Old 04-30-2020, 08:19 PM #1
Thrasher_S's Avatar
Thrasher_S Thrasher_S is offline
Thrasher_S will become famous soon enough
Thrasher_S's Avatar
RCI Skids, keep plastic piece?
I'm in the middle of installing the full set of RCI Aluminum skid plates and I was chased inside by unexpected rain.
My question is: For those of you with these installed did you, or did you not, keep the plastic piece that was attached up under the radiator and filled the gap between the front bumper and the factory skid?
It still attaches to the bumper side, but I don't see a way to get it attached on the skid side, so it would still do it's job, but would rattle unless I rig up something to keep it in place. I'm guessing it's not needed, but it might provide some marginal protection for the radiator or something.
Also, an extra detail, when I dropped the factory pan a LOT of dead bees fell on the ground, so be sure to sweep if you are going to be lying on your back like I am.
2018 TRD Off Road Premium - Barcelona Red
Thrasher_S is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 08:23 PM #2
ZenArcade ZenArcade is offline
ZenArcade will become famous soon enough
I had it on for a bit ... attached (soft of) as you mentioned. Then I bought the filler: Bumper Filler Plate | 10-Present 4Runner – RCI Off Road
If I replace the bumper, it will be a waste of $65 bucks (-15% sale w/ code SPRINGTIME) if I replace bumper at some point but it's only money.
ZenArcade is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 09:56 PM #3
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
I bought the filler plate too, happy I did.
Kinda hard to see but:
https://www.toyota-4runner.org/3334688-post59.html
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 10:46 PM #4
Thrasher_S's Avatar
Thrasher_S's Avatar
I didn't know that existed! Thanks for the coupon, I might have to pick something else up too...
Old 05-01-2020, 12:07 AM #5
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
I just kept the plastic piece.
delloro is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 07:49 AM #6
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
looks like fabricating a filler plate would be pretty easy using some thin metal from the hardware store.
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 08:01 AM #7
safdSA safdSA is offline
safdSA is on a distinguished road
+1 on keeping the plastic one till I got the RCI part. My plastic one stayed on fine, but the RCI one is cooler.
safdSA is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 09:49 AM #8
jrandom's Avatar
jrandom's Avatar
You are not at all wrong, cost-wise it’s going to be sixes (especially if you buy youR material from a hardware store), definitely if you powder coat it.
2013 TE w/ KDSS Nav
Old 05-01-2020, 10:38 AM #9
heck, for all that piece does, I was thinking some thin sheetmetal and flat black rattle can... or whatever color to match the particular skid plate i suppose.
Old 05-01-2020, 11:00 AM #10
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
It will fall off eventually.
One day I looked down there and it was gone.
Driving through deep snow is probably what killed it.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 11:16 AM #11
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
I got one and even put on the TRD red letters that are made for the TRD Pro skid. Looked good until I hit a tree stump on a 4x4 road. It bent but it actually did provide some protection.
Also I rattled canned the edge of my aluminum skid. Aluminum just got too much of a whip to clean every so often with aluminum cleaner.
RCI Skids, keep plastic piece?-trd-jpg
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 05-01-2020, 02:28 PM #12
jrandom's Avatar
jrandom's Avatar
It actually helps protect your, ugh... plastic, radiator and A/C condenser from debris, either flung up or driven in to. Its like 14 or 16 guage steel, decent for brush small limbs. ect.
RCI Skids, keep plastic piece?-img_0989-jpg
2013 TE w/ KDSS Nav
Old 05-01-2020, 06:47 PM #13
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
the RCI filler plate is worth it. It's decent gauge steel and powder coated. It offers decent protection against trail brush. It also doesn't disappear/get lost as easily as the plastic OEM one. I lost my plastic OEM somewhere after crossing a washed out road.....
I even modified it to use with my after market bumper to fill in the radiator gap.
Old 05-01-2020, 08:04 PM #14
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
I just made my own.......https://www.toyota-4runner.org/attac...1&d=1588377823
RCI Skids, keep plastic piece?-20171223_112006-jpg
83Mule is offline   Reply With QuoteReply With Quote
Old 05-05-2020, 09:21 AM #15
batex batex is offline
batex is on a distinguished road
I kept the plastic piece after I installed my RCI skids. I just used the factory bolts on the bumper side and then strapped a stout bungie cord across the other end. The bungie keeps the loose side tight up against the skid plate. Not noise, no rattle. I assume it will get tossed when I add a SSO slimline bumper.
batex is offline   Reply With QuoteReply With Quote
attached , bumper , rci , side , skid
What is this extra piece of plastic in my new T4R? wareagle2882 5th gen T4Rs 4 05-25-2015 12:29 PM
FS; 5th gen BudBuilt 5 piece combo skids plates Philadelphia PA ($950) Alex T4R For Sale: T4R Items 6 11-25-2014 09:39 PM
Cheap Plastic Piece Dilong26 5th gen T4Rs 6 03-19-2013 08:26 PM
Cracked the plastic piece under bumper. MpJustice 5th gen T4Rs 15 02-06-2013 09:03 PM
oil pan plastic piece undercar 08UrbanRunner08 4th Gen T4Rs 8 07-24-2008 03:28 PM
