Old 05-09-2020, 12:28 PM #31
Xetabur's Avatar
Xetabur Xetabur is offline
Xetabur will become famous soon enough
Xetabur's Avatar
The 285s are on and no rubbing. I’ll test them out on the trail later this afternoon.
I did go with P rated tires this time as I don’t need 10 ply tires. The 275s were LT.
2015 Nautical Blue Trail Premium 4WD w/KDSS
2016 Magnetic Gray Limited 4WD
2000 Land Cruiser
Xetabur is offline   Reply With QuoteReply With Quote
Old 05-09-2020, 12:42 PM #32
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
Originally Posted by patkelly4370 View Post
Here's my 17 SR5 with 1½" front, 0 rear & 285's
Toyo Open Country A/T on Mickey Thompson "Deegan 38" wheels. They were on the truck when I bought it.
At full lock they barely kissed the fender liners, really wasn't an issue. But I did the mod anyway. I almost used a heat gun to push in the nub where they rubbed.
Mudflaps are still intact. Contact hasn't exceeded flex, yet.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 05-09-2020, 12:58 PM #33
Need pictures!
Old 05-09-2020, 02:52 PM #34
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
Interested in hearing about the ride quality difference as I have E rated 275’s and my C rated 285/75-16’s on my 2001 Runner rode nicer. Also, would like to see some comparison pics.
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 05-09-2020, 04:28 PM #35
sicnarfone's Avatar
sicnarfone sicnarfone is offline
sicnarfone will become famous soon enough
sicnarfone's Avatar
Originally Posted by teldel View Post
interested as well, tire brand?
BFG KO2s
sicnarfone is offline   Reply With QuoteReply With Quote
Old 05-09-2020, 07:05 PM #36
Xetabur's Avatar
Xetabur's Avatar
Here are a few pics of the tires side by side. The tread depth is smaller in the P rated 285s but they're really quiet and the weight feels about the same as the LT275s.
For some reason I cannot upload pics right now.
2000 Land Cruiser
Old 05-09-2020, 10:35 PM #37
adrummingdude's Avatar
adrummingdude adrummingdude is offline
adrummingdude will become famous soon enough
The 275 vs 285 vs tall skinnies is where I'm currently at as well. I wonder though, why is it that everyone says you "might" need to do a BMC? Aren't these trucks pretty much all the same, and tire brands sizing only varies typically by a few tenths?
If 285s really are that close to everything, running them probably isn't the best idea? Heaven forbid you hit a pothole and rip your fender out because your suspension compressed a few inches.
2020 TRD PRO - Morimoto 2 stroke LED's - KC flex pillar pods - Rigid rack pods - Goal Zero 100w panel/ Yeti 200X - Rago MOLLE panels and shelf - Thule cargo box - Gobi Ladder - Rotopax
adrummingdude is offline   Reply With QuoteReply With Quote
Old 05-10-2020, 04:13 AM #38
DaveSki DaveSki is offline
DaveSki has a spectacular aura about DaveSki has a spectacular aura about
Running C load rated 285 KO2s that were Jeep takeoffs. The 116Qs only weigh 50 pounds and balance a lot easier. Tucked under a 2.5”/2” lift. No rub, not even close to hitting the body mount.
2012 Blizzard Pearl Limited. 17" Icon Rebounds w/285/70/17 KO2s. TRD Pro skid plate. Eibach/Wheelers/OME 2.5"/2" lift. Low Pro Rola rack. USR Blackout Tail Lights, Canadian SR5 front bumper swap.
DaveSki is offline   Reply With QuoteReply With Quote
Old 05-10-2020, 05:01 AM #39
That’s what I would like to run after my 275 KO2’s E rated tires (57 lbs.) get a bit more worn. How’s the ride quality?
Old 05-10-2020, 10:05 AM #40
I’ve been really happy with suspension and tires. Don’t notice a ton of road noise, tracks straight, no issues in rain. Have them set to 38 psi.
Old 05-10-2020, 10:32 AM #41
Chris In Milwaukee's Avatar
Chris In Milwaukee Chris In Milwaukee is offline
Chris In Milwaukee will become famous soon enough Chris In Milwaukee will become famous soon enough
I think a lot of it has to do with wheel width/offset choices. The greater of either, the greater the likelihood of rubbing, and at varying extents.
2019 MGM TRD ORP
BFG KO2 265/70-17
Dobinsons C509-302/GS59-700, C59-505/GS59-705, UCAs
Victory 4x4 Blitz Bumper w/Zeak 12000
Chris In Milwaukee is offline   Reply With QuoteReply With Quote
275/70/17 , at3ws , i’m , larger , regretting
Driver's Door Lock Actuator Motor Repair [step-by-step w/ pics!!] mbumpus11 5th gen T4Rs 181 01-11-2024 04:18 PM
4th Gen Door Lock Actuator Replacement: Step by Step with Pictures y=mx+b 4th Gen T4Rs 13 10-22-2023 12:27 PM
Step-by-Step guide to install in dash navigation system.. punupara 4th Gen T4Rs 2 03-12-2012 09:21 PM
'99 Deckplate mod (4cyl) page - step by step directions for deck plate mod jmfranc 3rd gen T4Rs 9 04-22-2008 11:32 PM
