Old 04-29-2020, 02:57 PM #1
bokehshooter bokehshooter is offline
bokehshooter is on a distinguished road
Switch Pros and Baja Designs Wiring
Hey all! I have a SP 9100 already installed and will be working on wiring in some BD lights next.
The Squadrons and S2s both come with a harness. My question to you all is did you all use the included wiring harness (at cut off the relay and switch) or did you use the included weatherpack connectors and do your own wiring?
If you used the weatherpack connectors, is soldering needed or did you just use a heat shrink connector to connect the 2 lights together and run a single wire to the switch pro?
I know with the S8 lightbar, it does not include a harness so I will be using the weatherpack connector and 12awg wiring for that.
TIA
bokehshooter is offline   Reply With QuoteReply With Quote
Old 04-29-2020, 10:50 PM #2
jdm-v35 jdm-v35 is offline
jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough
I used the DIY connectors it came with, but to do it properly you need the special crimper for those to "fold" the connections over.
jdm-v35 is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 12:39 AM #3
Thanks! I did order a weather pack crimper so will make sure it's done right.
I ended up cutting the harness for the ditch lights but I think I will use the weather connectors for the S2 lights that I will be running for chase and side lighting since I would need to extend the harness anyways if I were to chop those up.
Anyone else have some feedback? I think I will be using 14awg wires for the S2's and 12awg for the S8.
Old 04-30-2020, 06:55 PM #4
Baja Designs Baja Designs is offline
Baja Designs will become famous soon enough Baja Designs will become famous soon enough
If you're using a Switch-Pros, I would buy a big spool of wire and run your own leads from the lights. This way you can make everything cut to fit. If the wiring harness that came with the lights is long enough, you can use it as a pigtail to the Switch-Pros. You would disconnect it at the switch. For gauge of wire, it just depends on length and amperage of the light.
S2 Sport .9 amps each
S2 Pro 1.7 amps each
Squadron Sport 2 amps each
Squadron Pro 3.33 amps each
S8
https://www.bajadesigns.com/images/S...ta%20Sheet.pdf
Blue Sea systems has a great chart that tells you what gauge to use.
Part 1: Choosing the Correct Wire Size for a DC Circuit - Blue Sea Systems
Baja Designs is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 05:50 PM #5
S8
Thanks for the info! I also called you guys and you were extremely helpful with my questions so much appreciated!
Old 05-01-2020, 06:53 PM #6
Happy to hear that! Let us know if you need assistance.
Old 05-01-2020, 09:54 PM #7
SnowYeti's Avatar
SnowYeti SnowYeti is offline
SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough
SnowYeti's Avatar
Doesn’t hurt to have some spare connectors on hand that Baja uses to do custom work.
Amazon.com: Delphi Packard (2 Circuits) Weatherpack, Waterproof, Terminal Kit 18, 20 GA (Pack of 3 Set): Automotive
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
SnowYeti is offline   Reply With QuoteReply With Quote
Old 05-02-2020, 02:08 PM #8
As recommended, I am trying to use some 12 gauge wires for the S8 but unfortunately the weatherpack it comes with, looks like will only fit a 14-16 gauge wire.
I guess I will need to buy a different 3 pin weatherpack connector for 10-12 gauge?
harness , lights , switch , weatherpack , wiring
Baja Designs Ditch Lights w/Switch Pro 412Runner 5th gen T4Rs 5 02-11-2021 05:01 PM
Help: Baja Designs Dimmer/Strobe to AOB switch inv3nt 5th gen T4Rs 2 01-06-2019 06:08 PM
Baja Designs "pods" & wiring question doctorres112 5th gen T4Rs 2 01-27-2018 07:27 PM
? about wiring Baja Designs S8 light caspian45 5th gen T4Rs 2 12-16-2016 12:21 PM
New Baja Designs S8 LED Light Bar - Replaces Baja Designs Stealth - Now Shipping TotalAutomotiveLV Engines / Suspension / Wheels / Tires / Audio / Accessories 2 06-03-2016 08:24 PM
