04-22-2020, 08:39 AM
Gmrs radio
2019 SW TRDORP
04-22-2020, 10:43 AM
I like mine as well but never went that far for testing, good to know it works on repeaters at that range with the extended antenna.
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
04-22-2020, 11:31 AM
Looks great! Was considering installing mine under the dash on passenger side but this looks like a better idea. Thanks for sharing!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
04-22-2020, 11:51 AM
Are you closing the center console door on the coil? does it close and stay shut?
Mine is in the glove box but not permanately fixed just Velcro down, so I can move it to other vehicles when needed, ghetto rig I know.
04-22-2020, 12:18 PM
I did the same with my box but ran switched constant power and extended the mic to a homemade port in the tiny dash cubby. It’s a great set up having all the controls on the mic.
04-22-2020, 01:35 PM
Gmrs radio
Mine is Velcro as well for ease of removal and setup in a go box.
I actually used a dremel with a cylindrical grinding bit on the lid where the mic wire comes through between lid and console. The straight part before the coil is what comes through. I just leave the mic in the front cup holder currently.
2019 SW TRDORP
04-22-2020, 01:39 PM
Nothing wrong with that! I agree , all controls on the mic was honestly why I chose that model
2019 SW TRDORP
04-23-2020, 12:31 AM
Just got mine last week, still looking for mount + antenna. Are you using their 4R hood bracket? Does it still tilt forward or can it be easily bent back?
01-16-2021, 04:38 PM
Trying to work a commo plan for the TuRD. GMRS is good for... A closed network? Are they used on the highway like CB radio in the olden days?
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
01-17-2021, 11:54 AM
Real Name: Halko
Real Name: Halko
Originally Posted by Charlievee
Trying to work a comment plan for the TuRD. GMRS is good for... A closed network? Are they used on the highway like CB radio in the olden days?
I use it in off-road groups and caravans on road. Has worked better for me than CB generally. Ive used both and gmrs is easier with good range. If you want to talk to truckers I suppose they still use CB. I occasionally got some entertainment on the CB but I’d rather listen to music.
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
06-07-2021, 10:38 PM
How did you make the homemade port? I just ordered the radio and I'm looking to do the same.
06-08-2021, 01:46 AM
Just drill a hole in the back of that cubby and run an extension cable from the radio in the center console under the console to behind the dash and through the hole in the back of the cubby. Could probably do this without removing the entire center console by drilling some holes and tucking the extension cable under the sides of the console leading to the dash, but I pulled mine out when I did it.
Originally Posted by RysiuM
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
06-08-2021, 02:15 AM
What is that insert/bracket that you have in that cubby that is holding it?
06-08-2021, 04:35 AM
That's the mounting bracket for the radio. It comes with it.
06-08-2021, 09:38 AM
Real Name: Ben
Real Name: Ben
GMRS is pretty affordable, and if you're going to be legal, the license is for a family and not an individual like HAM. Distance isn't quite what HAM is, but there are more and more repeaters popping up all over to help with that. Seems to be a better, clearer, and further reaching option over CB.
But none of this matters if you're going with a group that has something else. I haven't installed a mobile radio of any kind yet because of this. I do have my HAM license, and there are reasons I like HAM, but I have a couple of GMRS handhelds for going exploring with my kids. Only problem is distance with handhelds... not too far.
1992 3.0 Auto - First Project -Sold-
1995 3.0 Manual - Second Project - Sold-
2018 TRD ORP Barcelona Red
