Old 05-05-2020, 03:39 PM #1
KF4R2011 KF4R2011 is offline
KF4R2011 is on a distinguished road
Hayden 699 Transmission Cooler
Hey Guys, just wanted to throw this out. I purchased and had this transmission cooler installed downstream of the stock radiator. Massive improvement in temperatures at the torque converter. Highest ever recorded was 168F pulling just over 2000lbs up a hill and may have been in 5th gear (wasn't going fast but didn't have it locked out). Maybe 15 seconds after getting back on flat ground, the temps were in a free fall back to 138-143. It likes to stay ~140F to 158 depending on the terrain. Because it has a bypass "circuit" it almost seems like it "clicks" over some point because the temp will go up and then just rocket back down. Mounted it to the front aluminum bumper beam, sealed up the screws. Couldn't be happier. Its a 20,000 GVRW cooler so I should NEVER get over temp. Fit very well between the front clip and the factory radiator... all kinds of room in there.
Hope this helps someone. Highly recommend.
KF4R2011 is offline   Reply With QuoteReply With Quote
Old 05-06-2020, 09:29 AM #2
Moreno Moreno is offline
Moreno will become famous soon enough Moreno will become famous soon enough
Any photos of how you mounted this please.
Moreno is offline   Reply With QuoteReply With Quote
Old 05-06-2020, 10:54 AM #3
blackened_offroad blackened_offroad is offline
blackened_offroad has a spectacular aura about blackened_offroad has a spectacular aura about blackened_offroad has a spectacular aura about
at what point do you need a tranny cooler? towing?
blackened_offroad is offline   Reply With QuoteReply With Quote
Old 05-06-2020, 12:50 PM #4
I will get some pictures after work today.
The need for the cooler is because I tow about 2000lbs (including the trailer) and was seeing torque converter temps around 205F. Now I've never seen higher than 168F and that was for less than a minute. There are as many opinions as there are people but towing or not, I want my transmission to stay below 200 when towing and any other time, I want 140-160F.
The hayden unit has an internal bypass to allow the transmission to come up to temp quickly. But there might be some other kind of bypass if you live in a very cold climate. Central Texas may see a week's worth of days below freezing in any given year so I'm not worried about completely bypassing the cooler.
Old 05-06-2020, 04:14 PM #5
Seattle206's Avatar
Seattle206 Seattle206 is offline
Seattle206 is just really nice Seattle206 is just really nice Seattle206 is just really nice Seattle206 is just really nice Seattle206 is just really nice
Seattle206's Avatar
Good review. I am searching for an upgraded tranny cooler for mine.
Seattle206 is offline   Reply With QuoteReply With Quote
Old 05-06-2020, 09:18 PM #6
troopa4life troopa4life is offline
troopa4life is on a distinguished road
I'm wondering what the outside temps were when you recorded your trans temps.
troopa4life is offline   Reply With QuoteReply With Quote
Old 05-06-2020, 11:25 PM #7
Outside temps were around 80F.
So two screws into the bumper beam. One into the black bracket at the top and attached with aluminum angle. Screws are sealed to keep water out. Sorry about the pictures being rotated. My uploads all do that for some reason. My phone was in the upright position the whole time.
Hayden 699 Transmission Cooler-b43c9458-f972-4996-83d8-01d32f5a2c66-jpeg  Hayden 699 Transmission Cooler-b355c3b1-731e-4b3e-8d9b-abdc6046ad22-jpeg  Hayden 699 Transmission Cooler-2efbbce3-c4bb-4500-b028-19ca24b784e2-jpeg  Hayden 699 Transmission Cooler-4fb4c1da-2308-4f0e-b8af-82980c100b5d-jpeg  Hayden 699 Transmission Cooler-7b27494e-e22a-45cd-8187-c19acb516e19-jpeg
Old 05-06-2020, 11:29 PM #8
Hayden Automotive 699 Transmission Oil Cooler Amazon.com: Hayden Automotive 699 Transmission Oil Cooler: Automotive
Old 05-07-2020, 07:53 AM #9
picklebear picklebear is offline
picklebear is on a distinguished road
I have have a cooler on hand, ready to install. How did you differentiate between in the inlet and outlet hoses on the transmission? I haven't found a definitive answer on which is which, so I can ensure I install it on the downstream side of the radiator.
2014 SR5
picklebear is offline   Reply With QuoteReply With Quote
Old 05-07-2020, 09:19 AM #10
JPOVS's Avatar
JPOVS JPOVS is offline
JPOVS will become famous soon enough
JPOVS's Avatar
Did the hose sizes matchup? I've read about some of the other tranny coolers (B&M) out there on this forum where the hoses and outlets were different sizes compared to what's factory on the 4Runner.
2016 TEP, Elka 2.5 RR Adj F&R, Chaos UCA & LCA, OME 899, KO2 285/70E, Wheeler F&R Bumps, BMC, Spindle Gussets, Cam Tabs, Nitro 4.88 Gearing, Tranny Cooler, Hefty Fab F&R Bumpers Dual w/ ladder, Warn Plat 12s, Icon Pan & Billet Rear Links, OCD Links, GFC RTT, RCI Sliders, Every RCI Skid Plate (In Alum if avail), SCS Stealth 6 Rims, ARB Twin Comp, ARB 2500 Awn, Quick Pitch Shower Awn, Compustar T11 & RMS, Dual 42" drawers W/ Adj sleep/dog height platform (2nd Row Removed) Switch Pros, Baja LP9's, Squadron & S2 Pros, Rock Lights, Dometic CFX3 35qt.
JPOVS is offline   Reply With QuoteReply With Quote
back , cooler , front , radiator , temp
Hayden 678 Transmission Cooler TonyB66 3rd gen T4Rs 17 08-23-2021 02:03 PM
Hayden transmission cooler vs. B&M FiXXXerX 3rd gen T4Rs 13 07-10-2018 11:29 AM
Hayden 402 Transmission Cooler Write-Up 02_SE_Runner 3rd gen T4Rs 5 08-25-2014 01:33 PM
TRD Transmission cooler vs Hayden Smobien 4th Gen T4Rs 1 06-06-2013 04:50 PM
Clear corners and Hayden transmission cooler. slomatt Classifieds - buy & sell (no commercial ads please) 0 10-27-2010 03:25 AM
