05-08-2020, 10:10 AM
Should I step up to a 285/70/17?
So a few weeks ago I had a lift and tires installed. I went with the Falken Wildpeak AT3Ws in 275/70/17 and I’m regretting not getting a larger tire.
Edit-285s were ordered. Install is 10:30 tomorrow.
2015 Nautical Blue Trail Premium 4WD w/KDSS
2016 Magnetic Gray Limited 4WD
2000 Land Cruiser
05-08-2020, 10:12 AM
of course.
it's going to happen go on and do it.
05-08-2020, 10:14 AM
Nah 275's look just fine my guy.
Lift specs tho?
2015 Limited Blizzard Pearl: OEM TRD Pro Fox Suspension | 2”/2” Cornfed Spacers | TRD-OR 17" | 285/70/17 Firestone Destination A/T | Shrockworks Rocker Panels
05-08-2020, 10:15 AM
Lift specs tho?
OME medium lift (2.5” I believe).
2000 Land Cruiser
05-08-2020, 10:23 AM
Looks pretty good to me. Why not wear those tires out and then decide if you want to upgrade?
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
05-08-2020, 10:30 AM
I will be keeping the tires and installing them on my limited once I get wheels for it.
2000 Land Cruiser
05-08-2020, 10:43 AM
Glad I'm not the only one. Same situation installed Kings with 275s. In the process of ordering 285s at the moment.
2019 4Runner TRD Pro
2016 BMW M4
05-08-2020, 10:51 AM
I have until 2pm today to pull the trigger so they can be installed in the morning.
Any idea how much bigger the sidewall is on the 285 vs 275?
I’m open to a skinny tire with more sidewall if anyone has any suggestions.
2000 Land Cruiser
05-08-2020, 10:59 AM
Real Name: MURDERED TRD
Sounds like you have a back up plan for your 275’s so I would say go ahead get the 285’s or it will just keep chipping away in the back corner of your mind. I knew this going from 265 to 285. I originally thought about 275 but skipped it and went straight to 285 and I’m glad I did. With that said, theres nothing wrong with 275’s but it wasn’t the overall look I wanted to achieve on my rig. Everyone’s personal taste and use for their own rig is different. YMMV
05-08-2020, 11:09 AM
285's in some brands such as Cooper (current tire) weigh the same as 275's in the popular KO2 choice, 55lbs.
Ride like glass and love them.
05-08-2020, 11:23 AM
Here is a clip from my tire decision excel document!
275- diameter 32.4
285- diameter 32.8
255/80 would be a good choice for you - 33.1
05-08-2020, 11:24 AM
You do realize that with 285's you'll have to do a fender liner mod, may have to remove mudflaps, and could possibly need a body mount chop?
05-08-2020, 11:31 AM
275s look fab! But I do get the draw toward the 285s!
2019 MGM TRD ORP
BFG KO2 265/70-17
Dobinsons C509-302/GS59-700, C59-505/GS59-705, UCAs
Victory 4x4 Blitz Bumper w/Zeak 12000
05-08-2020, 11:57 AM
275- diameter 32.4
285- diameter 32.8
Hmmmm 255/80
Might have to go that route. Thanks
2000 Land Cruiser
05-08-2020, 12:05 PM
I would say yes to going 285, but like a few people said, I would recommend you wearing out those tires before going 285s.
2018 TRDOR W/KDSS
