Old 05-12-2020, 12:56 AM #16
CF_Machete's Avatar
CF_Machete CF_Machete is offline
CF_Machete has a spectacular aura about CF_Machete has a spectacular aura about
CF_Machete's Avatar
Originally Posted by mteolus View Post
Why don't you install a E-locker (Eaton seems to be the brand of choice there) instead of an air locker? That way you won't have to worry about air leaks or the addition of an air compressor under the hood.
Eaton e-lockers require a half wheel turn to engage and to disengage. So if you are on a steep incline and need to back up, you will have to rotate your wheels 360 to disengage and then re engage. Sound like something you want to chance in a hairy situation?
Troner envy... the struggle is real!
CF_Machete is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 04:35 PM #17
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
IMO if that diff is coming out, no way it's going back in WITHOUT a locker. I will do dual ARB air lockers if I ever go for a re-gear one day. Or just spend the $$ on a supercharger.
I love the traction aids on my T4R, especially the crawl control as for sand self rescue.. they all come close to, but never beat a good ol' mechanical diff locker.
FYI I mainly offroad in deep sand with very few rock stuff
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 04:50 PM #18
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Everyone I know swears air lockers are either totally reliable and okay even for a daily driver or unreliable shit.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 05:22 PM #19
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
Yeah. Experiences are always at the polar ends. If I didn't have a rear locker I'd probably look into something like a Harrop E-locker.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 05:36 PM #20
4rNCMTNs 4rNCMTNs is offline
4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light
I can say I regret not adding the front locker when I changed the gears. I just recently added the front locker (already had rear E-locker from factory) and of course paid twice to send front diff to ECGS and twice for the labor. In hindsight I should have done it at the same time.
So, in my opinion if you can afford it and think you will need it I would do it at the same time.
then E locker vs ARB as others said good and bad for each, I ended up putting the Harrop in the front and running it through my spod.
4rNCMTNs is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 05:39 PM #21
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
My only beef with Harrop E-locker i availability and cost.
I talked to my diff guy about ARB and kept talking about all the concerns and issues I read about... at the end of the day it comes down to maintenance.
If it was properly installed, you shouldn't have problem. If you develop an air leak in the fittings or lines, it's time to maintain it.
It doesn't matter what it is... batteries, shocks (oil/seals/rebuilding), engine hoses, fluids, air lines... sooner or later something is going to need a little upkeep.
I just look at this as part of ownership once you get into this type of thing.
Old 05-12-2020, 05:42 PM #22
Bumbo's Avatar
Bumbo's Avatar
ARB air solenoids are still electric... you can wire them up to an spod or switch pro without issues.
The user experience for both is pretty much the same once it's installed. That said, you will use one additional circuit for the compressor assuming you have a dedicated one and not just using OBA.
Old 05-12-2020, 06:03 PM #23
itr1275 itr1275 is offline
itr1275 has a spectacular aura about itr1275 has a spectacular aura about
Originally Posted by RustyAb View Post
Just wondering if there is anyone out there that has re-geared a SR5, and didn’t opt for the air locker since everything was open? Getting my 4.56’s installed this week and I’m having second thoughts on the locker.
I live in an area where there’s no real chance of rock crawling. Just some good ol mud, and rocky terrain in the mtns. I’ve always been a guy that says ‘go big or go home’ but with work being dead lately I was nervous about spending another 2grand on that. But right now I’m thinking I might regret it down the road...
If you do any off roading at all and you have the money, get the locker without a doubt. It's not just for rock crawling, it works when your stuck... bad.
The only reasons (send the hate mail) to get the Off Road version is for the KDSS and the e-locker. The KDSS is sort of useful to add like 2" of wheel travel in the front. Maybe a bit more in the back. But the e-locker is gold!
Yes you have ATRAC, but it's not the same as a locked axle. And it doesn't sound like your truck is imploding when you use it.
Get the locker.
itr1275 is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 06:38 PM #24
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
Eaton just released a 5th gen specific e-locker a couple of months ago. Should be widely available and I have my supplier sourcing it right now. Will post up once I get it. Even though I have everything already plumbed out for an air locker I'm going with an electric actuated one for reliability reasons.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 06:50 PM #25
I agree with you on user experience and the maintenance aspect. If air lines break they are easy, cheap, and quick to repair assuming you the right tools on the trail.
I already have my compressor wired to spod as well as I had space available but will most be likely adding a second one soon as this stuff never ends.
Old 05-12-2020, 06:51 PM #26
From order to install was under two weeks for me. I got mine from ECGS as they are close to me and it's just too easy.
Old 05-12-2020, 07:02 PM #27
Bumbo's Avatar
Bumbo's Avatar
To me its part of the hobby. I try to be geared up for basic trail repair. Expect issues and prepare for them.
There is one thing I don't mind is electrical work... I rather enjoy it, so adding a few circuits or doing some custom work is enjoyable to me.
Old 05-12-2020, 07:49 PM #28
I hear you, I love this hobby. I'm getting better and better with the electrical work not your level at all, but maybe one day. I added 3 more circuit breakers (total of 4 on top of the spod) for car audio and another 12 position fuse panel in back of truck this past weekend. I should start my build thread soon...
yes most us all agree get that locker
Old 05-12-2020, 10:52 PM #29
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
I have been looking for it but do not see it anywhere other than the flyer.
delloro is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 11:14 PM #30
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
Same with the stock TRD Off-road. That is the nature of E-lockers. Most of the time you would engage the locker before you get onto something rather than waiting until you are in a bind.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
air , i’m , locker , regret , sr5
Need ideas for adding Rear Tie Down Points jtice 5th gen T4Rs 3 04-27-2019 09:11 AM
Rear Locker vs Center Locker in Practical 4x4 Uses?? Xx_Black-out 3rd gen T4Rs 46 11-24-2017 10:43 AM
Any difference in rear axle shafts between e-locker/non locker? 99Runnr 3rd gen T4Rs 4 02-25-2016 09:19 PM
WTB: '96-00 4runner with E-locker or rear axle w/ e-locker StreetKill831 Want to Buy/Trade 3 08-24-2011 10:26 PM
what does regearing mean for my factory locker? theizzardking 3rd gen T4Rs 1 09-10-2009 10:24 AM
