04-24-2020, 09:25 AM
Water Rotopax on rear window molle panels?
Bad idea? Would be a great location with a GoWesty water spout. Full access while loaded up, no dust, etc.
But...weight full and the water dynamics when half full. Rago shows their kid hanging off of them.
Thoughts?
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
04-24-2020, 10:25 AM
Thoughts?
I wouldn't want 16# of water hanging up high in my rig. But then again I see people with hatchets, machete, fire extinguishers etc on molle panels. Not my idea of safe but to each their own.
04-24-2020, 10:39 AM
Water is heavy, almost 7 pounds per gallon.
Would recommend checking how much weight the mole panels can support and make sure there’s headroom for water potentially sloshing around creating additional forces.
I suppose if Rago shows it that they’ve done the math and tried it out.
04-24-2020, 10:43 AM
water is just over 8# per US gallon
04-24-2020, 10:48 AM
I assume you are referring to something like this? (not my photo) I would email Rago, Victory, Orange Boxx, or whoever makes molle panels and ask if they could provide a dynamic load rating.
04-24-2020, 10:49 AM
Just looked it up and you beat me to it, was going to update the post. Thanks. So much for my memory!
04-24-2020, 11:54 AM
Thoughts?
i dont think you will incite a response from any of the manufacturers to give you a thumbs up due to liability reasons. I also don't think it will be an issue as long as you arent strapping them on with a bungee cord. dont skimp on mounting and 2 gallons of water should be ok.
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
