Old 04-22-2020, 06:20 PM #31
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
I think the 4th gen model had motion sickness down for the rear passengers... people say that little thing back there is for a little trash can, but the size and shape better resembles a barf bag.
Couple that with the lacking sun glass holder... and you can really see what's lacking in the 5th.
Old 04-22-2020, 09:02 PM #32
jdm-v35 jdm-v35 is online now
jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough
since people mentioned dobinsons I took a look at their rear springs. unfortunately the only ones that are stiffer than the what I currently have are the springs rates for 600-800lbs of weight (271lb springs). my OME 2895e's are 260lb springs.
If the bushings do not help, I will take a look at other suspension options. not only for this reason, but it may be good to do an upgrade anyway in the near future.
jdm-v35 is online now   Reply With QuoteReply With Quote
Old 04-23-2020, 07:47 AM #33
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
You might call Dobinsons or contact Crikeymike on here. I think there is an intermediate weight spring in the 400# range, IIRC.
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
Old 04-23-2020, 01:47 PM #34
Rack Rack is offline
Rack has a spectacular aura about Rack has a spectacular aura about
What I'm hearing here is
"Honey we need a new suspension system for our truck so it makes you happy". LOL
signature not available
Rack is offline   Reply With QuoteReply With Quote
Old 04-23-2020, 02:56 PM #35
I wish, but not at the moment if possible. Trying to finish up engine for my other car first before doing more expensive work on the 4runner. I also do not really daily the 4runner. It is just used in bad weather, for camping, and hauling stuff for the most part. Camping drives are long though, which is usually when it comes up.
Old 04-24-2020, 06:16 AM #36
In that case, as it's not a daily.... generic dramamine is cheap...
Old 04-24-2020, 01:06 PM #37
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
It could be the digressive shocks. I'd say the springs you're running now should be more than enough.
Try changing the rear shocks out and put the stock ones back on. It won't cost you anything and you can see how it feels with different shock valving.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 04-24-2020, 04:26 PM #38
Thanks for the suggestion. that may be a good idea. are the stocks progressive style valving?
Old 04-27-2020, 04:55 AM #39
Louisiana Overland's Avatar
Louisiana Overland Louisiana Overland is offline
Louisiana Overland is a jewel in the rough Louisiana Overland is a jewel in the rough Louisiana Overland is a jewel in the rough
I did some work on my suspension last year that has it handling much flatter. I have the standard yellow shock OME 3” kit. The shock/spring combo adds about 3” front and 2” ish rear lift. First I swapped to sway bushings front and rear to urethane. This did result in a noticeable change on its own.
I had also installed adjustable rear sway bar links. Mine are Dobinsons, although several sources are available. The purpose here is to correct the geometry of the rear sway bar after lifting. Two reasons. Number one is to lower the ends of the sway bar so that it is as near parallel to the ground as possible. This puts it back in position to function as designed to combat rear sway. Second reason, after lifting, unless you have extended sway links to lower the ends, the travel of the sway bar is limited. So, in offroad situations, the axle droop can be limited by the sway bar’s travel. Adding the adjustable links fixes this and allows for the droop to be limited by the max extended length of the shock. Good stuff, eh?
Lastly, the panhard bar. Factory panhard geometry puts it pretty much parallel to rear axle. Lifting the suspension will change the angle on the bar. The bars function is to keep the rear axle centered under the truck and also to brace against side to side motion of the axle. It cant do either very well unless it is parallel to the axle. An adjustable panhard bar can be used to re center the rear axle under the truck, but does nothing to help with the bracing against side to side motion. A panhard correction bracket fixes both issues without replacing the bar itself. Forum member eimkeith sells these. It is a weld on bracket, but it retains factory mount positon in case you ever go back to stock ride height. After installing it extends the length of the axle bracket to get the bar parallel.
These three mods together made a great bit of improvement to handling. Its about as near to slot car handling as one can expect from a lifted vehicle.
Lastly, is this a new thing for her? I had a vertigo episode awhile back that really messed me up for about 6 months. Maybe theres medical help for her situation.
Also, my ex got car sick..unless she was driving. Let the girl wheel!
Louisiana Overland is offline   Reply With QuoteReply With Quote
Old 04-27-2020, 07:46 AM #40
Muskrat14's Avatar
Muskrat14 Muskrat14 is offline
Real Name: Dave
Muskrat14 will become famous soon enough
Muskrat14's Avatar
Real Name: Dave
Originally Posted by ads2539 View Post
I don’t think sway bars will help your wife’s motion sickness. I don’t think it is a vehicle-dependent issue.
It’s not strange at all that she got the most sick in the back seat of a car.
I have suffered from motion sickness my whole life, and it is definitely worse in the back seat. It is easier to see where you’re going and focus on the horizon in the front seat. In an airplane, you really can’t see where you’re going, and there’s not a horizon to focus on, so I get the worst motion sickness in the air. (I get seasick looking at a boat, haha!)
I never get motion sickness if I am the driver of a car or the operator of a boat.
If I try to read as a passenger in a moving car, I feel sick almost immediately.
My friend wife get motion sickness in every car, except when she drives. Out her behind the wheel and see if it makes a difference.
I’ve never driven a KDSS version of a 4runner, but take one of those for a drive and see what happens.
Muskrat14 is offline   Reply With QuoteReply With Quote
Old 04-29-2020, 10:12 AM #41
Thanks for the info! I have bilstein 5100's and 2" OME springs front and rear. I think that I am going to try and crank the fronts up a notch to get closer to 3" and also add some preload to stiffen things up. I also got the sway bushings in and will get those installed. I have had the PCK kit but just have not got it welded in yet. My friend will do it for me, but the weather has been on and off so hopefully will get it done soon. Hopefully that combo will help.
The motion sickness is definitely not anything new. we rented a canoe on the lake one day and that made her sick, and its just something about riding in certain cars.
Old 04-30-2020, 10:39 AM #42
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
Poly sway bar bushings make a huge difference.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 10:09 PM #43
I installed the front and rear whiteline poly sway bushings. Havent installed the rear endlink poly bushings yet, and no driving yet. will update with my experience.
Upon install I can feel a significant difference in the poly vs oem rubber compound though. And mine should be "almost new". my 2018 only has 14k miles since i got it new. We will see how significantly it improves handling.
Old 05-01-2020, 10:49 AM #44
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
to add this has been mentioned before, here is a post with pictures
https://www.toyota-4runner.org/3208305-post19.html
it's best to read the complete thread, it would be wise to coat the link to prevent rust.
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 07:16 PM #45
Thanks! I may actually go and buy those longer links now. I went out and bought some flex head ratcheting wrenches and changes out the rear link bushings in about 20 min.
I drove this morning and the sway bar bushings did make a noticeable difference on turns. I would recommend it. This is how it should have felt from the factory.
4runner , issue , leaning , springs , swaying
Compressor no longer turns on, and trying to turn it on turns off the speakers. 4rcybr 4th Gen T4Rs 0 06-17-2018 01:16 PM
Best Rear suspension value option for high milager 4th GEn greenscales 4th Gen T4Rs 8 11-09-2016 04:59 PM
Need to get rid of XREAS, which suspension option should I go for? MadKap 4th Gen T4Rs 7 05-19-2015 12:52 AM
Questions about Xreas and self levling rear suspension option? Jason B 4th Gen T4Rs 23 09-13-2007 07:37 PM
Suspension parts to reduce body roll? *AK2006* 4th Gen T4Rs 20 04-13-2006 08:32 AM
