Old 05-10-2020, 10:42 PM #1
bnvu19 bnvu19 is offline
bnvu19 is on a distinguished road
Alignment UCA Question
Hey guys...just wanted to check in with the experts out there. I just installed my Cornfed spacers on my '17 TRD Pro. I did a 2/1.5 lift and also installed the JBA UCR. Man were those annoying to install. I am still keeping my stock 265 Nittos as I wanted to jump up to 285 Ridge Grapplers, but they were on backorder. An alignment was done after the install of the UCAs. When I make the jump to bigger tires, does another alignment need to be done. My buddy said I should be okay, but just wanted to check to make sure my new tires perform at optimal efficiency. Aloha all.
bnvu19 is offline   Reply With QuoteReply With Quote
Old 05-10-2020, 11:42 PM #2
joshers22 joshers22 is offline
joshers22 is on a distinguished road
Any changes in your suspension or tires/rims require an alignment to get proper alignment. Although the difference may be considered minimal between 265/285, itís still a difference in which you may see improper wear.
joshers22 is offline   Reply With QuoteReply With Quote
Old 05-11-2020, 12:28 AM #3
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is just really nice daytonaviolet is just really nice daytonaviolet is just really nice daytonaviolet is just really nice
Most shops warranty there alignment. When you install the 285ís, your shop should check/align for free.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 05-11-2020, 11:13 AM #4
Finslayer83 Finslayer83 is offline
Finslayer83 will become famous soon enough
Depending on which wheels you are going to run with 285's the JBA's might rub the tire if on stock wheels.
I've encountered this before on my Tacoma, went with Dobinson UCA for my TRDP / CF setup - but I'm running FJ steelies.
Finslayer83 is offline   Reply With QuoteReply With Quote
Old 05-11-2020, 11:25 AM #5
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future Jetboy has a brilliant future
Jetboy's Avatar
The answer is no. You do not need to re-align after changing tires. Alignment is independent of the tires or wheels and does not change if you change tires/wheels. The only reason you might want to re-align it when changing tires would be if you want to adjust caster so you can eliminate a rub somewhere. You'll need to install them and see first.
Old 05-11-2020, 04:08 PM #6
Thanks all. Really appreciate the feedback.
Old 05-11-2020, 09:04 PM #7
Arnezie's Avatar
Arnezie Arnezie is offline
Arnezie will become famous soon enough
Arnezie's Avatar
I buy Firestone lifetime alignment with every vehicle Iíve messed with the suspension on. Itís worth it.
Arnezie is offline   Reply With QuoteReply With Quote
Old 05-11-2020, 10:22 PM #8
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
Do you possibly have the estimate from FireStone showing they will honor the lifetime alignment on a modified vehicle?
I always go to a Firestone since its the closest to my house and they do not sell the lifetime on vehicles with modified suspension. I never argued because they weren't trying to rip me off and I figure it was valid since I didn't mod the suspension.
But If I can get them to give me lifetime I'm all for it. Unless it is just for this one Firestone.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 05-11-2020, 11:15 PM #9
MeefZah's Avatar
MeefZah MeefZah is offline
MeefZah is a glorious beacon of light MeefZah is a glorious beacon of light MeefZah is a glorious beacon of light MeefZah is a glorious beacon of light MeefZah is a glorious beacon of light MeefZah is a glorious beacon of light
MeefZah's Avatar
I don't have a document I can validate this with, but I also get a Firestone lifetime alignment on new vehicles and they never have blinked at aligning lifted vehicles.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You canít grasp its vastness from a plane. Itís diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
Photos, mods & trip reports
MeefZah is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 12:32 PM #10
Guess next trip I'll ask again.
2018 TRD OFF ROAD
My Build
Old 05-13-2020, 06:34 AM #11
Arnezie's Avatar
Arnezie's Avatar
Firestone shops are independently owned and operated so all I can tell you is my local Firestone will align mine knowing that I have modified it and I even discussed that i just put the 6112ís on the front and am debating on raising the front and rear another inch. My Firestone service guy said well if I do bring it right back and that if I do any off-roading I should bring it in 3-4 times a year to keep everything within spec. Iíve had many vehicles over the years that Iíve lifted and always bought the lifetime alignment. A regular alignment in my area is $99 everywhere. $199 for lifetime knowing Iíll be tweaking and changing parts pays for itself in short time. They run a special once a year and never let it out ahead of time when itís going to be but it was already done on Presidentsí Day this year where itís only $125 for lifetime
Old 05-13-2020, 09:47 AM #12
Jetboy's Avatar
Jetboy's Avatar
All of the firestone shops in northern Utah closed except one or two that are not close. I think there's only one left in Utah now.
Old 05-13-2020, 12:48 PM #13
Firestone shops are independently owned and operated so all I can tell you is my local Firestone will align mine knowing that I have modified it and I even discussed that i just put the 6112’s on the front and am debating on raising the front and rear another inch. My Firestone service guy said well if I do bring it right back and that if I do any off-roading I should bring it in 3-4 times a year to keep everything within spec. I’ve had many vehicles over the years that I’ve lifted and always bought the lifetime alignment. A regular alignment in my area is $99 everywhere. $199 for lifetime knowing I’ll be tweaking and changing parts pays for itself in short time. They run a special once a year and never let it out ahead of time when it’s going to be but it was already done on Presidents’ Day this year where it’s only $125 for lifetime
I never did argue because I wouldn't want to honor a lifetime alignment when someone mods the suspension either.
Not looking to rip them off I figure I just ask again.
I won't be due for another alignment for a while. My thing has been a garage queen. I might hit 1K miles this year.
2018 TRD OFF ROAD
My Build
Old 05-13-2020, 02:10 PM #14
MeefZah's Avatar
MeefZah's Avatar
You sure they are independent? I'm almost certain they are corporate. Their warranty and lifetime services are honored at all locations.
Edit, corporate:
Bridgestone Retail Operations | Automotive Service Providers
alignment , install , make , tires , wanted
alignment question tomania23 4th Gen T4Rs 1 06-06-2018 04:07 PM
Help! Alignment Question d0nkeyxpunch 3rd gen T4Rs 35 06-27-2017 07:53 PM
Alignment Question michael33r 3rd gen T4Rs 27 11-05-2015 01:20 PM
Alignment question AZrunner11 5th gen T4Rs 2 06-02-2014 10:18 AM
4th gen alignment question nyc4runnin 4th Gen T4Rs 10 10-04-2010 06:55 AM
