10-25-2020, 07:10 PM
#106
Originally Posted by dowling177
I was able to download the file as well and when I opened it up the text is all scrambled. I have attached the first page to show you what it looks like. I am opening it with Bluebeam. I am excited to figure this out to start working on my 4Runner
I only use open source software (unless there's no way to), so I can't confirm that it will work for all PDF viewing software. I use SumatraPDF and whenever I have to digitally sign something I'll resort to using Adobe.
My best advice is to see if you can use SumatraPDF.
Please note, some pages actually DO have scrambled text. This took so long that I wasn't able to individually confirm that all 8,593 pages weren't corrupt.
If someone is crazy enough to remake this, I have all of these pages as individual files if someone really wants to pay the $20, download the pages that are corrupt and then merge them all into one file again......lol. I doubt doing this would be worth anyone's time though.
2016 SR5, electronic dial actuated, part-time 4WD
2016-2019 service manual: https://www.toyota-4runner.org/5th-g...l-rm27f0u.html
12-07-2020, 11:57 AM
#107
Real Name: Todi
Real Name: Todi
I tried today to download the file but I was not able to. Is the sharing turned on?
Thanks
2018 TRD OR
- SSO Full Rack; Ironman 4x4 Stage 3 Foam Cell Pro: Constant Load – front, Performance Load – rear; M.O.R.E. aluminum full set skid plates; Artec aluminum gas tank skid; RCI front filler skid plate; HetfyFab Low-Profile Banshee Bumper; ReszFab flat sliders; Smittybilt 98695 XRC 9.5K GEN3 Winch; Pedal Commander; ARB diff breather; Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Wildpeak AT3W LT285/70-17 E;
12-08-2020, 12:20 AM
#108
Thanks
You have to manually type in the link exactly, i.e. it is case sensitive. It can be a challenge, but I was eventually able to do it.
12-08-2020, 07:55 AM
#109
Real Name: Todi
Real Name: Todi
Got it, I had 2 typos. THANKS
2018 TRD OR
01-08-2021, 01:03 AM
#110
I hope DougEFresh2 received his "4runner Owner of The Year" award! So great.
Thank you for sharing!
02-11-2021, 12:09 PM
#111
Well I'm having trouble too.
I got the Zip file downloaded but when I try to extract with 7Zip I get a password incorrect error.
7Zip goes ahead and places a PDF file in the Folder but its size is 0Kb
I've read to use the "HASH" in this case. Are those "Hash" thingys alternative passwords?
If not how are they used? If they're passwords, I get the same error. Incorrect Password"
Thanks
02-11-2021, 01:42 PM
#112
Thanks
IIRC I didn't have to mess with the HASH stuff at all. Are you sure you entered the password correctly? It the whole string, starting with "x*" and ending with "83".
2019 TRD ORP
02-11-2021, 01:47 PM
#113
Yes I copied and pasted.
Maybe I have to actually type it in??
02-11-2021, 02:20 PM
#114
Copy Paste didn’t work for me, but typing it in gave me no problems.
2014 MGM TEP - Dobinsons’ C59-300, Bilstien 5100 (front set to stock height), Cornfed 1/2 spacers in rear, Spidertrax, Airlift 1000
02-11-2021, 04:19 PM
#115
thanks.. i was able to download and view now. i used extract here then pasted password.
02-11-2021, 05:58 PM
#116
Typing or pasting doesn't work for me.
Extract or Extract Here
Tried it within Explorer/Downloads and my 4Runner Folder and within 7-Zip as well.
Nothing works.
Guess I'm SOL
02-11-2021, 07:14 PM
#117
TOYOTA 2016-2019 4Runner Repair Manual RM27F0U
Nothing works.
Guess I'm SOL
I did this a few times with errors too. I kept on getting a 0 file size after extracting.
So I deleted the zip and pdf. I downloaded again, extra fed and pasted the password. Then it worked. Strange right
02-26-2021, 09:50 AM
#118
Thanks
@ DougEFresh2
for putting this together!!!!
For the Mac Users out there, just downloaded Keko to unzip it and it worked like a charm.
Cheers!
04-28-2021, 12:30 PM
#119
Thanks for doing this!
My download was successful, but all of the text is scrambled.
Is this file corrupt, or is there another method to obtain the uncorrupted version?
04-28-2021, 09:57 PM
#120
try using the HASH to verify that your downloaded copy of this file isn't corrupted, that's why I included it.
See below for HASH information:
Compare Checksums on Windows:
Types of hash algorithms: md2, md4, md5, sha1, sha256, sha384, sha512
Command: certutil -hashfile location\file hash_algorithm
Example: certutil -hashfile C:\game.exe sha256
Compare Checksums on Linux:
Types of hash algorithms: md5sum, sha1sum, sha224sum, sha256sum, sha384sum, sha512sum, sharesec
Command: hash_algorithm location/file
Example: sha256sum /home/game.iso
Alternatives: Download the latest and past versions of QuickHash here (replaces the former hosting page of sourceforge.net/projects/quickhash | QuickHash GUI
Source: GitHub - tedsmith/quickhash: Graphical cross platform data hashing tool for Linux, Windows and Mac
