05-09-2020, 11:34 AM
#76
Originally Posted by pableaux
How'd you get your "no questions asked" 125k mile warranty?
I bought it when I bought my Pro.
I work at the dealership as well.
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
05-10-2020, 02:34 PM
#77
34s without extended bumpstops will result in this offroading. Red circled part is suppose to be flat. Pinch welds need to be hammered flush also
05-11-2020, 11:32 AM
#78
Longv, What suspension and lift were you running when your 34 slammed up inside the the wheel well and created the dent? What extended bump stops are you going to put on?
Thanks for sharing the info.
05-11-2020, 11:37 AM
#79
Originally Posted by ryguytheman
I don't understand why both sets of 285s are so different width-wise. Shouldn't they be the same? And as for how the 275s are wider than both...
Isn't "X" in X/Y/rZ the width measurement?
Yes - they should be the same. It really shows how different various tires are that have similar size labels.
05-11-2020, 11:46 AM
#80
Can you tell us more about your setup? Namely suspension, control arms, and caster setting. I'm also curious. I haven't had any of those issues with 34's. I'm not racing competitively, but I've pushed it fairly hard and haven't found any issues with rubbing or contact in the front (outside of the normal mud flap and BMC that were necessary to fit).
My setup is stock LCA (with KDSS), stock bump stops, stock wheels sometimes with 1" spacers, sometimes without, Fox 2.5" front coilovers, and JBA UCAs. I set my caster pretty high - around 4.5 - and I'm set at around 2" lift height, but I've gone everywhere from 1-3" height over the years.
I do actually get some minor rub on the inner fender liner in the rear in the whoops at speed if I push it. But nothing up front.
05-11-2020, 03:38 PM
#81
At the time dobsinsons 2.5fr 2rear, dirt king upper arms. Ripped out both fender liners, pushed back and bowed out the fenders by the bottom near the door. Bent spindles and/or lower control arms
My current set up is fox 2.5 all around, dirt king lower kdss arms, wheelers offroad bumpstops, new spindles with gussets welded in.
05-11-2020, 04:12 PM
#82
The Dirt King LCA's seem to be the big difference I see. It seems likely to be the case that the LCAs do not share the same relationship with up travel and bump stop contact so they would allow more up travel before contacting the bump stops.
05-11-2020, 04:15 PM
#83
I have extended bump stops; Toytec in the rear and Energy Suspensions in the front.
I added these to avoid damaging my shocks and struts.
I did, however, do a little off roading and fully compressed the suspension a couple times before replacing the bump stops and did not have any issues in that area. I did catch the inner liner one time, but far from ripping it out.
05-11-2020, 04:39 PM
#84
So what kind of trail situation caused this? High speed or crawling? I've run 34's for years with and without extended bump stops and never had this happen.
05-11-2020, 06:05 PM
#85
I'm thinkin' a 3' jump to cause that much damage.....that's not a Rub but a Pounding!
05-11-2020, 06:44 PM
#86
Damn.... I was going to try a little 3 footer one day
05-12-2020, 01:44 PM
#87
I was in stock lower arms at the time.
Possibly lol
Probably 40mph in the desert, those whoops came out of nowhere lol
05-12-2020, 02:00 PM
#88
Possibly lol
lol ok that explains some of it. What's your wheel offset and what tires do you run btw?
05-12-2020, 03:28 PM
#89
17x8.5 -10 scs ray10 on 285/75/17
04-15-2021, 11:46 AM
#90
Thanks for sharing the info. I have King/Icon 2in rear lift in the back running 295/70/17 Cooper MTs with the -38 offset. When rear wheels are tucked, they are rubbing against the rear doors. My next step was to get the wheelers offroad superbumps. Did you add 1/4" or 3/8" washer? Hoping this will help with the rubbing.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
