushings a try and hope they help! I saw a comparison picture and there is quite a bit of rubber material there allowing for movement, so maybe the poly would be a big improvement by itself.
Old 04-20-2020, 09:15 PM #19
NW.OH.T4R NW.OH.T4R is offline
Real Name: Jason
NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough
Real Name: Jason
I haven’t installed these yet, but another member had before going on a Moab trip. These are aluminum brackets with a Delrin insert and either poly or high durometer rubber bushing. The full kit is only available for the front because the hole spacing on the rear is much larger than anything available for our 20mm rear sway bar. Price was $100 shipped to my door from Ride Tech. They aren’t on their online catalog yet, but are available if you reach out to them directly.
NW.OH.T4R is offline   Reply With QuoteReply With Quote
Old 04-20-2020, 09:31 PM #20
thanks! I saw something similar for sale from ironman 4x4. i am not sure if the bracket itself will help any more than just changing the bushing itself though? So far I have ordered front and rear poly sway bushings from whiteline, and also ordered energy suspension urethane rear endlink bushings.
I think most of the swaying is coming from the rear and hopefully these small things make a decent difference. They seem to have great reviews and significant improvement in handling according to other threads here.
Old 04-20-2020, 09:43 PM #21
Ezlife45 Ezlife45 is offline
Ezlife45 will become famous soon enough
Ever drive a limited? different suspension in that too.
Ezlife45 is offline   Reply With QuoteReply With Quote
Old 04-20-2020, 10:16 PM #22
I have not. saw the chrome, interior and bodystyle and wasnt really liking it. Plus it is nice to have the rear locker option. From reading though, the xreas would be the softest suspension option
Old 04-20-2020, 10:54 PM #23
Turfboy's Avatar
Turfboy Turfboy is offline
Turfboy will become famous soon enough
Turfboy's Avatar
My wife gets motion sickness also. The KDSS certainly helps but I have learned the following helps.
1) Slow down before it gets bad
2) Open windows before it gets bad
3) Stop if it gets bad.
Good Luck!
2016 TEP, KDSS, ALPRO Apex Sliders, Focal IS690TOY, Old Red's Accessory Meter Display Mod , Rear Differential Breather Mod, Radium Fuel Surge Tank, URD Supercharger , Ironman FCP shocks
Turfboy is offline   Reply With QuoteReply With Quote
Old 04-20-2020, 10:56 PM #24
Real Name: Jason
Real Name: Jason
The one from Ironman is only the aluminum bracket. The real difference with this kit is the Delrin sleeve inside the bushing. In theory the Delrin should really tighten the bushing compression.
Old 04-21-2020, 09:58 PM #25
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
Is the OP's front end lifted? My 5100's are at the max setting of 2.5'' and mine is ''float'' free and little roll. Sounds like the OP is rolling on the springs like a boat.
83Mule is offline   Reply With QuoteReply With Quote
Old 04-21-2020, 10:58 PM #26
yes the fronts and rears are OME springs. 2" lift all around and they are stiffer than oem. I am guessing yours could be stiffer at the cost of some travel because you are preloading the stock springs. my clips are on the lowest settings.
Old 04-21-2020, 11:25 PM #27
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
I have used 4 front springs and 2 rear springs not to mention front Dobs with OEM rear.
With all that, I would say that a stiff offroad setup has virtually no sway but comfort on road will not be the same as with a lighter duty spring. I don't really sway.
For most people, I would say 6112 at lowest setting with stock rear springs and Eibach sport shocks in the rear to maximize comfort while improving handling.
This will give you great handling for an SUV and a plush ride.
And it will still be an improvement off-road though it won't match the speeds of a stiffer suspension or the latter's ability to not squat over rocks when crawling. But most people don't need either of those abilities.
EDIT: come to think of it, the 6112 on 600lb springs still has lots of brake dive. So I am not sure if that would be a factor for you. But it corners very nicely. 650lb springs dramatically improve the 6112's offroad performance but they make for a sporty rather than a plush ride on road.
Old 04-22-2020, 04:45 PM #28
Thanks for the info! that firsthand comparison info is highly useful. How would you compare 600 vs 650 spring change on road? more firm and planted and less sway? I am looking for that very firm sport feel more so than plush and comfortable. I am on 5100's and the fronts are 590lb springs. maybe going to 6112 fronts with 650's would be ideal. But if I am going that far I may just go kings with 650 or 700lb fronts.
I dont crawl over rocks much much except to go on trails on the woods for camping. Most of it is high speed washboard and fire roads.
I figured for $60 ill try the poly sway and endlink bushings before jumping straight to $2500 kings.
I also just thought about that I do have dual AGM batteries up front now which could cause sagging in front as well.
Old 04-22-2020, 05:55 PM #29
seth401 seth401 is offline
seth401 is on a distinguished road
Originally Posted by Sundy View Post
Sounds like the cheapest option might be to keep a bottle of dramamine in the 4Runner for her
On a more serious note - expanding on Jetboy's comment, I would also test drive a 4Runner with KDSS. I wanted KDSS specifically to stiffen up the truck at higher speeds as my girlfriend gets motion sickness rather easy and I was used to driving a full size pickup with much less body roll.
It might not be feasible to sell/change to a vehicle with KDSS, but you could see if the 4Runner is something that can be considered for you two moving forward, or if the KDSS makes a significant enough change where you want to upgrade.
Either way, I just install my suspension about 200 miles ago and it has less body roll/nose diving lifted than it did factory w/KDSS. The ride is a little firmer but very comfortable.
I did upgrade the UCA's to get additional caster which helps reduce the touchiness of the steering and makes it feel a bit more stable at high speeds. Another thing you might want to try - can get Freedom Offroad UCA's for a great price - I'm personally quite impressed with them.
I have 5100's on all 4 corners and dobinson springs in the back. I don't have much body roll(nothing like stock) so it might be rear springs would help
seth401 is offline   Reply With QuoteReply With Quote
Old 04-22-2020, 06:13 PM #30
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
Originally Posted by ads2539 View Post
I don’t think sway bars will help your wife’s motion sickness. I don’t think it is a vehicle-dependent issue.
It’s not strange at all that she got the most sick in the back seat of a car.
I have suffered from motion sickness my whole life, and it is definitely worse in the back seat. It is easier to see where you’re going and focus on the horizon in the front seat. In an airplane, you really can’t see where you’re going, and there’s not a horizon to focus on, so I get the worst motion sickness in the air. (I get seasick looking at a boat, haha!)
I never get motion sickness if I am the driver of a car or the operator of a boat.
If I try to read as a passenger in a moving car, I feel sick almost immediately.
THIS^ I'm the same way.
That said, to answer your question, I just got heavier dobinson springs and my 4R rides much stiffer than before. It makes me feel like I'm back in my 3/4 ton truck. Which to me is a good thing.
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
4runner , issue , leaning , springs , swaying
Compressor no longer turns on, and trying to turn it on turns off the speakers. 4rcybr 4th Gen T4Rs 0 06-17-2018 01:16 PM
Best Rear suspension value option for high milager 4th GEn greenscales 4th Gen T4Rs 8 11-09-2016 04:59 PM
Need to get rid of XREAS, which suspension option should I go for? MadKap 4th Gen T4Rs 7 05-19-2015 12:52 AM
Questions about Xreas and self levling rear suspension option? Jason B 4th Gen T4Rs 23 09-13-2007 07:37 PM
Suspension parts to reduce body roll? *AK2006* 4th Gen T4Rs 20 04-13-2006 08:32 AM
