Old 04-29-2020, 05:24 PM #1
pck823 pck823 is offline
pck823 is on a distinguished road
Low beam not working-weird problem
I upgraded by headlights to Xenon Depot's LED's several years ago. Had one low beam go bad and they replaced it without any fuss - good experience.
Fast forward 1 year - same thing occurs, same headlamp (driver's side). They send a new LED and driver. Replaced both - still not working. Tried taking known good light and driver from opposite side of vehicle. Still not working.
I checked both 10A low beam fuses - 0 ohms, not blown. BUT, only the passenger side fuse ever sees 12 volts. Pulled the fuse for the driver's side low beam, and no voltage in the fuse socket. Found the low beam headlamp relay and swapped it with another identical relay - still no light.
Anyone else experience something like this? This is a relatively new vehicle so I wouldn't think a wire would open up in a harness somewhere between the battery and fuse box, but I guess its possible...
pck823 is offline   Reply With QuoteReply With Quote
Old 04-29-2020, 07:19 PM #2
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Sounds like you have done all you can without a wiring diagram. If you don't have power in the fuse block on the supply side of that fuse, I would start there and work back with a drawing for your vehicle model and year.
There are drawings as part of the manuals Nashman posted several years ago. Link should still be in the stickies. They are for a 2011 I think, so may not be correct for your vehicle.
Old 01-30-2023, 01:21 PM #3
K4Run K4Run is offline
K4Run is on a distinguished road
Did you ever solve your issue?
- 2019 TRD PRO
K4Run is offline   Reply With QuoteReply With Quote
Old 02-02-2023, 09:28 PM #4
Haze25 Haze25 is offline
Haze25 is on a distinguished road
Also wondering if this was solved. My 2018 with the same setup just did the same thing.
Haze25 is offline   Reply With QuoteReply With Quote
Old 11-27-2023, 04:19 AM #5
Dune4Runner Dune4Runner is offline
Dune4Runner is on a distinguished road
Would love to know how any of you solved this same problem here!
Dune4Runner is offline   Reply With QuoteReply With Quote
beam , fuse , headlamp , low , side
Low/High Beam Headlights not working Bimmerod 3rd gen T4Rs 3 03-22-2016 12:10 AM
Low Beam On Driver's Side Not Working ngfilla94 3rd gen T4Rs 1 10-13-2012 10:45 PM
Weird Problem: Volume control not working. Help! Toy4R4Me 4th Gen T4Rs 2 03-30-2011 08:56 PM
