Old 04-24-2020, 08:59 PM #31
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Originally Posted by TRDHULK View Post
I basically have a "no questions asked" bumper to bumper 125k mile warranty, so if something happens its not a problem.
I've done all of this in under 3k miles, so I'm sure I'll eventually upgrade the shocks, struts and coils ones day; most likely long before I experience any issues.
I dont feel I'll need to yet, but I've only driven about 35 miles with the new tires.
In my experience you'll end up wanting a re-gear. 34's were what pushed me over the edge to do it. It's considerably better off road, otherwise you'll be feathering the gas and break all the time. On road performance wise acceleration improves as well. I get 15.5 mpg on a mix of street and highway FWIW
As far as rubbing goes that looks good sitting still but it'll rub if you compress it. You'll need to trim your fender liners and maybe hammer flat or trim your pinch welds. If you can push your caster out any further I would consider that too Definitely ditch the spacers
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 04-24-2020, 09:07 PM #32
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
I haven't gone up to 34s yet but moving up to a heavy 33, wow yea the difference offroad...its heinous when crawling. Prioritizing a regear now to 4.88s before a rear bumper now. On road its ok though.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 04-24-2020, 09:12 PM #33
comtn4x4's Avatar
comtn4x4's Avatar
Yeah there's no such thing as a light 34 either. I've been really happy with 4:56 gears even when I had 305/70's. My rig would have to be considerably heavier or on 35's to want 4:88's.
Old 04-24-2020, 09:17 PM #34
CRB Racing CRB Racing is offline
CRB Racing has a spectacular aura about CRB Racing has a spectacular aura about
Wow! Looks good.
So at full lock in Reverse the tires don’t rub the front bumper?
CRB Racing is offline   Reply With QuoteReply With Quote
Old 04-25-2020, 01:00 AM #35
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
Originally Posted by Xtremluck View Post
Something to think about. That nice fancy Fox suspension isn't going to last very long with your spacer setup. Especially if you are using your rig offroad which I'm guessing you are given you're running dedicated mud tires.
I think there are a lot of folks on here running 34s/35s with no major issues. If you remove your spacers you will rub even less.
You'd be surprised, that's a big assumption. Lot of these builds are nothing more than 'gram builds. I'm willing to bet this thing isn't going to see more than a dirt hill. There's going to be plenty of rubbing if that suspension is flexed out but not sure that's going to be an issue here.
One of the lighter 34" MT (well 295/70/17) I've seen is the Cooper Evolution MT weighing about 59lbs. They're only 2 ply sidewall though so I'm guess that's where they shed some weight.
They come in pretty cheap too
https://www.walmart.com/ip/Cooper-EV...Tire/761428538
I'm still riding on 285/70/17's and with all the weight I have I won't go with a bigger tire until I re-gear. She's right at the tipping point where it's still tolerable but I don't think it would drive well at all with a bigger tire.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 04-25-2020, 02:46 AM #36
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
Looks great! With the spacers removed you will gain some clearance. I think the tire is wide enough that it will still have a bold stance without spacers. Good luck when you get it off road.
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 04-25-2020, 09:11 AM #37
DallasTRDPro's Avatar
DallasTRDPro DallasTRDPro is offline
DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light
Great stance!! How's the ride quality with the Burtman spacers?
DallasTRDPro is offline   Reply With QuoteReply With Quote
Old 04-25-2020, 10:49 AM #38
comtn4x4's Avatar
comtn4x4's Avatar
I looked at the Evolution and the Cooper AT3 LTX is another relatively light AT that is worth considering too. My St Maxx's are very heavy but the off road performance and durability is worth it to me.
As far as the jump to 34's goes it frankly doesn't add much. At best you are gaining a 1/2" ish clearance, probably less when airing down.
And as you said it just an appearance/cool factor thing to most. Not rubbing seems to be judged by coming off a curb or hitting a pothole.
Old 04-25-2020, 11:02 AM #39
itr1275 itr1275 is offline
itr1275 has a spectacular aura about itr1275 has a spectacular aura about
Dumb question - What is BMC?
itr1275 is offline   Reply With QuoteReply With Quote
Old 04-25-2020, 11:27 AM #40
sleepsontoilet sleepsontoilet is offline
sleepsontoilet will become famous soon enough
Body Mount Chop. The front tires will rub the body mount if you don't trim it back even with the fender well. Also a good idea to hammer the pinch weld flat there as well, so you don't slice up your new tires.
sleepsontoilet is offline   Reply With QuoteReply With Quote
Old 04-25-2020, 11:30 AM #41
Thanks and it makes senses.
I've seen the pinch weld thing as well.
Old 04-25-2020, 12:48 PM #42
TRDHULK's Avatar
TRDHULK TRDHULK is offline
TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold
TRDHULK's Avatar
Originally Posted by CRB Racing View Post
Wow! Looks good.
Thank you!
It would have rubbed, but the Pro's are trimmed at the port, and I trimmed another 1/4" and already moved the liner forward.
I'll be wheeling it tomorrow and will trim as needed. I bet I end of taking off another 1/4" to a 1/2" off the bumper, just to play it safe. the BMC should not give me any problems though; I think I cut it enough. My RSG plates should be here next week so I can weld them up.
Its not bad. The larger tires actualy make the ride better than the stock Nittos with the spacer lift.
At slow speeds, I can feel that they are MT's. On The Highway, so far, I think the ride is great.
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
TRDHULK is offline   Reply With QuoteReply With Quote
Old 04-25-2020, 12:53 PM #43
TRDHULK's Avatar
TRDHULK's Avatar
I'm going to take good care of my 4Rnr, but it is in no way just a "gram build." I've already had it off road 4-5 times in the month I've owned it, and will be doing some more serious stuff this weekend, hopefully.
Isn't a 295/70 typically a 33.5"? These 285/75's are showing 34.1"
I can't find how much this tire weighs anywhere. They feel a little heavier, but honestly the extra weight kind of makes the truck feel more planted, and maybe more substantial. It only feels slightly more sluggish. I really don't think I'll regear unless I go 35's in the future.
BTW, what does a re-gear in these usually cost?
Old 04-25-2020, 01:13 PM #44
comtn4x4's Avatar
comtn4x4's Avatar
The Yokohama MT's weigh 63.3# per the Yokohama website. My same size Coopers are 65# in a AT as a reference.
A 285 /75/17 is by the exact metric measurements 33.83"x11.22". Your Yokohamas as with my Coopers are a bit taller at 34.1".
A 305/70/17 is also considered to be a 34" tire at 33.81"x12.01". They are considerably harder to fit due to the extra width.
I haven't checked re-gear costs since I re-geared my rig about 3 1/2 years ago, to give it a guess, using a pre-built clamshell from ECGS and average labor at a reputable shop I'd say $2500-$3000
Here's a link to some details on the re-gear. Search and you can find lots more info
Review: East Coast Gear Supply Gear Swap
Old 04-25-2020, 02:47 PM #45
TRDHULK's Avatar
TRDHULK's Avatar
Thanks for the info.
So it seems the Geolandar is fairly light for a 34" MT. More good news!
Aaaaaannd I'll be holding off on the re-gear at that price lol. This is just my daily driver that I'll have fun with whenever I can.
34s , end , fit , make , world
