Old 05-01-2020, 02:08 PM #1
PopsSmurf's Avatar
PopsSmurf PopsSmurf is offline
PopsSmurf is on a distinguished road
PopsSmurf's Avatar
Steering wheel shake at 50 - 60 MPH.
I'm getting a a decent steering wheel shake when I get up to about 50mph and it goes away around the 60-65 mph range.
The background is that this is an almost new 2020 TRDOP w/KDSS. I just leveled the front end with Bilstein 6112's, installed new Falken ATW3 in stock size on new OEM TRD wheels. Also installed Bilstein 5100's in the rear without changing the rear springs. I installed the new coilovers and shocks myself. It has approximately 5k miles on it. The new tires were installed on the new wheels and obviously balanced at that time. After a few hundred miles I finally got it in to the dealer for it's 5K service and had it aligned at the dealer. It was pretty far off after the new coilovers were installed but since I didn't even lift it a full 2" it got back into specs easily. I can't really tell if it got any better after the alignment but the wheel shake is still there in that speed range. Before the lift it was perfect from the factory and I can't remember if I did the lift before or after the new tires/wheels were installed (I want to say before and I didn't notice the shake but anybodies guess at this point).
Anyhow, with this COVID-19 I haven't been able to go back to Discount Tire to have them re-balanced yet but I was hoping for any suggestions beyond the tires and alignment. I've looked at countless threads but besides alignment and balancing not too many suggestions of where to focus. If it was my Ford F350 and I was getting the death shake I would loosen and readjust the front track bar. Anyway to reset the KDSS or other components I should be looking at in the front end. I'm hoping it is the tires but who knows.
Thanks
2020 TRD Off-Road Premium / KDSS / Bilstein 6112-5160s / Falken AT3W 265/70 17
PopsSmurf is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 03:31 PM #2
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
In a situation like this it's almost always the tires, or the balancing job. Especially a new vehicle.
Take it back to Discount, and ask them to do a full Roadforce balancing job, (ideally with a Tech that truly knows how to use the machine) and to turn off the 'Smart Weight' feature.
Unless you have an out-of-round wheel, or a tire with poor uniformity (which should then be replaced) they should be able to fix the issue.
02SE is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 04:23 PM #3
mcat707's Avatar
mcat707 mcat707 is offline
Real Name: MURDERED TRD
mcat707 has a spectacular aura about mcat707 has a spectacular aura about mcat707 has a spectacular aura about
mcat707's Avatar
Try mounting your rear wheels to the front and see if your steering wheel shakes or not. If the shake is gone then maybe its either your wheels or tires or both that were originally from the front. If it still shakes, then my guess its suspension related. Maybe your new 6112 shocks are DOA’s? Check your work. Make sure every nut and bolt is secure. Mark them with a paint pen, then check them again after driving it few miles.
mcat707 is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 04:33 PM #4
axel1's Avatar
axel1 axel1 is offline
axel1 is on a distinguished road
axel1's Avatar
It would be nice to know if a rebalance solves your issue.
I've had a shake for over a year on my '14 with AT3w's and I've been to four separate discount tire locations. All of them have balanced the tires and said that they looked fine. Still have the steering wheel shake. I've pretty much ruled out tires at this point but once COVID dies down a bit I'm planning on taking it to one more Discount location to see what they say.
The difference from most people is some days mine isn't there and other days it's really bad. Always around 55-65 mph though. Sometimes it will go away while driving, it's really strange.
The 5th gen's are just super sensitive at that speed I guess.
'14 SR5 in Classic Silver, Wilpeak AT3Ws, miscellaneous electrical odds and ends.
axel1 is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 04:37 PM #5
Chevrolegs Chevrolegs is offline
Chevrolegs is on a distinguished road
I also have a 20 with Falken tires. I have the steering wheel shake at about 60mph but it goes away after a bit. I read somewhere that AT tires develop a flat spot when parked and go away after the tires warm up.
Not sure how true that is but it seems to be the case with mine.
Chevrolegs is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 04:51 PM #6
mizzougrad01's Avatar
mizzougrad01 mizzougrad01 is offline
mizzougrad01 is on a distinguished road
Sounds like your suspension needs a retorque and allignment.
mizzougrad01 is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 06:57 PM #7
Wolfman’s Brother Wolfman’s Brother is offline
Wolfman’s Brother will become famous soon enough Wolfman’s Brother will become famous soon enough
I’ll go another direction than those above.
Welcome to owning a 5th gen. It’s a roll of the dice if this issue will forever haunt your vehicle, or maybe it can be eliminated completely. There are plenty of both outcomes to be found on here.
I got new K02s road force balanced with the special Yota attachment recently and long story short it smoothed out the shake I was getting at 75 and it’s generally silk, but at 58-60 it still shakes if I’m honest. It’s minor enough now to tolerate, but it’s still there.
I don’t set the cruise to 58 and I deal.
People have returned new vehicles over this. It’s a whole thing. Fight it to a point and move on.
2014 Trail Premium - Heritage Grill | TRD Wheels | TRD skid | Bilstein 5100/5160 | 275 KO2s | BD Squadron-R Pro fogs
Wolfman’s Brother is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 09:23 PM #8
SoCalRunner's Avatar
SoCalRunner SoCalRunner is offline
SoCalRunner is on a distinguished road
Easy check
Check the specs on the Tire and find out what the PSI should be. If its under inflated it could cause the steering wheel to shake at certain speeds.
2016 T4R TEP | Maxliner floor mat | KO2 285/70/17/C | Precision Interior LEDs | Ceramic window tint | AVS Aeroskin deflector | Rhino Rack Pioneer Platform | SunSeeker Awning | Fox 2.0 front/rear no res | Icon 52700 | VTX Wheels | Side exhaust | Xenon Depot HID Low Beams & LED fogs
Round Rock, Texas
SoCalRunner is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 09:34 PM #9
engineeer engineeer is offline
engineeer will become famous soon enough
One of the few reasons I got rid of my 5th Gen.
Steering wheel vibration poll -- responses appreciated
Steering wheel vibration Poll
engineeer is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 09:41 PM #10
nwebb01's Avatar
nwebb01 nwebb01 is offline
nwebb01 is on a distinguished road
nwebb01's Avatar
I had those tires on my 3rd gen and had the same vibration issue at the same speed. I got them from discount tire and they didn't mount them with the valve stem aligned with the red dot. Seemed odd to me. Also, each tire had vastly different amounts of weight. I assumed they just sucked at balancing the tires. I was going to go somewhere else to get them balanced, but I just traded in my 3rd gen for a 5th gen last week. It needs new tires, and after reading this, I'm not sure if I want to go with the falcons again. I loved them except the flaw that you and others have seemed to have, apparently.
Sent from my Pixel 3 XL using Tapatalk
nwebb01 is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 04:41 PM #11
PopsSmurf's Avatar
PopsSmurf's Avatar
Update
Finally was able to get into the tire shop to have the tires rebalanced. Road force balancing did the trick. T4R drives like new again! Tech said the original installer just slapped on the weights in one inside location instead of placing them on the wheel width wise as needed. Good guy at Discount Tire who went the extra mile. Took him about 20 minutes top.
Thanks for the suggestions and the most obvious solution usually works!
Old 05-29-2020, 05:44 PM #12
ryguytheman's Avatar
ryguytheman ryguytheman is offline
ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice
A while back, an accident occurred on the other side of the highway from me, and I ran over a piece of debris that flew over the divider right as I went by. Instantly flat tire going 75 MPH on I-70. Discount Tire "fixed" it. That particular tire has had a very slow leak ever since, where I have to fill it up every other week or so.
The steering wheel shake gets bad when that tire gets low. The shake seems to go away almost entirely when I check and adjust all 4 tires PSI. Worth noting that unequal PSI has a significant effect in my case.
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
ryguytheman is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 05:47 PM #13
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
My '20 SR5P came with the black TRD wheels, and I just noticed yesterday that three of the wheels have weights going halfway around the inside of the rim. I've never seen a tire/wheel combo require so much weight. I wonder if it's the wheels or the OEM Duratracs. I have the steering wheel shake too.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 05:54 PM #14
DEF4Runner's Avatar
DEF4Runner DEF4Runner is offline
DEF4Runner will become famous soon enough
DEF4Runner's Avatar
Unequal PSI as in 1-2 pounds?
SOLD 2008 V6 SR5 4X4 @ 165K: 265/70/17 Falken Wildpeak | SPC Racing UCAs | Method NV wheels | Wheeler's T1/T12 springs| Bilstein 5100
2020 Off Road 4X4: 265/70/17 Falken Wildpeak | OME 883/ Wheeler's T13 | Bilstein 5100 | Sprint Booster
DEF4Runner is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 06:00 PM #15
lyodbraun's Avatar
lyodbraun lyodbraun is offline
lyodbraun is on a distinguished road
lyodbraun's Avatar
Probably have too much weight on there definitely go in and have them road forced balanced...
lyodbraun is offline   Reply With QuoteReply With Quote
front , installed , lift , shake , tires
Steering Wheel Shake stever1000 3rd gen T4Rs 52 10-30-2021 03:04 PM
Possible fix for the steering wheel shake 68ChargerJMP 3rd gen T4Rs 3 01-08-2016 03:56 PM
Steering Wheel Shake nvestor88 3rd gen T4Rs 10 07-13-2014 01:40 PM
Steering wheel shake, need help sina518 4th Gen T4Rs 11 12-19-2012 05:46 PM
steering wheel shake rayny1014 3rd gen T4Rs 1 09-17-2007 09:39 PM
