Old 05-02-2020, 03:20 PM #16
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Is $500 for a 2017 TRDP suspension a good price?
Originally Posted by daytonaviolet View Post
Seems high for Oem suspension folks are taking off
I want to change my reply. Initially I thought this was TRD off road but now I realize it’s for TRD Pro Bilstein suspension.
I got mine ~ $700 from ‘18 ~ 5000 miles. Actually $500 is not bad for 20k miles. I would offer the guy $350 for the higher miles.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 05-02-2020, 04:03 PM #17
Rogue-Runner's Avatar
Rogue-Runner Rogue-Runner is offline
Rogue-Runner is on a distinguished road
I offered $350, but they just sold today. Seller said he'd reach out if it doesn't go through. Man, I really wanted them. If anyone knows where to get a TRD Pro bilstein suspension, please let me know. Thanks, everyone.
Rogue-Runner is offline   Reply With QuoteReply With Quote
Old 05-02-2020, 08:22 PM #18
jasxn's Avatar
jasxn jasxn is offline
jasxn will become famous soon enough jasxn will become famous soon enough
jasxn's Avatar
why not look for a comparable setup like bilstein 6112/5160? instead of netting 1" from the TRD Pro you can get up to 2.5". and trust me 2.5 is not a lot.
or look at Dobinsons setup if youre on a budget.
theres nothing fancy about the Bilstein TRD Pro setup. the FOX TRD Pro setup might be different? i dont know i havent really looked into it.
good luck with your search. you're bound to find more used setups.
i got the stuff
jasxn is offline   Reply With QuoteReply With Quote
Old 05-02-2020, 10:21 PM #19
The 6112/5160 was the route I was going to take. Then when I saw the low mileage ‘18 pro setup, well I wanted to give it a try.
I’m not into overlanding as much as I am more into Oem TRD stuff. It’s a family hauler limited with TRD looks. So far it’s working out fine with CF 2/1.5 leveling kit.
But I’m really itching for the entry level king setup.
Old 05-04-2020, 10:25 AM #20
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
Just a heads up
https://www.toyota-4runner.org/3483394-post17935.html
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 05-04-2020, 01:53 PM #21
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Is the OEM TRDP 6112 height adjustable like the retail version? I know a lot of people were taking it off to get more lift.
If it isn't, that alone would be enough for me to pass on an OEM take-off suspension.
It looks like Wheelers is also running 25% off stuff right now... might be worth looking into.
Bilstein 6112
Old 05-04-2020, 03:30 PM #22
Bilstein 6112
My TRD pro Bilstein suspension is not adjustable. There is one adjustment clip but it’s only 1/4 for the driver side.
Old 05-04-2020, 03:31 PM #23
Old 05-04-2020, 04:06 PM #24
Bumbo's Avatar
Bumbo's Avatar
Thanks for that info... I suspected the same, and is another reason I would be hesitant to jump on the OEM stuff unless a lift is of no interest to you, then it's a decent deal for $500 if it came with front and rear shocks + springs.
The 6112 is a pretty awesome shock, I run them in the front on my 4th gen, but also used the spring perch adjustments to lift the truck.
Old 05-04-2020, 04:42 PM #25
Then there are CF spacers Is 0 for a 2017 TRDP suspension a good price?
Old 05-04-2020, 04:52 PM #26
Hans Moleman Hans Moleman is offline
Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about
I would say no because I got spoiled when I bought the FJ Ultimate Trail Teams TRD suspension (PTR13-35140) for $500 from a Toyota dealer. It's similar to the 4Runner TRD Pro suspension except the coil springs are longer and slightly higher rate.
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
Hans Moleman is offline   Reply With QuoteReply With Quote
Old 05-04-2020, 05:08 PM #27
Bumbo's Avatar
Bumbo's Avatar
Now that you mention it... I do feel like my front coils could use a small bump up in spring rate.
That said, I did buy mine before they started offering different rates on the 6112.
Old 05-04-2020, 06:59 PM #28
Update: the original buyer flaked. Never showed up. I swooped in and picked it up for $400. I might have been able to get a lower price had I been more aggressive, but I'd be punching a wall if I missed out over $50 and had to wait for the next set to pop up locally. Super excited to do the install.
Time to shop for RGs, although not feeling great about my wife greenlighting that purchase anytime soon. It'd be a shame... if I blew a Dunlop while offroading... Southern Utah has some sharp terrain. If anyone has any pointers on how to not blow a tire, I'm all ears.
Old 05-04-2020, 07:20 PM #29
Bumbo's Avatar
Bumbo's Avatar
Run a lower air pressure off-road
Buy a tire that has thicker sidewalls if you go often.
When I go off-road, I expect to damage something. I don't do it intentionally but I'm not going to sit there and act surprised if I do. Just do a better job of preparing for it, because it's not if, but when. Air compressor, patch kit, green slime, breaker bar, valve stems, maintained spare...
Hopefully you like the 6112 shocks. They have been good to me.
Old 05-04-2020, 08:58 PM #30
awesome
so do you plan to run them stock trd pro or are you going to level
area , good , miles , price , suspension
2017 TRDP Clunk Hadelson 5th gen T4Rs 6 01-20-2019 08:31 AM
Are these suspension components a good deal for the price? DustyRoads 3rd gen T4Rs 3 08-25-2014 02:44 PM
Good Price for FJ suspension? Djrashonal 4th Gen T4Rs 17 06-08-2012 10:34 PM
Good price on FJ suspension MichaelM 4th Gen T4Rs 20 01-17-2011 07:00 PM
