Old 04-30-2020, 12:25 PM #16
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Originally Posted by JSparky View Post
I went from Dobinsons 701v to OME 899 to Dobinsons 749v.
With all the weight I carry I was finding the 701’s a little soft. The 899’s were great but I missed the down travel variable coils gave me. Attempted to mediate this with some poly spacers, but ended up going 749v when they came out and love them. I have a hybrid extended travel shock with 2” bump stop extensions and rarely bottom out.
I still prefer the predictability of a linear coil like the OME for on-road, but off-road you cant beat the travel of a variable rate.
The Dobinsons will ride tall when unloaded, where as a linear coil will just ride firmer (little tall, but within range). What this means is you may need to look at other components depending on your specific setup, like rear control arms to correct your pinion angle, longer sway bar links, etc, depending on typical ride height.
I admittedly went pretty tall with my build, probably running the 749v’s on the lighter side, but when loaded up for a trip it’s nice and level, which is how I like it.
For what it’s worth, I sold my 899’s to a buddy with no rear bumper, just a drawer system and fridge, and he doesn’t think they’re too stiff. Your results may vary.
This is a great set of examples. Thanks for providing it.
My experiences with the Dobinson's variable rate coils (677v & 701v) is very similar to yours although I've never run the OME's. The Dobinson's coils do stand a bit tall unloaded but not negatively so.
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 12:27 PM #17
comtn4x4's Avatar
comtn4x4's Avatar
Originally Posted by Xtremluck View Post
I know Dobinson has come out with some heavier variable coils but at the time the heaviest option didn't seem enough. I had a guy I know on them who had a similar setup as me and he was sagging. The newer options may be better.
I'll have to look more into the OME coils. Although I'm pretty happy with my current setup. Thanks
Old 10-20-2020, 09:09 PM #18
TheWraith's Avatar
TheWraith TheWraith is offline
Real Name: Justin
TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light
TheWraith's Avatar
Real Name: Justin
The dobinson 749v how much lift are you??? I'm looking to replace my 3" icon Overland springs. As even now I just have a hitch tire carrier and it's already sagging w/ my 3rd row... I would like to maintain a 3" which is level with my 4.5" in the front
My Build Thread
My kids call it ROCKY
2014 Raptor Liner White TEP w/ some mods.
TheWraith is offline   Reply With QuoteReply With Quote
Old 10-20-2020, 09:17 PM #19
cmilviper's Avatar
cmilviper cmilviper is offline
cmilviper is just really nice cmilviper is just really nice cmilviper is just really nice cmilviper is just really nice
cmilviper's Avatar
I'm still running the Icon Overland 3'' springs with a 15mm Dobinson's spacer on top of the Icon springs. Currently I have about .75'' of rake when unloaded.....but it decreases quick when loaded down, and I want to maintain about a 1'' rake when fully loaded.
I currently have the 701V's and the OME 899's in the garage that have never been installed.
I've been thinking about going straight to the 749V's, or maybe trying the OME 899's w/ the same 15mm spacers, if needed, to get the height I want in the rear.....Interested to see what you end up doing, as well as any further info from @JSparky ..
2017 4Runner TRD Pro - Cement Icon RR CDCV (700 lb) w/ Icon Delta Joint UCA's/Billet Rear Link Arms || Icon Overland 3'' Rear Springs+Dobinson's 15mm spacers on top || C4 Fab Sliders || CBI Front Bumper || Shrockworks Rear Bumper || Gobi Stealth Rack/Ladder || Baja Designs & Rigid Lighting || 285/75r17 Toyo MT's (34") || Safari Snorkel || ARB Diff. Breather Kit || Spidertrax || ARB Awning 2000 || Maxtrax || XD Philips 4300K HID's || Warn Winch/Factor 55 || IKamper Skycamp 2.0 4X || SCS Ray10's || Durobumps
2015 4Runner TRD Pro - Super White (Wife's) Icon Stage 2 w/ Icon UCA's || Toytec Superflex HD Rear Springs || Expedition One Sliders || 285/70r17 BFG KO2's || Gobi Stealth Rack/Ladder || 40" Rigid Radiance || Spidertrax || XD Philips 4300K HID's || Philips Yellow LED Fogs
cmilviper is offline   Reply With QuoteReply With Quote
Old 10-20-2020, 10:18 PM #20
TheWraith's Avatar
Real Name: Justin
TheWraith's Avatar
Real Name: Justin
I weight my 4runner without new front skids tire carrier w/ the stuff on it and pumpkin skid. I was 5660lbs
So currently I have just a tire carrier (80lbs) w/ a 35" spare( 86lbs), a hi lift, traction boards, and a 3rd row... I'm going to go tomorrow to weight again at the truck scale.
And as of right now... my 4runner has a small squatted stance. And I have 3" Overland springs. I'm afraid that with the rear bumper comes it'll squat even more. This will be furtherly worsen by having 6 passengers and all our camping gear.
My Build Thread
Old 10-20-2020, 10:40 PM #21
comtn4x4's Avatar
comtn4x4's Avatar
I think the 749v would be too stiff for that weight. I have about 425# over stock behind my rear axle and run the 701v and it's just a bit too stiff, about 3.25". I have some drawers on the way that should correct it. It rides fine just too tall for what I want. Loaded up it's fantastic.
Old 10-21-2020, 11:53 AM #22
JSparky's Avatar
JSparky JSparky is offline
JSparky is a jewel in the rough JSparky is a jewel in the rough JSparky is a jewel in the rough
JSparky's Avatar
I can get back to you later today, I’m honestly not sure.
Anyone know of a free vehicle scale in the Bay Area?
67' Land Rover 109, 97' FZJ80, 16' 4Runner Limited
http://www.toyota-4runner.org/5th-ge...-jr-build.html
http://www.overlandcookery.com
http://www.schaubphoto.com
JSparky is offline   Reply With QuoteReply With Quote
Old 10-21-2020, 03:47 PM #23
JSparky's Avatar
JSparky's Avatar
Just measured, from the asphalt to the bottom of the rear fender flare I’m at 41.5” and 41.75”, respectively. That’s with 315/70r17’s (saw you have the same tire size). I can measure from the center of the hub when I can get an extra pair of hands.
That’s unloaded, which for me means rear bumper plus full size spare, Autohome Columbus rtt, empty fridge and full tool box.
I’ll have to update my build thread with current stats.
Old 04-07-2021, 04:02 PM #24
TheWraith's Avatar
Real Name: Justin
TheWraith's Avatar
Real Name: Justin
just an update ...
6240lbs was perfect with the 749V but as soon as I load it with my family of 6 ... we're at 7100 to 7200lbs; 749V still good.
but with full camping gear for 5 days ... I'm at 7960lbs and 749V isnt enough ... so I ended up adding bags.
ended up using Air Lift Kit #60920; which was perfect because theres a 1" gap from the bump stops ( I cut 2 off ) so it doesnt restrict flex even at only 5psi.
My Build Thread
Old 04-07-2021, 06:34 PM #25
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough
just an update ...
DAYUM that's a heavy rig
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 10:00 AM #26
comtn4x4's Avatar
comtn4x4's Avatar
just an update ...
Damn dude that's loaded up! I nominate you for most loaded 4Runner! I loaded up pretty heavy but nothing like you.
Old 04-08-2021, 02:56 PM #27
TheWraith's Avatar
Real Name: Justin
TheWraith's Avatar
Real Name: Justin
Yeah cuz of the weight I'm exploring the options of getting a trailer and towing that weight instead of having it on top and in the back.
My Build Thread
Old 04-08-2021, 04:04 PM #28
comtn4x4's Avatar
comtn4x4's Avatar
Yeah I have started to consider the same thing. Although the kids are getting old enough that camping isn't "cool" anymore lol.
Old 04-08-2021, 04:07 PM #29
TheWraith's Avatar
Real Name: Justin
TheWraith's Avatar
Real Name: Justin
Looking at a half cut ... a buddy of mine has a half cut 2nd gen with electric and sleeping platform.
But I don't know
My Build Thread
Old 04-08-2021, 05:43 PM #30
camping is always cool!
bumper , icon , i’m , rear , springs
Fox 2.5 rear with DSC specs for07+Tundras Icon 2in rr spring Kaleo For Sale: Suspension/Wheels/Tires 2 05-02-2020 06:12 PM
Icon rear coil spring 2" for $150 in utah area Mgltacoma For Sale: Suspension/Wheels/Tires 1 06-03-2019 01:28 AM
FS: Icon Vehicle Dynamics 2" Rear Spring, $150, Southern California VTXWheels For Sale: Suspension/Wheels/Tires 1 02-15-2017 10:45 PM
5th Gen - Icon rear spring (almost new) $200 + shipping Elpaca19 For Sale: Suspension/Wheels/Tires 10 03-04-2014 05:00 PM
ICON Rear Spring install - do I have to mess up the rear brake lines? KodeRush 5th gen T4Rs 8 02-20-2013 10:44 AM
