04-24-2020, 03:24 PM
#16
Originally Posted by Finslayer83
Was that for me?
Its a TRD so its adding to the OEM "lift" and I've been assured by many clearing 285's will not be an issue.
Going on 17x7.5 FJ steelies.
ETA: What PSI are folks running on thier E load tires (275 or 285)? Seems 38-40psi is popular.
I'm running my 285 Wildpeak M/Ts at 36-37psi.
Also for the OP, when I had my Wildpeak AT3Ws (E), I can't say they were loud on the highway. Had them for about 20k miles before changing them out for the M/T. They were still at 15/32 (17 to start) and had about 1500 miles of offroad travel on them.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
04-24-2020, 05:26 PM
#17
I have the 285 KO2's. I would have gotten the Wildpeaks but they weighed about 7 lbs heavier each. I have never figured out why a Wildpeak C-load is so much heavier than the KO2 C-load. In fact the C load and E load Wildpeak's weigh about the same. That doesn't make any sense.
I run them at 42 PSI.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
04-24-2020, 05:38 PM
#18
Was that for me?
No sorry that was for OP.
Also I keep my E's at about 34 to 36. 40+ is harsh to me.
04-24-2020, 05:40 PM
#19
I bought some falken wild peaks in 275 flavor about a 2 weeks ago. One of the main reason I chose these over ko2’s or any other is because they are c rated and wanted to keep the same ride as the stock tires. Do have some rubbing on the front mud flap, Bilstein 5100’s on the way. Also, only have about 1k or less miles on then but I haven’t got any additional noise on the road
'19 TRD ORP, Magnetic Gray stock
04-24-2020, 07:29 PM
#20
Yea all of Falkens tire weights seem odd, especially the C vs E load weights. Why are they heavier than the Ko2s? Not sure really but I remember reading somewhere that the steel they used in the belt was cheaper and heavier than the type the Ko2s use. I was concerned about the weights but got a deal I couldn't say no to lol. 64lb tires ...yeap lol
04-24-2020, 08:25 PM
#21
I put 275 wildpeaks on the wife’s T4R and they are pretty quiet. I refuse to buy BFG KO2s anymore.
2015 Nautical Blue Trail Premium 4WD w/KDSS
2016 Magnetic Gray Limited 4WD
2000 Land Cruiser
04-24-2020, 09:49 PM
#22
Why? I have run 3 sets on 2 different 4runners. Close to 150k miles with not a single issue. I will say, they lose some wet weather performance after about 40k
04-25-2020, 12:23 PM
#23
Real Name: Sparky
Real Name: Sparky
I have them on my FJC and my 4Runner. They are a good all around tire.
Old and (c)rusty.
04-25-2020, 03:14 PM
#24
I have a set of the 285 Falkens and a new set of Methods in the shop now. Just waiting for new TPMS sensors and I'll mount them up. I did a lot of research before pulling the trigger and the Falkens seem to be held in very high regard. I have also had great luck with the General ATX's on the truck now. 30k on them and maybe 1/2 worn. I've had numerous sets of the BFG's also. Never had an issue with them. I did run Coopers on my last Tacoma and they were OK but not great.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
04-25-2020, 03:28 PM
#25
BFG KO/KO2s were the only tire I ever bought for the 9 Toyota 4WDs I’ve owned.
My last two sets were installed on an 07 T4R Sport 4wd V8 and a 2000 Land Cruiser. They both wore like complete crap. Rotated/balanced at every oil change at the Toyota dealer.
Now I have two 5th gens and figured it was time for a change. The Falkens have been great so far.
2000 Land Cruiser
04-25-2020, 05:19 PM
#26
Got em on this morning along with the CF 2/1.5
3rd Vehicle with an AT3 variant, second with XLT's. Best A/T out there. I've owned 7 sets of BFG's (A/T, KO, KO2, M/T, and KM2), I'm a Cooper convert.
04-25-2020, 10:21 PM
#27
Originally Posted by comtn4x4
I'd vote for the Coopers. Solid American made tire
I’d trust a recommendation for Coopers from the CO and TN members vs the Falken recommendation from FL. No offense FL you guys just have too great of weather down there. MA is another beast of climate.
04-26-2020, 12:58 AM
#28
You friend probably has E rated Falken tires and you should get P rated Falken Wildpeak AT3 since they only weigh 50lbs and it's more than enough for your application.
04-26-2020, 06:55 PM
#30
Originally Posted by Ascole
Those look pretty great. I’ll have to consider them as well. Thanks for the recommendation!
