04-28-2020, 01:11 PM
Dobinsons 2.5" lift kit
Hey all,
I'm looking to possibly buy a Dobinsons 2.5" lift. I tried searching and it seemed very scattered so can I see some examples of the Dobinsons 2.5" lift and what size tires you have?
Thanks!
04-28-2020, 01:30 PM
I've got the Dobinsons IMS lift with C302 front coils (2.5") and C725 rear coils (2.0" w/KDSS) and I'm on 255/80R17 tires (33.1" x 10")
I've got no rubbing, including some off-road fun.
04-28-2020, 01:35 PM
I literally just found your 4runner in another thread and saved the pics because its perfect! Thanks for the specs! I don't think I'll go THAT nice of a Dobinson's kitbut damn that looks good. Hows it ride?
04-28-2020, 01:45 PM
Thanks! The ride is excellent - took about 200 miles for the rear end to break in nicely, but now that is has I'd say it rides better than stock. Eats up bumps, almost zero nose dive, reduced body roll, and the tires are pretty quiet with great traction.
I just went out on BLM land and did some camping/wheeling this weekend. From filling up 1 mile from my house, putting on just over 200 miles (including wheeling/loaded truck/highway driving) I averaged 19.1 MPG - I've VERY happy I went skinny tires vs 285's, thinking that helped (they don't look THAT skinny on the truck, I was really concerned before install).
I only ordered this lift because of the great promo going on in February - I was considering going with the standard but the air compressors for those were already gone, and I was going to be dropping a few bucks for a compressor anyways. Plus being able to rebuild was a benefit for me long term / high mileage a year vehicle.
04-28-2020, 03:36 PM
Running the same coils as Sundy but with the twintubes instead.
285/70 + Full skids (Everything steel except fuel tank and front) + Front bumper/winch + sliders + 150lbs of constant weight in the rear
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
04-28-2020, 04:15 PM
See Signature...
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
04-28-2020, 05:56 PM
IMS shocks, 302 fronts, 505 rears
Falken Wildpeak 285/70/17
04-29-2020, 08:38 AM
Dobinsons C509-302/GS59-700, C59-505/GS59-705, UCAs for me. 2.5”/1.5” with stock sized KO2s.
2019 MGM TRD ORP
BFG KO2 265/70-17
Victory 4x4 Blitz Bumper w/Zeak 12000
03-22-2022, 12:59 PM
Any chance you could send me some pictures of your rig? I just bought that exact same set up today, but it’s on back order for two more months. I’d like to get an idea on what it might look like from different angles.
03-24-2022, 11:25 PM
Never mind… didn’t realize this thread is ancient
Current: 2018 SR5P XP; Dobinsons c59-314/MRA59-A574(F) c59-505/MRA59-A701(R); Dobinsons PS59-4030 (driver); Dobinsons UCAs, rear sway bar links, and diff drop; Nitto Trail Grap 285/70R17; Bash Fabrication Sliders; Bash Fabrication lo-pro front bumper; Badland Apex 12k winch; Baja Designs Squadron fog lights and 20" S8; Diode Dynamics LED reverse lights; Victory 4x4 crossbars; BPFabricating molle pet barrier; Victory 4x4 front/mid/tcase skids; EVC throttle controller; front sway bar delete; ARB Diff Breather kit; Spidertrax; Total Chaos weld on spindle gussets, BMC with pinch weld mod
03-25-2022, 04:59 PM
Are you still happy with the ride from the ims shocks, tire size and fuel mileage?
03-28-2022, 05:19 PM
Overall I'm still very pleased! There are a few things I would change, but nothing major. At this point I've got 43K on the lift/tires and have figured out all my wants needs. The shocks themselves ride the same as the day I installed them and show no signs of leaking or squeaks. Around 7K of those miles are on FS roads/trails.
1. I would go with the extended travel front shocks if I did it again. After adding a lo-pro bumper, winch, roof rack, and front skid - the front has settled a lot. I did take it apart and raise the spring perches to gain a lot of it back, but there's a limit of too much pre-load and diminishing returns.
2. The UCA's have been great! I'll recommend them to people day in and day out.
3. MPGs - these have dropped a bit, after the addition of mods. I did sit right around 19 MPG for close to 20K with the lift. I'm assuming a combo of winter driving/fuel, adding a roof rack, and having more stuff (front bumper/winch/skid). I'm sitting around 17-17.5 average. With skis and such on top it drops to 16.5-17. I'm seeing no real change when I have the RTT installed (Osprey Slimline).
4. Tire size - I did add 1.25" spidertrax spacers, that helped a lot and I've been happy with the look. When I get new tires I plan to get new wheels and also step it up to 285/75R17 (34" x 11.5"). This is where the extended travel shocks would have been nice. Depending on rub, I might need to get SPC's for the adjustability, but that's going to be a last case scenario.
2019 TRD ORP w/KDSS: Dobinsons IMS Lift (front C302 - 3" / rear C725 - 2.5"), Freedom Offroad UCA's, Falken Wildpeak AT3W 255/80R17, RSG Angled Kickout Sliders & Skid Plate, C4 Lo Pro, Warn Evo 10S, Agency 6 Flatlink, Diode Dynamics SS3 Fogs, Desert Does It Seat Jackers, Sherpa Crestone Rack, Outer Tents RTT
03-28-2022, 08:30 PM
I’m doing the same lift, 2.5”/1.5”. Hoping to stuff 285’s on stock wheels underneath.
Sent from my iPhone using Tapatalk Pro
2016 White SR5 4Runner / T Force Package
05-31-2022, 11:10 PM
Sorry for the (really) late reply. I’m not on this forum very often. My build thread is here, so hopefully you can get the views you seek.
Chris in Milwaukee's "CheeseRunner" build | Toyota 4Runner Forum [4Runners.com]
I’ll be looking for photos of your rig as well!
2019 MGM TRD ORP
BFG KO2 265/70-17
