Old 05-10-2020, 08:32 AM #1
rigtimmins rigtimmins is offline
rigtimmins is on a distinguished road
Stock size Nitto Ridge Grapplers
Anyone have exp with these? I'm throwing a lift on soon, but I think I'm just going to keep stock size tires and push em out a bit. Want these ridge grapplers but know they only come in E load. Ride a lot stiffer? Big mpg hit? Should I just upgrade to C load 285 Ridge Grapplers? I don't really need the bigger tires, and I want to have somewhat ok mpg since its my dd, and I believe 265 with a 2/1 Dobinsons will be plenty capable of handling most of the stuff out here in NoVA.
rigtimmins is offline   Reply With QuoteReply With Quote
Old 05-10-2020, 09:32 AM #2
ScottR ScottR is offline
ScottR is on a distinguished road
E rated tires will not be kind to you, especially after the lift stiffens things up a bit. Stick with C load on your dd.
2014 Super White TEP, Dobinsons 2"/1" lift, Firestone Destination AT2 265/70‑17, OEM led headlights 81070-35600/ 81140-35610
ScottR is offline   Reply With QuoteReply With Quote
Old 05-10-2020, 09:43 AM #3
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Nitto Ridge Grappler?
Nitto Ridge Grapplers...long term reviews and impressions?
Nitto Ridge Grappler C & E Load Help
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 05-10-2020, 10:06 AM #4
Appreciate the links! Looked around for a bit and could only find 285 write-ups really.
Old 05-10-2020, 11:13 AM #5
RusPro17 RusPro17 is offline
Real Name: Don
RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about
Real Name: Don
If you go over to the ArmyGreen Pro link I just added SCS wheels with Falken AT tires. There pretty aggressive and I went with 10ply they ride good and no loss of power. I’m lifting mine down the road a little and staying with stock size tires. I believe the reason I don’t feel any power loss is I have a sprint booster on my Pro.
RusPro17 is offline   Reply With QuoteReply With Quote
Old 05-10-2020, 12:49 PM #6
CO-Cygnus's Avatar
CO-Cygnus CO-Cygnus is offline
CO-Cygnus will become famous soon enough CO-Cygnus will become famous soon enough
CO-Cygnus's Avatar
+1 to this, stick with Cs.
CO-Cygnus is offline   Reply With QuoteReply With Quote
Old 05-10-2020, 12:58 PM #7
Mello03's Avatar
Mello03 Mello03 is offline
Mello03 is on a distinguished road
Mello03's Avatar
Both stock size and 285s come in standard load. I run SL in 285s.
2020 Nautical Blue ORP ADS suspension, Icon Deltas, FN Pro wheels, Ridge Grapplers, CBI skids....
Mello03 is offline   Reply With QuoteReply With Quote
Old 05-10-2020, 01:53 PM #8
Rogue-Runner's Avatar
Rogue-Runner Rogue-Runner is offline
Rogue-Runner is on a distinguished road
I've looked but have seen very little information on the 285 SL. What made you choose SL over Cs? Any regrets? Any idea how they handle on light to moderate off roading? I'd appreciate any feedback since I'm getting these for memorial day and it's coming up.
Rogue-Runner is offline   Reply With QuoteReply With Quote
Old 05-10-2020, 03:25 PM #9
Mello03's Avatar
Mello03's Avatar
I wanted the lighter weight and ride and get 18+ mpg. I‘m 95% on road and they’re great. I run 34 psi in them and with my suspension it’s phenomenal. I aired them down to 20 a few times and they’re great, but I’m very choosy about my tire placement. This thing won’t see a ton of trails for a few years.
Old 05-11-2020, 07:54 PM #10
SilentWalker SilentWalker is offline
Real Name: Creech
SilentWalker is on a distinguished road
Real Name: Creech
I run the 285 SL’s as well. I picked the SL’s because they were $211/tire vs $275/tire. Doing the lift and tires at the same time, I was looking to cut costs where I could and figured I could always go with the higher load on the next set. They ride good to me.
2019 Magnetic Gray TRD Off Road Premium, non-KDSS | NITTO Ridge Grapplers SL | 3” Bilstein 6112 w/ Medium Duty Springs | 2” Bilstein 5100 w/ Heavy Duty Springs | N-Fab RKR Step Rails | Supernova V.4 LED Headlights and Fogs | 1.25” G2 Wheel Spacers | TRD Pro Grille and Skid Plate
SilentWalker is offline   Reply With QuoteReply With Quote
Old 05-11-2020, 11:37 PM #11
UTKSmokey's Avatar
UTKSmokey UTKSmokey is offline
UTKSmokey is on a distinguished road
UTKSmokey's Avatar
If you’re not using them to off-road, skip them.
I’ve had them since August.
They start quiet and then get louder, not bad really But you can hear them if radio isn’t cranking.
Vibrations have been an issue since day one, 60mph type vibration. Didn’t have it before and they come and go with rotations & weather (hot and cold).
Mileage took a 20+ mile per tank hit.
Really wish I would have gone more AT. Daily driving is fine if you wheel. If you don’t wheel i’d look for a tamer tire.
Stock size Nitto Ridge Grapplers-acef2f87-2ead-42f8-aa95-b8c1304eff67-jpg
UTKSmokey is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 11:52 AM #12
C load range or SL?
Old 05-12-2020, 04:20 PM #13
UTKSmokey's Avatar
UTKSmokey's Avatar
Sl (265/70r17 115t)
Old 05-12-2020, 04:59 PM #14
the_fornicator the_fornicator is offline
the_fornicator has a spectacular aura about the_fornicator has a spectacular aura about
Why would E load tires not be kind?
I jumped from Ds to Es (no reason other than lack of option) and haven't noticed too much of a difference with the exception of a noisier tire. Weight wise, there's only a 1 lbs difference between loads. I'm sure the weight different will eventually translate to worse mileage.
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Procharged (D1SC), Bilstein 5100s w/ 2" Toytech Superflex, 285/70/18 duratracs (E), 18x9 Volk TE37, OEM Audio+ Ref500, RA Motorsports rack, TRD hood + skid // 2003 Black Limited (2UZFE) aka Blacky Chan: Bilstein 5100 w/ Icon 2.5" springs, BMC, air bag delete, 17x9 SCS Ray10, 285/70/18 Yokos
the_fornicator is offline   Reply With QuoteReply With Quote
grapplers , load , ridge , size , stock
General Grabber vs Nitto Ridge Grapplers benhalleniii 5th gen T4Rs 21 02-20-2020 12:32 PM
FS: 4 Used/1 New Nitto Ridge Grapplers 285/70/17 - Bay Area SAC-CA-Runner For Sale: Suspension/Wheels/Tires 3 06-30-2019 12:12 AM
FS: (5) 285/70/17 Nitto Ridge Grapplers Like New! SOLD - Canton, GA dot_tom For Sale: Suspension/Wheels/Tires 2 02-28-2019 05:07 PM
