Old 04-22-2020, 08:39 AM #1
DeltaWhiskey's Avatar
DeltaWhiskey DeltaWhiskey is offline
DeltaWhiskey has a spectacular aura about DeltaWhiskey has a spectacular aura about
Gmrs radio
I picked up a Midland MXT275 gmrs radio and found it fits nicely in the console. I used the power outlet for power, and drilled a hole for the antenna. Works very well, made contacts at 17 and 25 miles away with the mxta26 +6db antenna
2019 SW TRDORP
DeltaWhiskey is offline   Reply With QuoteReply With Quote
Old 04-22-2020, 10:43 AM #2
Akkording's Avatar
Akkording Akkording is offline
Akkording is a jewel in the rough Akkording is a jewel in the rough Akkording is a jewel in the rough Akkording is a jewel in the rough
Akkording's Avatar
I like mine as well but never went that far for testing, good to know it works on repeaters at that range with the extended antenna.
2012 Blizzard Pearl SR5 | 285P Destination AT2 | Level 8 Slam | PC | X2Power w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | 6112 | 650# King | ICON Delta Joint | 5160 | SAW 1.5" | .5" Headstrong top plate |
| 03 Tacoma OME equipped, +300k Still Truckin|
Akkording is offline   Reply With QuoteReply With Quote
Old 04-22-2020, 11:31 AM #3
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Looks great! Was considering installing mine under the dash on passenger side but this looks like a better idea. Thanks for sharing!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 04-22-2020, 11:51 AM #4
Akkording's Avatar
Akkording's Avatar
Are you closing the center console door on the coil? does it close and stay shut?
Mine is in the glove box but not permanately fixed just Velcro down, so I can move it to other vehicles when needed, ghetto rig I know.
Old 04-22-2020, 12:18 PM #5
Phil Frames Phil Frames is offline
Phil Frames is on a distinguished road
I did the same with my box but ran switched constant power and extended the mic to a homemade port in the tiny dash cubby. It’s a great set up having all the controls on the mic.
Phil Frames is offline   Reply With QuoteReply With Quote
Old 04-22-2020, 01:35 PM #6
Gmrs radio
Mine is Velcro as well for ease of removal and setup in a go box.
I actually used a dremel with a cylindrical grinding bit on the lid where the mic wire comes through between lid and console. The straight part before the coil is what comes through. I just leave the mic in the front cup holder currently.
2019 SW TRDORP
Old 04-22-2020, 01:39 PM #7
Nothing wrong with that! I agree , all controls on the mic was honestly why I chose that model Gmrs radio
2019 SW TRDORP
Old 04-23-2020, 12:31 AM #8
sclui56 sclui56 is offline
sclui56 is on a distinguished road
Just got mine last week, still looking for mount + antenna. Are you using their 4R hood bracket? Does it still tilt forward or can it be easily bent back?
sclui56 is offline   Reply With QuoteReply With Quote
Old 01-16-2021, 04:38 PM #9
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a glorious beacon of light Charlievee is a glorious beacon of light Charlievee is a glorious beacon of light Charlievee is a glorious beacon of light Charlievee is a glorious beacon of light Charlievee is a glorious beacon of light
Charlievee's Avatar
Trying to work a comment plan for the TuRD. GMRS is good for... A closed network? Are they used on the highway like CB radio in the olden days?
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 01-17-2021, 11:54 AM #10
Jhalko's Avatar
Jhalko Jhalko is offline
Real Name: Halko
Jhalko has a spectacular aura about Jhalko has a spectacular aura about
Jhalko's Avatar
Real Name: Halko
I use it in off-road groups and caravans on road. Has worked better for me than CB generally. Ive used both and gmrs is easier with good range. If you want to talk to truckers I suppose they still use CB. I occasionally got some entertainment on the CB but I’d rather listen to music.
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
Jhalko is offline   Reply With QuoteReply With Quote
antenna , gmrs , miles , power , radio
Mounting GMRS and CB Aznisegi 5th gen T4Rs 9 01-10-2021 12:44 PM
GMRS vs CB and whats the protocol to connect? wlfmachine 3rd gen T4Rs 0 12-05-2018 11:45 AM
FRS vs GMRS radio Expat 4th Gen T4Rs 5 01-16-2005 05:26 PM
GMRS radios. dcampen Off-Roading 3 09-15-2004 12:33 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
