Originally Posted by VanillaGorilla502
How did you get the bracket mounted in the cubby? Did you pull the center console and drill a hole in the back to runthe wires? Any links would be appreciated or pictures.
That's exactly what I did. While I had everything apart
-I ran the power to the cigarette lighter plug in the center console,
-routed the antenna wire down the passenger side then behind the kick panel to the back of the dash,
-drilled a hole in the back of the cubby and attached the quick release mount to the cubby top,
- hooked it up, slid the cubby back in place, then reassembled the rest of the console
Don't have pictures or a write up, I get busy doing and forget to document.
2019 MGM TRD ORP
Dobinsons IMS 3in lift, FN f(x) Pros 17x8in 0 offset, 285/70 C load Nitto Ridge Grapplers, and all sorts of other fun stuff
shootn4runner on IG
