Old 07-16-2020, 02:19 PM #1
tls3601 tls3601 is offline
Real Name: Tom
tls3601 will become famous soon enough tls3601 will become famous soon enough
Real Name: Tom
Gobi Rack
Considering a Gobi for my 2019 Voodoo Blue Pro with sunroof. What model is best and what do people think of it? My plan is to run a Roof Nest RTT up there and also mount some gear, shovel, axe, traction boards etc. Will there be room for that with RTT on top? Thanks for the input guys.
1978 FJ40. Mostly stock, reverse shackle 3 inch lift.
2019 Pro Voodoo Blue
tls3601 is offline   Reply With QuoteReply With Quote
Old 07-16-2020, 02:45 PM #2
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Gobi Rack - Advantage and disadvantages
Gobi Stealth: no rise vs standard
https://www.toyota-4runner.org/3518143-post18290.html
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 07-16-2020, 02:54 PM #3
2112 R's Avatar
2112 R 2112 R is offline
2112 R will become famous soon enough 2112 R will become famous soon enough
2112 R's Avatar
It all depends on the dimensions of the RTT. Many RTTs hang over the sides of the roof racks and that is where many of the accessory mounts go, so there is a high possibility that the RTT will interfere with the gobi sold mounts.
You may want to look at the flat roof racks if you're set on a RTT.
If you're set on having a gobi, I would suggest the stealth which is the lower profile one, so you're keeping the weight of the RTT as low as possible and I assume you'd have a lot of empty space under it if you get the Ranger Rack. It might be able to be configured for storage under the RTT, but accessing it could be a pain with the Ranger.
In general you're going to get speculative answers here as you'll have to measure the gear/tent you have and determine if it will fit/mount to the rack you want and the extra options of the accessories.
While gobi doesn't have the greatest rep on this forum (and most places) for being helpful, you might want to give them a call and see what they thing about the accessory mounts with RTT options.
Additionally, google and forum search here folks who have gobi's with RTTs to get ideas on what might be possible ... all depending on what you want to bring with you.
Pic of mine loaded down for a Death Valley Trip, no RTT, but hey, if you're gonna post, might as well include a pic.
2112 R is offline   Reply With QuoteReply With Quote
Old 07-16-2020, 03:30 PM #4
Real Name: Tom
Real Name: Tom
Thanks for your response. Is that a Gobi Stealth Rack?
Old 07-16-2020, 06:14 PM #5
2112 R's Avatar
2112 R's Avatar
Yes, gobi stealth, with the rise in the front and 40" light bar brackets and a 6" light rear facing.
I wanted the lower profile with the stealth 'in case' we ever wanted a RTT.
We mount a ton of stuff up there and there a lot of easy ways to tie and secure it all down.
I take off the hi lift and rotopax when using it as the DD.
Some more shots to give you perspective of how it sits up there. There are tons of impages on line and lots of roof rack options. Just gotta find the one that is right for what you want to use it for.
Also not sure why the aspect ratio of the pics is all messed, but whateves, you get the idea.
Old 07-16-2020, 06:27 PM #6
cmilviper's Avatar
cmilviper cmilviper is offline
cmilviper is just really nice cmilviper is just really nice cmilviper is just really nice cmilviper is just really nice
cmilviper's Avatar
Like what was said above, there are better/easier racks for mounting a RTT, but the Gobi Stealth can definitely work, and it's tough as hell....
I've had a Gobi on my wife's 4Runner since 2015, and on mine since 2017.........no issues at all.
The type and size of the RTT will determine if you have room for anything else. My tent takes up the entire rack, but I was still able to mount my awning with no problem ect.
Good luck.
2017 4Runner TRD Pro - Cement Icon RR CDCV (700 lb) w/ Icon Delta Joint UCA's/Billet Rear Link Arms || Icon Overland 3'' Rear Springs+Dobinson's 15mm spacers on top || C4 Fab Sliders || CBI Front Bumper || Shrockworks Rear Bumper || Gobi Stealth Rack/Ladder || Baja Designs & Rigid Lighting || 285/75r17 Toyo MT's (34") || Safari Snorkel || ARB Diff. Breather Kit || Spidertrax || ARB Awning 2000 || Maxtrax || XD Philips 4300K HID's || Warn Winch/Factor 55 || IKamper Skycamp 2.0 4X || SCS Ray10's || Durobumps
2015 4Runner TRD Pro - Super White (Wife's) Icon Stage 2 w/ Icon UCA's || Toytec Superflex HD Rear Springs || Expedition One Sliders || 285/70r17 BFG KO2's || Gobi Stealth Rack/Ladder || 40" Rigid Radiance || Spidertrax || XD Philips 4300K HID's || Philips Yellow LED Fogs
cmilviper is offline   Reply With QuoteReply With Quote
Old 07-19-2020, 04:30 PM #7
Real Name: Tom
Real Name: Tom
Thanks for posting up the pics, it gives me persoective as to what I might be able to get up there. BTW love the Cement👍
Old 07-19-2020, 11:34 PM #8
760Runner 760Runner is offline
760Runner will become famous soon enough
Why do people pick the stealth over the ranger? It’s literally an inch in difference, why not have that extra stability with cargo? The cg/top load isn’t really going to make that much more of a difference, same with trying to get into parking garages....seems like more people buy it for the looks over the ranger? Curious about that decision on Why people pick the stealth over ranger
760Runner is offline   Reply With QuoteReply With Quote
Old 07-20-2020, 09:11 AM #9
ctrporsche ctrporsche is offline
ctrporsche is on a distinguished road
How is the Gobi stealth with wind noise? I have a 2019 TRDP and am considering one of these racks to replace the stock basket. But I don't want to deal with any wind noise as I do a lot of highway driving.
ctrporsche is offline   Reply With QuoteReply With Quote
Old 07-20-2020, 12:36 PM #10
trey99ek trey99ek is offline
trey99ek will become famous soon enough
I had a a Gobi stealth on my 4th gen. The wind noise was minimal. My light bar is what added noise. I just took my first trip with my Sherpa rack in my 5th gen. I already miss the mesh floor of the Gobi. It was nice tossing stuff up here an not have to rely on centering the load on the crossbars.
Sent from my SM-G960U1 using Tapatalk
2008 Sport Edition - GONE
2020 TRD ORP
trey99ek is offline   Reply With QuoteReply With Quote
Old 07-20-2020, 01:47 PM #11
Mudhorn's Avatar
Mudhorn Mudhorn is offline
Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough
Mudhorn's Avatar
2” clearance height difference w/ the rise option on the stealth compared to the Ranger.
I would agree it is looks with most. I had the Ranger rack on another vehicle and it looked a lot bigger in person (so to speak). I didn’t feel a lot of advantages with the Ranger vs Stealth. Only difference in my setup was the type of lights used, light bar seems good on the stealth. I found round lights more protected on the Ranger (personal feeling).
Personally I like the stealth since it is a daily driver and every inch counts (that’s what she said) for my garage, etc. Plus I like the look and had no issues with functionality.
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
Mudhorn is offline   Reply With QuoteReply With Quote
Old 07-20-2020, 02:02 PM #12
JSparky's Avatar
JSparky JSparky is offline
JSparky is a jewel in the rough JSparky is a jewel in the rough JSparky is a jewel in the rough
JSparky's Avatar
x2 to all the comments on measuring tent dimensions.
The Gobi stealth is pretty quiet, much quieter than front runner on these vehicles.
Lastly, depending on what you’re carrying, consider a tent that can accept crossbars. Autohome comes to mind, and GFC tents are designed to replace the rack altogether, featuring accessory rails built into the tent itself.
67' Land Rover 109, 97' FZJ80, 16' 4Runner Limited
http://www.toyota-4runner.org/5th-ge...-jr-build.html
http://www.overlandcookery.com
http://www.schaubphoto.com
JSparky is offline   Reply With QuoteReply With Quote
Old 07-20-2020, 04:23 PM #13
Big B Big B is offline
Big B is on a distinguished road
Originally Posted by 2112 R View Post
How's the trasharoo working out on the ladder? I want to run this setup when my gobi gets here, but I figured it'd leak/dump shit everywhere when the hatch is opened
Big B is offline   Reply With QuoteReply With Quote
Old 07-20-2020, 08:22 PM #14
Mudhorn's Avatar
Mudhorn's Avatar
I have mine installed on the ladder. No issues with stuff spilling out when the hatch is opened.
Only complaints is the hatch is tough to open with the weight of a full trasharoo. You lose some of the space inside the trasharoo since it is installed on a narrower surface compared to a tire. I can fit 2 bags of firewood, but only 1 bag when mounted.
An alternate brand might have dimensions more suitable for the ladder.
Old 07-20-2020, 09:23 PM #15
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
I have the Gobi Stealth with front rise, cross bars and removable sunroof insert.
You. can't beat how good they look.
I have Zero interest in ever having the ladder....
If I ever buy another Gobi, It will be without crossbars, or perhaps removable crossbars.
It seems I can never pack the load the way I want with those damn things in the way.
nglayton is offline   Reply With QuoteReply With Quote
boards , gear , gobi , mount , rtt
Gobi rack owners - any wind noise from your rack? Arv 3rd gen T4Rs 15 02-28-2016 12:32 AM
Gobi Rack GROUP BUY. Stealth Rooftop Rack. Free ladder or sun roof insert reklov 5th gen T4Rs 300 06-26-2012 07:57 AM
Gobi Rack GROUP BUY. Stealth + Ranger Rooftop Rack with FREE Ladder reklov 4th Gen T4Rs 11 06-04-2011 05:05 PM
Gobi Rack GROUP BUY. Stealth + Ranger Rooftop Rack with FREE Ladder reklov 3rd gen T4Rs 21 05-16-2011 09:52 PM
Gobi Rack GROUP BUY. Stealth + Ranger Rooftop Rack with FREE Ladder reklov 3rd gen T4Rs 0 04-21-2011 04:47 AM
