05-08-2020, 12:35 PM
#16
Sell the tires you have, and upgrade before you wear the tires out. I just sold my Nittos with 3k miles on them for $150 less than you can buy them brand new for.
If you need the BMC, skip one night of NetFlix and knock it out; no big deal.
The fender liner mod only takes 5 minutes.
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
#17
Originally Posted by mteolus
You do realize that with 285's you'll have to do a fender liner mod, may have to remove mudflaps, and could possibly need a body mount chop?
Not true. The keyword is maybe on all. I didn't do any of that. Many people don't have to do any modification to get 285's to work. Since the OP is running trail edition rims its even less likely he will have to do anything to get it to work properly.
2016 TEP, Elka 2.5 RR Adj F&R, Chaos UCA & LCA, OME 899, KO2 285/70E, Wheeler F&R Bumps, BMC, Spindle Gussets, Cam Tabs, Nitro 4.88 Gearing, Tranny Cooler, Hefty Fab F&R Bumpers Dual w/ ladder, Warn Plat 12s, Icon Pan & Billet Rear Links, OCD Links, GFC RTT, RCI Sliders, Every RCI Skid Plate (In Alum if avail), SCS Stealth 6 Rims, ARB Twin Comp, ARB 2500 Awn, Quick Pitch Shower Awn, Compustar T11 & RMS, Dual 42" drawers W/ Adj sleep/dog height platform (2nd Row Removed) Switch Pros, Baja LP9's, Squadron & S2 Pros, Rock Lights, Dometic CFX3 35qt.
05-08-2020, 12:51 PM
#18
Having been through cooper 285 tires I am now back to KO2 275s
Off-road and look wise, no doubt 285s help. But for the majority of the drive time (tarmac) it was just too cumbersome for my taste.
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
05-08-2020, 01:06 PM
#19
I’m getting to the wire here and I’m still undecided. Grrrrr
Thanks for all the responses so far.
2015 Nautical Blue Trail Premium 4WD w/KDSS
2016 Magnetic Gray Limited 4WD
2000 Land Cruiser
05-08-2020, 01:08 PM
#20
I have 285's on my 17 SR5.
1½" spacer on top of OEM struts.
They slightly rubbed the inner fender liner until I moved the liners, about an inch.
Not stock wheels so no idea what offset they are.
05-08-2020, 01:37 PM
#21
285s were ordered. Install is 10:30 tomorrow.
2000 Land Cruiser
05-08-2020, 02:01 PM
#22
Hmm interesting. On a stock rig 275 vs 285 is noticeable. 275's almost drive stock whereas with 285's you definitely feel the sluggishness. However your 4R is definitely not stock and the CBI rear is probably around 225-250lbs. I was running 275's and then I threw on a rear bumper I could feel the extra weight. I went up to 285's after getting the bumper and really didn't notice much difference at all.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
05-08-2020, 03:59 PM
#23
Real Name: MURDERED TRD
I didn’t have to do any of that on my rig and I’m running the larger 285/70/17 Falken Wildpeak M/Ts with OEM 17x7 wheels. Supposedly the Falkens run larger than some of the other popular brands in the same size.
4Runners can be all set up different with brands of suspension components, lift height, tire size, tire brand, wheel size and extra weight in accessories.
05-08-2020, 09:02 PM
#24
Running M/Ts with trd offroad wheels (7.5). Only slight rub on mud flap near body mount on full compression. Not sure on the front since i chopped it.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
05-09-2020, 12:22 AM
#25
I only had to do minor trimming with my 285's. I think you made a solid choice.
05-09-2020, 05:14 AM
#26
The 275s looked good imo
2001 SR5 4x4 Premium
2017 SR5 4x4 Premium
17 SR5
05-09-2020, 05:58 AM
#27
Real Name: BLACK TRD PRO
Originally Posted by Xetabur
So a few weeks ago I had a lift and tires installed. I went with the Falken Wildpeak AT3Ws in 275/70/17 and I’m regretting not getting a larger tire.
Edit-285s were ordered. Install is 10:30 tomorrow.
Let's see some pics when you have the 285's on. I have 275's and sold my 265 Nittos immediately after purchasing my Pro. Then I did a 1.5/1" spacer lift to level it out. I'm satisfied with the look and result, plus I had to do zero mods for fitment. No rubbing and clearance issues fully articulated and I like running my front mud flaps. BUT, I will eventually go to 285's once the 275's wear down, as I think the 285-70-17 is the best size (looks/off road performance) tire on the 5th gen without sacrificing too much. Much more selection on 285's, and due to selection, if you blow a 285 out it is easy to find another one no matter where your at. It will also still fit in the spare area underneath.
05-09-2020, 07:28 AM
#28
Here's my 17 SR5 with 1½" front, 0 rear & 285's
05-09-2020, 11:07 AM
#29
Any mods. Looks like you still managed to keep your mudflaps. I am in the middle of deciding between 275s/lift with no mods and 285s/lift with potential mods.
05-09-2020, 11:52 AM
#30
interested as well, tire brand?
