Old 05-29-2020, 10:22 PM #16
Signal Signal is offline
Signal has a spectacular aura about Signal has a spectacular aura about
Originally Posted by PopsSmurf View Post
I'm getting a a decent steering wheel shake when I get up to about 50mph and it goes away around the 60-65 mph range.
The background is that this is an almost new 2020 TRDOP w/KDSS. I just leveled the front end with Bilstein 6112's, installed new Falken ATW3 in stock size on new OEM TRD wheels. Also installed Bilstein 5100's in the rear without changing the rear springs. I installed the new coilovers and shocks myself. It has approximately 5k miles on it. The new tires were installed on the new wheels and obviously balanced at that time. After a few hundred miles I finally got it in to the dealer for it's 5K service and had it aligned at the dealer. It was pretty far off after the new coilovers were installed but since I didn't even lift it a full 2" it got back into specs easily. I can't really tell if it got any better after the alignment but the wheel shake is still there in that speed range. Before the lift it was perfect from the factory and I can't remember if I did the lift before or after the new tires/wheels were installed (I want to say before and I didn't notice the shake but anybodies guess at this point).
Anyhow, with this COVID-19 I haven't been able to go back to Discount Tire to have them re-balanced yet but I was hoping for any suggestions beyond the tires and alignment. I've looked at countless threads but besides alignment and balancing not too many suggestions of where to focus. If it was my Ford F350 and I was getting the death shake I would loosen and readjust the front track bar. Anyway to reset the KDSS or other components I should be looking at in the front end. I'm hoping it is the tires but who knows.
Thanks
Welcome to the group, I took the 4runner to the dealer on a weekly basis for this issue and I gave up. 20k miles on my 4runner and at 60 the steering wheel shakes bad. they rotated the tires, gave it an alignment, tried different wheels and tires and nothing made it better. I bought a 3 inch lift and just ordered new UCA's. next will be wheels and tires. If it's still there aft that the dealer is not going to have a good day.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
Signal is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 10:36 PM #17
DEF4Runner's Avatar
DEF4Runner DEF4Runner is offline
DEF4Runner will become famous soon enough
DEF4Runner's Avatar
I really hate to recommend this because the truck is relatively new, but check the brake calipers. If there's a seized piston, it'll give you wheel shake. I dealt with this issue for quite a while on my 4th gen and when I replaced the calipers, it went away and was smooth as glass. I bought the lifetime warranty NAPA calipers and took advantage of it twice until I sold it.
Just remove the caliper and try to compress the pistons in with a c-clamp. If there's one more difficult than the others...could be it. On my 4th gen, it was the inner lower piston that would constantly seize up.
Hate to think it's bad calipers this soon, but maybe that's a possibility.
Good luck!
SOLD 2008 V6 SR5 4X4 @ 165K: 265/70/17 Falken Wildpeak | SPC Racing UCAs | Method NV wheels | Wheeler's T1/T12 springs| Bilstein 5100
2020 Off Road 4X4: 265/70/17 Falken Wildpeak | OME 883/ Wheeler's T13 | Bilstein 5100 | Sprint Booster
DEF4Runner is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 02:25 AM #18
RusPro17 RusPro17 is offline
Real Name: Don
RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about
Real Name: Don
It was the Falken tires on my 2020 Pro. 3 different sets and mounted on my new SCS wheels and shake between 50 and 60. Did not have it before I removed my pro wheels and tires. My Pro only has on it at the time 2000 miles on it. Put Nitto’s back on and smooth as silk.
RusPro17 is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 10:37 AM #19
85GT-79FJ40 85GT-79FJ40 is offline
85GT-79FJ40 will become famous soon enough
definitely tires. Mine was smooth as silk with the OE wheels and General Grabber ATX's even with 1.25" spacers. I already had my suspension on (eibach springs and 5100's with a .75 cornfed spacer out back and JBA UCA's) and it was perfect. Bought a set of Methods and 285 AT3's and it's driven like a POS between about 50 and 65 since. 3 trips to the balancer and it seems better initially but sure enough it's still there and just seems to get progressively worse. Unfortunately I have about 2k miles on the tires and I bought them on amazon so I'm probably hosed. I will probably buy a new set of BFG At's this week. So sick of my nice 67k mile truck driving like a shitbox.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
85GT-79FJ40 is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 12:15 PM #20
DallasTRDPro's Avatar
DallasTRDPro DallasTRDPro is offline
DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light
I barely had it on my Pro. Then I added spacers and it was slightly worse. Then I had my tires rotated and balanced and it sucks at 55-60. I just speed right through that speed so I don't have to worry about it.
DallasTRDPro is offline   Reply With QuoteReply With Quote
Old 05-30-2020, 06:03 PM #21
Real Name: Don
Real Name: Don
I contacted Falken twice. The girl I spoke with was very helpful. You have 30 days to return the Falkens if you are not happy. She even told me after my third set to switch to something else. And I did.
Old 05-30-2020, 07:22 PM #22
yota275 yota275 is offline
yota275 is on a distinguished road
At that speed its almost always a balance issue. Depending on the order in which you got new tires and balanced them and got your lift if could have changed how you sit on your tires even if you got it aligned. I'd see if you can find a place that will check your balance and not just re-balance them to see if that was the issue before you do anything.
2011 SR5 | Billstien 5100s (2.65" in front, 1.5" spacer in rear) | 265x70x17 BFG KO2s | RCI metal works full skid system | Victory4x4 sliders and rear window storage | Rhinorack pioneer platform and backbone rails on the roof
yota275 is offline   Reply With QuoteReply With Quote
Old 05-31-2020, 12:45 AM #23
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
I cant believe this is still problem after 10 years of this model. This has been going on since 2010 folks. Its not the tires, suspension, or any theory you guys came up with... its the design of the steering.. its upsetting that toyota just left that shit alone after all these years
1jzgte is offline   Reply With QuoteReply With Quote
Old 05-31-2020, 07:02 AM #24
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
No vibration either through the steering wheel or through the truck body.
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 05-31-2020, 02:04 PM #25
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
It's been going on since Toyota switched to steering racks on their trucks and SUVs. So '95 with the introduction of the Tacoma, then the 4Runner in '96.
Steering racks are more sensitive to any tire uniformity or wheel run-out issue. Trucks and SUVs have bigger, heavier tires than cars, so any tire uniformity or wheel run-out issue is more likely to be felt.
The upside to using steering racks is that the steering is more precise than the old recirculating ball systems.
So it generally IS a tire or wheel issue. Of course if we're talking an old vehicle with worn chassis components (ball joints, tie-rods, etc.) that can contribute to uniformity/run-out issues being more readily felt.
Some tire manufacturers just do a better job building round tires. I avoid the ones that have a hard time doing that. Having a competent tech installing and balancing the tires also helps.
02SE is offline   Reply With QuoteReply With Quote
Old 05-31-2020, 02:37 PM #26
Nuke's Avatar
Nuke Nuke is offline
Nuke will become famous soon enough
Nuke's Avatar
I've owned 2nd thru 5th gen 4Runners and they all have been a royal PITA to have balanced correctly. It seems the wheels are (were?) lug centric as opposed to hub centric, the later of which will give you a good balance on most any spin balancer. Lug centric wheels tend to require an adapter and most shops don't use them because it takes time. I had a shop do a spin balance, then had them rotate the wheel about 90 degrees on the shaft of the machine and then re-spin it. It was way off.
A shop that has a RoadForce balancer is your next best bet after a COMPETENT Toyota dealer.
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
Nuke is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 04:30 PM #27
When you say trucks and SUV's does this apply to other makes and models? I have no experience with other makes but am curious whether truck/suv drivers just accept this as normal truck behavior?
Old 06-01-2020, 04:43 PM #28
ryguytheman's Avatar
ryguytheman ryguytheman is offline
ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice
Originally Posted by DEF4Runner View Post
Unequal PSI as in 1-2 pounds?
That small of a difference probably isn't contributing much. Over 5, then yes. In my experience.
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
ryguytheman is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 07:44 PM #29
Of course. But not all Trucks or SUVs use a steering rack.
It's not a steering rack issue. The steering rack design is just more sensitive to any imbalance, run-out, or uniformity issue.
Old 06-02-2020, 07:57 AM #30
Salvo Jimmy's Avatar
Salvo Jimmy Salvo Jimmy is offline
Real Name: Ted A Hamilton
Salvo Jimmy is a jewel in the rough Salvo Jimmy is a jewel in the rough Salvo Jimmy is a jewel in the rough
In addition to the causes noted above, I recall a TSB that said improperly torqued lug nut could cause the vibration
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
2022 SR5 Premium 4WD
No Mods, Yet😇
Salvo Jimmy is offline   Reply With QuoteReply With Quote
front , installed , lift , shake , tires
Steering Wheel Shake stever1000 3rd gen T4Rs 52 10-30-2021 03:04 PM
Possible fix for the steering wheel shake 68ChargerJMP 3rd gen T4Rs 3 01-08-2016 03:56 PM
Steering Wheel Shake nvestor88 3rd gen T4Rs 10 07-13-2014 01:40 PM
Steering wheel shake, need help sina518 4th Gen T4Rs 11 12-19-2012 05:46 PM
steering wheel shake rayny1014 3rd gen T4Rs 1 09-17-2007 09:39 PM
